Question about Maytag MAV6200 Top Load Washer
Machine was spinning, was out of balance, shutdown, distributed load evenly and went to restart and nothing is happening.
  • 159 Answers
Some where on the machine I do not know were because different model put them in all places. you will find a reset button this should be red press it and release it an machine should work again. Best of luck
Posted on Jun 02, 2010
Washing machine tub is banging into the side of the walls..what's the problem here
There are two possible causes for when a washing machine jumps and bangs on spin. Either the load is a bad one and unable to be balanced, or a fault is preventing the machine from balancing the load (or causing the motor to surge into spin when it shouldn't). This causes the laundry to be flung around inside. The occasional jumping around may not be anything to worry about, but regular or severe occurrences should be a cause for concern and can cause expensive damage to your washing machine if ignored.
Both these faults are less common these days because manufacturers have built in certain protections, but it's still something that can happen. To differentiate between the two, observe when the problem occurs, if it's during a wash cycle, maybe at random parts of the programme, it may have a fault which really needs an engineer to diagnose as these faults can be intermittent and tricky to diagnose. If it happens when it kicks into the fast spin the chances are it's related to the load inside.
Am I overloading my washing machine?
By out of balance I mean when the washer jumps or bangs quite violently. If the washer is just rocking about on most spins make sure it's on a level floor and that it is properly level.
If a load is out of balance you can often observe the inner drum swaying about or even thumping the sides of the casing a few times whilst it's trying to distribute the load prior to fast spin. Before a proper spin the drum should revolve slowly for a couple of minutes. This is called "distribute" and at this stage you may see large flashes of metal drum on each revolution where all the laundry has settled around the drum but there wasn't enough to cover all of it. If this happens the drum will be out of balance and either refuse to spin, or if allowed to spin may cause the drum to thump around and hit the sides of the casing.
The best way to avoid unbalanced loads in a washing machine
If you try to wash a bulky, heavy and absorbent item, the washing machine is unlikely to be able to get it to balance inside the drum. Or if you put just a few large towels or a heavy item in amongst some very light fabrics the heavy items could bunch to one side of the drum and the lighter ones won't be able to counter-balance their weight effectively. There should be enough items to fit all around the drum. If there's only enough to fill most of the drum, but a section is empty, then it can get out of balance on spin. If the items are all light, then this may not cause a problem. However, if some items are heavy, they may cause violent banging, or the washing machine out of balance detection may just refuse to allow a spin.
Make sure you fill the drum well. Counter to expectations, the worst violent spins are caused by under-loading - not overloading. Heavy bath mats are notoriously difficult to balance and should ideally be washed with other items or they may gather on one side of the drum. However, some people (understandably) don't want to mix the bath mats in with normal washing. If this is the case and you do get problems with the bath mats getting out of balance I suggest you use old towels or sheets to even the load up. With most modern machines though, a heavy bath mat is more likely to just not get spun rather than be allowed to spin out of control and wreck the machine.
Sometimes you can get an unbalanced load by sheer chance, with loads you have successfully washed many times before. The occasional bad load is inevitable but constant bad loads and violent banging on spin should be looked into. [ Related: loading the washing machine properly ].
Modern washers have built in out of balance protection
Most modern washing machines now electronically monitor the motor during the slow distribution section leading up to the spin. If the load is out of balance, the motor shouldn't be allowed to spin. Typically, a modern washing machine will attempt to balance the load a certain amount of times, or for a certain passage of time, but if it can't, it will either reach the end of the program without spinning, or it will abort spin and turn off. (both scenarios leaving the clothes wet through). Some washing machines may allow a slow spin if the clothes are reasonably balanced, but then unless they settle down, it will not allow a higher spin thus leaving the clothes spun, but much wetter than normal.
Some will indicate a failed spin due to being unable to balance the wash load so check your instruction book to see if your washing machine has this function and what happens if a spin is aborted. Unfortunately some washing machines do not adequately inform the user that it failed to balance the wash load and aborted spin. As an engineer, I have been called out many times because a load was washed but not spun, but there was no fault on the washing machine, just an aborted unbalanced load.
Extra large drums make balancing loads harder
These days you can buy washing machines with much bigger drums. The average drum size was at one time a mere 4.5Kg but is now 6Kg. You can buy washing machines with 7Kg, 8Kg and even 10Kg drums.
These washing machines can be more prone to refusing to spin some small loads because they need even more items to fill the drum. For example, my 7Kg washing machine will not spin 3 large towels. Last week my wife was extremely frustrated with our 7Kg drum washing machine as she had just washed our son's hoody-top and wanted to spin it in the washer. It simply would not spin, so I advised her that it needed something to balance it out. She put in a couple of towels but still no spin. Eventually 5 towels were needed to balance out the absorbent top and allow a spin. This is a minor inconvenience compared to the benefit of being able to fit more washing in (even our king sized quilt) but it highlights how if you have a very large drum it could be more prone to not spinning small loads [ Washing machine won't spin just one item or very small loads ].
I'm loading the washing machine correctly but it still bangs and jumps on spin
This is unfortunately a difficult fault to diagnose. It could be various things including a faulty connection somewhere on the motor or pcb, especially if intermittent. It can be caused by a part overheating, cutting out and then cutting back in causing loss of control. If this fault isn't caused by the loading you really need to get an experienced engineer to look at it. Find a washing machine repairer on Washerhelp
If a brand new washing machine is jumping around on spin
Make sure you have removed all of the transit packaging before using a new washing machine. The transit packaging stops the suspension from working so without the tub being able to bounce up and down on the suspension all the movement created on spin will be translated to side to side movement and the washer will move about and shake.
Loading washing machine White Goods Help washing machine jumps and bangs on spin Washing machine won spin just one item Book washing machine repair
Aug 02, 2015 | Washing Machines
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
Why does my kemore elite always get out of balance when spinning worst with a light load
When Loading, Always Distribute Clothes Evenly (weight wise) With A Light Load Usually Clothes Will Become On One Side Before End Of Wash Cycle--If You Look Before Spin Cycle And This Had Happened, Redistribute and restart from present position (cycle wise)
Feb 28, 2015 | Kenmore 24032\24036 Top Load Washer
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Regards
Phillip
Oct 06, 2014 | Samsung SW62ASP Top Load Washer
Banging drum when spinning
if the drum in the washer klunks/bangs in ANY brand of washer when it is spinning, your load is off balance. stop the machine, re-distribute the wet clothes so that the weight is evenly distributed, then restar the spin. u may have to do this more than once if u did not evely distribute the weight. this is an easy one. just be sure to stop the spin soon as it starts banging. letting it bang thru an entire spin cycle could result in actual damage to the machine. some of the new machines auto shut off at an imbalance so u can correct the problem. think of spinning a top. u unevenly add weights to it then spin it again, it WILL wobble.
Feb 22, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
My washer is leval but continues to display ul code when spin cycle starts
UL does not mean the washing machine unit itself is unlevel, it means the load cannot be balance, possibly washing too small a load that the machine cannot distribute in drum evenly ( happens alot when only one or two items being washed), could be poor pump out (check filters if accessible) the machine tries to start spin with excess water or maybe it is a mixed load, lots of small items and maybe one or two large items that hinder the distribution. My machine is very temperamental when I do the sheets, because they get tangled during the wash part of the cycle and then the machine cannot get them balanced to spin. I sometime have to manual move the item about and then put it to the spin only cycle.Hope this helps
Oct 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Help my whirlpool AWM5145 washing machine is not spinning
these machines have an imbalance sensor on the machine and will not spin if load cannot be evenly distributed around the outside of the drum when the machine tries to go into a spin cycle. it will try to balance the load 3 time after which it will give up so as not to cause damage to the machine.
If this isn't the cause then you may need to replace the carbon brushes or even the motor itself
Apr 14, 2010 | Whirlpool AWM5145/2 Front Load Washer
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
My washing maching machine is very noisy and sounds like it is banging on a spin cycle. wot is it? it is ok when empty
Usually caused by the drum being out-of -balance. Can be the result of poor distribution of the clothes or too light a load in the machine. Before the spin cycle starts, the drum usually rotates clockwise and anticlockwise to distribute the load evenly.
If the above is not causing the problem, it may be due to the concrete damping block ( present on most washing machines) becoming loose. This sometimes happens after a period of use, and can be easily corrected by tightening up the retaining bollts.
Finally the bearings could be worn. Repairs could be expensive if this is the case.
Before investigating anything inside the machine MAKE SURE IT IS DISCONNECTED FROM THE MAINS SUPPLY!
May 02, 2008 | Washing Machines
My Whirlpool washer Ultimate Care II spins out of controle
Hi Geny, I can relate to your problem. Same thing happened to me. The morons who installed my washer didn't give a hoot about making sure it's properly balanced. I learned the hard way and figured it out myself. Balancing is very simple. Make sure the floor isn't slippery. Then check the nuts on the front feet that they're tightened while checking they're both evenly in height. They're adjustable. Third, lift the rear of the machine up about 4" from the floor and lower it so the rear feet can automatically set themselves. Also, a leveler can help. THis should take care of basic balance problems. Good luck!
Jun 09, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
