Question about Microwave Ovens
Microwave burnt spot on door seal
I have a 2 year old sharp carousal microwave. There is a 1 inch wide burn mark on the top left hand side between the door seal and microwave door opening. The plastic section of the door seal has melted whilst the paint on the corresponding oven frame has a burnt mark.
We first noticed a small mark some time ago but it seems to have enlarged after some face wax was heated in it.
Could it have something to do with the wax overheating giving off vapor which escaped or built up on a small section of the seal, spot burning at this point?
Is the microwave still safe to use?
MicrowaveSvc
  • 9098 Answers
SOURCE: Burning smell from microwave
This is the waveguide cover / stirrer cover.
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
Please reply back with your brand and model number so we can help you in obtaining parts.
Otherwise, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave door has burnt patch: is it safe to operate?
From your other post:
The paint should be available at big box stores like Wal-Mart, home improvement centers like Builder's Square, Lowe's, or Home Depot, or hardware stores or local appliance parts stores.
You can order the plastic sheet (called the "door film") here. It is part # WB06X10490.
Be sure the mesh is clean and dry before installing the new film.
Posted on Jul 23, 2008
MomsyKat
  • 52 Answers
SOURCE: burn at bottom of microwave
First try cleaning the burned mark off. Dip a scrubber in lemon juice and sprinkle salt on it; this is also great for burned coffee pots. The smell can be gotten rid of this way: Boil lemon peel in water, then put the water in a spray bottle. Not only will it make your microwave smell fresh but the lemon oil will make it easier to clean. If it still smells of burning rubber, take the back off and inspect the wiring. IF you see burned wiring, please do yourself a favor and replace the microwave!
Microwaves work by making the molecules in food get "excited"-they move more-meaning, if there IS rubber burning, then there will be minute molecules of rubber in your food, which is BAD for your immune system. If it's just burned chocolate, though, it is harmless unless you are allergic.
Posted on Aug 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave partially heats
Assuming your power line voltage is right, bearing the whole thread in mind, I'm sure you have a bad magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you follow the safety & disassembly info, this is not a difficult job for a do-it-yourselfer.
Posted on Dec 05, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: my mother's GE microwave oven
That would be the stirrer assembly. It consists of the stirrer motor, stirrer blade, and stirrer cover.
Without the stirrer in place, the oven will not cook evenly and may arc and spark.
Without the cover in place, food particles and grease can get on the waveguide and magnetron, and cause arcing damage.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you need to replace the stirrer motor, you'll probably have to pull the oven from the wall. You can download GE owner's manuals and installation instructions here.
Posted on Dec 08, 2008
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
Loud boom and burning smell in microwave
Is there any holes burnt into the liner inside the micro wave.? Or burn spots showing.? If there is thow it out. It is not safe to be useing it.It could start on fire. That problem is from when they are not clean out once in a while. End food is burn,t onto the interior liner end grease end oil,
Oct 22, 2012 | Sharp KB6001NS 24 Inch Microwave Drawer...
Problem with the Whirlpool GH5184XPQ 1100 Watts Microwave Oven: In turning the microwave on this morning, a faint electric sparking was heard. Upon shutting it off and opening the door an acrid burning...
The problem is that the magnetron is arcing when it is running and it has found a couple bare spots 'exposing the metal'. The microwave uses a special industrial white enamel paint to prevent arcing, it is very important that the oven be removed from service until the situation is rectified otherwise there is a danger of shorting out the magnetron.
Feb 22, 2011 | Whirlpool GH5184XPQ Microwave Oven
My thermador mbbs needs to be replaced, but is part of the 3 in one built in wall unit. Does anyone have any new or recent advice on the closest match?? Help! Our $50 micro at our office is 8 yrs old and...
How old is the wall unit? Sometimes it may be easier to repair than to find a replacement, and microwaves are fairly easy to fix.
Let me know if you want to diagnose what could be wrong and repair.
Dec 17, 2009 | Thermador MBBS Microwave Oven
Interior Microwave doesnt come on..Burned out?
If it doesn't have a door you have to remove the cover. Its likely a special microwave bulb and the socket will have to be replaced with the bulb. the bulb is built onto the socket.
Jan 14, 2009 | Sharp R-1514 Microwave Oven
My sharp microwave oven sparks and pops when in use.
1. You have to clean m/w inside from all kind of grease and food resedue.
2. Inspected m/w cavity inside and clean all burning spots with sand paper.
3.Apply touch paint on this spots.
Different color touch paint you can buy at any appliance patrs store.
Dec 01, 2008 | Sharp Microwave Ovens
Jul 19, 2008 | Whirlpool MH6130XEB/Q Microwave Oven
Microwave
A microwave needs all those surfaces to be fully reflective. those scorch marks greatly affect the magnetron. it will soon burn out . reccommend a new microwave.
Feb 17, 2008 | Microwave Ovens
Microwave Ovens Logo
844 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
