Question about Panasonic Heating & Cooling
Cw-xc118hu don't start when turned on - Panasonic Heating & Cooling
How do u set the darb screws on a mac cat 839 chainsaw
Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H jet needle CW until the engine starts to speed up. Correct adjustment is when the engine 4-strokes at speed unloaded, but 2-strokes immediately when cutting. Release the throttle and adjust the L jet screw CW for better idle, yet allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the engine continues to run, but the chain doesn't try to turn. Hope this helps!
Nov 05, 2010 | Garden
How to adjust carby settings after rebuilding. McCulloch Eager Be
Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting that should allow the engine to start and run. Start the engine and allow to warm up, then pull throttle full on. Adjust H needle CW until the engine starts to speed up, but continues to 4-stroke. Proper setting is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Aug 01, 2010 | McCulloch Garden
I need to know the high and low settings on husqvarna35
Turn both jet needles CW to stops (lightly), then turn each screw out CCW 1-1/2 turns. This is a basic setting which should allow the engine to start and run. Start the engine and allow to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, but still allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain stops turning, but the engine will continue to idle. Hope this helps!
Jul 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Adjusting the idle jets on a homelite super 2
'L' is the idle jet screw and 'H' is the full throttle screw. Make sure the air cleaner is not clogged. Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. Start the engine and allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed up, but still 4 stroking. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine keeps running. Hope this helps!
Jun 03, 2010 | Garden
Carb adjustments/ rule of thumb
Assuming that the adjustment screws 'H' and 'L' have slotted heads, turn both CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed-up, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed so that the chain stops turning, but the engine keeps running.
May 21, 2010 | Husqvarna Chain Saw 20" Bar
Hard to start, and wont idle long.
Check the air cleaner and muffler for plugging first. Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. Turn the idle speed screw CW about 1/2 turn. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on and adjust the H needle CW til the engine speeds up somewhat, but is still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and allow to idle. Turn the L needle CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops moving, but still allows the engine to keep running. Hope this helps!
May 10, 2010 | Garden
Carburator adjustment for Homelite xl 12 chain saw
Turn both screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This should get the engine running if it will. If it does not, check the lower diaphragm on the carburetor for hardness or cracking. You appear to be running on prime only--the carburetor doesn't seem to be pumping in fresh fuel. You may need to do a carburetor clean and re-kit. Check the fuel line condition and the fuel filter in the tank for plugging. Make sure the muffler and air cleaner are not plugged. Once you get the engine to continue running, warm the engine up. Open the throttle and adjust the H needle CW--the engine should start to speed up, but still 4-stroking. The proper setting is 4-stroking, but immediately 2-stroke when cutting. Release the throttle and adjust L needle CW so that the engine runs fairly smoothly, yet will allow the engine to 'follow the throttle'. Set idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Apr 17, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Can't locate driver cw 50
direct link for the driver is : http://ftp.casio.co.jp/pub/EZ-USB/download/en/CWup303W.exe click on it or paste it to ur browser then the download will start.
its the same driver for stated below CW-50/CW-75/CW-E60/CW-K85/CW-L300
Feb 18, 2010 | Casio CW 50 Thermal Printer
I own a McCullogh 610 Pro mac chain saw. Why does
Check the muffler to make sure that the spark arrestor screen is not plugged. Make sure the air cleaner is clean and not plugged. Turn both L and H mixture screws CW to stops (lightly), then back out 1-1/2 turns each. Warm up the engine, then open the throttle and turn the H needle CW until the engine speeds up, but still '4-stroking' but should immediately start '2-stroking' with light cutting. Release the throttle and adjust the L needle CW for fairly smooth idle, yet rich enough to allow the engine to 'follow the throttle' immediately when accelerated. Adjust idle speed CW until the chain starts to turn, then back off until it quits turning. Make sure the chain is being properly oiled and is adjusted for no chain droop, yet turns freely by hand. Hope this helps!
Dec 27, 2009 | Garden
When u start saw and start cutting saw dies down act like its flooding out
I think you are saying it starts and runs fine but bogs down when making a cut. If true turn the mixture screw marked "H" CCW ¼ turn and try it in a cut. Better? If not turn it CW 3/8 turn and try again. Careful CW is leaner; to lean will ruin your piston and cylinder. HTH
Lou
Dec 04, 2009 | Husqvarna Garden
Heating & Cooling Logo
51 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
