Question about HP Compaq Presario SR2030NX PC Desktop
Compaq presario sr2030nx won't boot. The fan
Compaq presario sr2030nx won't boot. The fan comes on with Green power light, but that is it. Sometimes if I leave it unpluged and plug in a few hours later it will come up. The problem seems to happen every few days. Today I can't get it to come back up at all though.
  • HP Master
  • 5,660 Answers
Bad Power Supply.
Weak Voltage power rail.
I'm going to explain what is wrong, and why.
Power Supply's are rated in Wattage.
The Power Supply used in a Compaq Presario SR2030NX desktop computer, is a 300 Watt unit.
(ATX style)
1) ALL the lights use Less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor uses 51 to 125 watts. Depends on what Processor it is.
The Compaq Presario SR2030NX uses an AMD Athlon 64 X2 3800+, processor,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00754206&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3245050
The AMD Athlon 64 X2 3800+ processor can use Up To 89 Watts, (Windsor Core)
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_processors#.22Windsor.22_.28F2_.26_F3.2C_90_nm.29
(HP Support lists the Processor as an Athlon 64 (O) 3800+.
The (O) should be an X2)
This means your bad Power Supply has enough power to light lights, and spin fans, but not enough to turn the Processor on.
No Processor running, No computer.
Bad Voltage power rail.
Inside the Power Supply are Electrolytic Capacitors.
Electrolytic Capacitors can break down.
The capacitors are used as Filters.
They filter the incoming AC electricity (Input Stage), and the outgoing DC electricity made by the Power Supply. (Output Stage)
http://en.wikipedia.org/wiki/Switched-mode_power_supply
(Observe the photo to the upper right of the page. The photo can be enlarged by left-clicking on it. It can be enlarged twice)
Electrolytic Capacitor simplified construction:
The Electrolytic Capacitors used in the Power Supply, (And on the motherboard), of a Compaq Presario SR2030NX, are Aluminum Electrolytic Capacitors, which are of the Radial design.
http://en.wikipedia.org/wiki/Electrolytic_capacitor
Observe the two photos of capacitors, shown at the upper right of the page.
The Electrolytic Capacitor example shown at the bottom, of the bottom photo, is the Radial design.
(Short blue capacitor)
The case of the capacitor is an Aluminum 'can'.
Inside the aluminum can are three strips.
1) One strip is an aluminum foil, and is the Conducting strip.
2) One strip is an aluminum foil, and has a non-conducting medium applied to it.
This is the Non-Conducting strip.
3) The last strip is a paper-like medium, and is soaked with Electrolytic paste.
The paper strip soaked with Electrolytic paste, is placed in-between the Conducting, and Non-Conducting strips, and all three strips are rolled up tightly.
(The Positive lead of the capacitor is attached to the Conducting strip. The Negative lead is attached to the Non-Conducting strip)
When a capacitor breaks down the paste inside develops a gas. (Hydrogen gas)
This gas expands inside the case of the capacitor (Can)
At the bottom of the 'Can' is a seal. It is a synthetic rubber like material, and is shaped like a flat disk.
The top of the 'Can' has a shape etched part way into it.
The shape is commonly an X, or K.
When the gas expands, and develops enough pressure, either the seal at the bottom is compromised, And/Or the etched shape breaks open, to relieve the pressure.
The Electrolytic paste is pushed out.
So much paste loss, and the capacitor operates at a weakened state.
To much paste loss, and the capacitor fails.
A Capacitor as a electronic component that slowly develops a charge, then releases it all at once.
You may compare it to a large swimming pool being filled up by a garden hose, then one wall of the swimming pool is taken down all at once.
This is why the Power Supply worked when you unplugged it for a while, then plugged it back in.
The weakened capacitors paste chemical composition, allowed the capacitor/s to revert back to a working stage once power was removed.
(Power Supply unplugged from power)
When you plugged the Power Supply back into power, the capacitor/s were working again.
Worked with so much paste loss.
Eventually enough paste was pushed out, and the capacitor/s have failed.
What causes Power Supply failure?
1) The inside of the computer is dirty, as well as the inside of the Power Supply.
The cooling components of Power Supply is it's fan, and Heatsink's located inside the Power Supply.
[Refer back to the photo of the open Power Supply, in the SMPS link]
(A Heatsink is a component, that draws heat away from another component.
Typically, a Heatsink is composed of a flat metal plate, that has tall, thin fins protruding from it.
Heat is absorbed into the flat metal plate, whereby it is absorbed into the tall, thin fins.
The fins radiate the heat away.
When a fan is used in conjunction with a Heatsink, the air produced by the fan goes in-between, and around the fins, and helps carry heat away)
When the fan's blades, center hub, and surrounding cage are dirty, and the Heatsink/s are dirty, the cooling capacity drops tremendously.
Again, Heat = Wasted Energy.
The Power Supply tries to keep up with the call for power, and eventually components inside the Power Supply fail.
Electrolytic Capacitors are the weakest link, and typically fail first.
2) The computer manufacturer used a cheap quality Power Supply.
Cheap quality components used inside the Power Supply.
If you wish I can guide you in testing the Power Supply.
You'll need an inexpensive multimeter, or an inexpensive power supply tester.
(One example of an inexpensive power supply tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471 )
Or if you have a KNOWN to be good, compatible power supply, you can use it for a test unit.
Need help in finding a replacement Power Supply, or information in how to replace it, simply state so in a Comment.
Posted on Jun 02, 2010
  • 600 Answers
First remove power cable, open up the casing and look for he memory module, it is a stick like with ic's on ti, push it in with light pressure, then check also the video card, it is where the cable to the monitor or lcd is attached, with the same pressure push it a bit, if it doesnt work maybe both of them and/or the processor or the power supply might have been damaged, have it checked by a repair center if your not sure about it.
Laptop won't boot, power light comes on for a few seconds
take the battery out of the laptop and try it again with just the power supply. If it boots up its your battery. if it does nothing replace charger.
Apr 29, 2012 | Compaq Presario CQ61 Series Laptop Charger...
My Compaq presario sr 1738nx desk top won't turn on at all. no blinking lights no fans nothing. if I unplug and re-plug back in the green light comes on for a second and thats it. nothing. ive swi
Sounds like the power supply has failed. That's where you plug the power wire into it. You could try opening the case and re-seating the main plug connector on the mother board. This is the big bunch of wires that ends in a 24 pin plug attached to the main board.
(See if you can borrow a power supply from a handy family member?) http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Jan 20, 2012 | HP Compaq Presario SR1738nx-b Desktop...
Compaq presario sr2020nx will not turn on
Just check the power suply behind computer case , or check your cable power.
May 24, 2010 | HP Compaq Presario SR2020NX PC Desktop
Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
Feb 12, 2010 | HP Compaq Presario SR2010NX PC Desktop
Compaq presario sr2030nx desktop-no beeps no video
This sounds like a problem on the motherboard. This can be determined quickly buy most technicians. Be certain you are using a good voltage regulator. This is common problem if there are voltage spikes. Happened to me.
Dec 16, 2009 | HP Compaq Presario SR2030NX PC Desktop
Computer Power comes on, shows compaq first screen, then everything stops. press esc, F10 or F12 and nothing happens. just continues to show the compaq screen. Any suggestions?
Try unplugging everything you can from the computer. Only leave keyboard, monitor, and power cables connected. Then try to turn on again. If computer boots now, then start adding peripherals back one at a time, rebooting each time. when you get the hang, there is your suspect peripheral.
Also, is the monitor itself having issues, or is it the computer? Look at the power light on the monitor, is it staying green, or is turning back to same color when it is in standby state?
Oct 02, 2009 | HP Compaq Presario SR1420nx...
My tower has power but won't come on
first guess is the motherboard is bad
a few things you can try:
unhook the monitor from the computer and test it on another computer. If the monitor works then its most likely the motherboard.
leave the computer unplugged for a few hours then plug it back up and give it another try just in case it overheated.
have the computers power supply tested as a bad power supply can cause all sorts of issues.
other than that you are down to a new motherboard and or a new computer.
Sep 09, 2009 | Compaq Computers & Internet
Compaq Presario F700 wont boot. Powers up then turns off again a
that means you might have a hardware failure. possible powersupply. check with local shop.
Jun 17, 2009 | HP Compaq Presario F730US Notebook
HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-43507-1&lc=en&dlc=en&cc=ca&lang=en&os=228&product=1841849 and restart the computer .
Apr 15, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Compaq Presario 900 Series PP2140 Power Up
Leave the battery out and try booting up on ac power only.
Jan 21, 2008 | Compaq Presario 900 /1500 Series EVO...
HP Compaq Presario SR2030NX  PC Desktop Logo
698 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
