Question about Philips 50PF7321D 50 in. Plasma HDTV
My tv won't turn on red light keeps blinking
Green light would come on but won't only red
  • 88 Answers
I am suspecting some slow and swelled capacitors in the power supply board. If you are technical ,I can guide you fix yourself. A shop should be able to fix for less than $200,if they can repair this board
Posted on Jun 02, 2010
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
praky16
  • 744 Answers
SOURCE: sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Posted on Apr 10, 2009
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
  • 92 Answers
SOURCE: green light turns red and red light blinks 4 times
Replace the Main Power Supply inside the TV.
Posted on Sep 07, 2009
dsacco86
  • 1077 Answers
SOURCE: red light blinking, tv doesn't start
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Posted on Sep 09, 2009
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
Tv won't turn on the green and red light keep flashing
tried to check first the power supply if no any sign of bulging electrolytic capacitor this was a common that we encountered trouble.
Jul 18, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Samsung 56" Model HL56A650C1FXZA will
Mine is doing the same... anyone find a solution?
Jul 05, 2011 | Samsung HL56A650 56 in. TV
Red/green light keeps blinking.
This issue is related to a bad/failed power supply inside your TV.
Call LG to see if your TV is still in warranty. 800-243-0000
If not in warranty, the power supply is about $225.
Good luck. I do hope that I have helped you.
Jun 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Philips 50PF7321D 50 in. Plasma HDTV Logo
246 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
