Question about Acer AOpen AX 5TC (91.87810.202) Motherboard
To assemble acer motherboard 48.37P01.011 - Acer AOpen AX 5TC (91.87810.202) Motherboard
What is the slot next to the ram slots on a acer aspire 7552g motherboard
Wireless Module. Also known as Wireless Card.
http://www.insidemylaptop.com/disassemble-acer-aspire-7551g-laptop/
Scroll down, look at the photo in Step 12.
Now look at the photo in Step 16.
http://www.batterysupport.com/acer-aspire-7551g-5407-card-p-331342.html
Two cables (Wires) connect to the Wireless module, go through the body of the laptop, up into the Display Assembly, and to a wireless antenna.
Regards,
joecoolvette
Oct 19, 2012 | Acer mb.pt901.001 - Aspire 7551 Laptop...
Acer aspire L100
What kind of cable is it? does it have 4 wires? or? how many?
Oct 08, 2008 | Acer Aspire L100 PC Desktop
How to find drivers for my motherboard
You can try this website for drivers http://www.driverguide.com/
it`s very helpful.Serial # should be on the desktop pc somewhere under it.
Jul 14, 2012 | Acer Veriton M460 Micro Tower Core 2 DUO...
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Acer aspire 1642 frozen mouse
    Connect an external USB mouse to get at least the cursor to work, then download the latest touch pad drivers from Acer's site
    Check that you have not disabled the mouse pad (FN and F7?)
    If that fails, you may need to dismantle the laptop and check the small ribbon cable that connects the touch pad to the motherboard has not come adrift.
    After that it looks like physical failure of the trackpad / touch pad assembly
    Jul 18, 2011 | Acer Aspire 1642ZWLMi Notebook
    Acer Aspire 7720Z PC Notebook Cmos battery location ???
    You can obtain it at this web page free make sure you have a .PDF program like Adobe reader it is free at adobe.com to open it Click Here go to the bottom of the page and put in the code and then download it. Read the instructions check to make sure this is your lap top as well. If you cannot get the copy for some reason you can get a manual at acer web site.
    Jan 22, 2011 | Acer Aspire 7720 Notebook
    I have a acer 3680 where is the motherboard on that is in the front right coner of comp
    the motherboard is approximately 60% of all the space under the keyboard and top cover assembly. Only the battery, hard drive and cd/dvd drive make up approx. the rest.
    I believe this is the question you were asking.
    Jan 09, 2010 | Acer Aspire 3680 Laptop
    Password bios reset Acer extensa 5220 DipSW G39
    if ur taking of how to change the bios password...den goto bios setup and reset it...if u have forget the bios password....only by removing the c-mos battery and inserting it again the bios password can b reset..
    May 23, 2009 | Acer Extensa 5620 Notebook PC
    Mass assembling computers using power screwdrivers. What torque?
    Ive personally never used power tools to attach the motherboard to the mounts, but you will want to use the lowest possible torque settings as to not crack the motherboard. The screws need to be snug nothing more.
    Be careful as many problems can arise from doing this.
    Thank you for trying Fixya!
    Mar 27, 2009 | Acer (ACERMOTHERBOARD)
    Acer laptop manual
    that's on the motherboard by the way..and usually is a whole board replacement issue.
    Mar 09, 2008 | Acer Aspire 3000 Notebook
    Acer AOpen AX 5TC (91.87810.202) Motherboard Logo
    122 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
