Question about Electrical Supplies
Ok i am running a hydro-vac excavation truck and we are required to have a dead-man switch on our water hose to kil the flow of water if the wand slips out of grasp etc. we have been buying these cheap motorbike/dirtbike/sled killswitches and they never last more than 2 weeks, this is my thought: would it be possible to wear a battery operated remote transmitter on the users wrist that would send a wireless signal to a reciever in the truck to shut the water pump off if the wristlet came outside a perimeter of lets say 2-3 feet of a magnet or other simple device we could mount on the wand?
  • 760 Answers
If you were to use something like this for personnel safety it sould be approved for the use There are approved radio systems to remote control cranes and even train engines. Anything for safety would be redundent operation and would be very expensive. Try buying a kill switch asembly from a jet ski. They should be waterproof.
Posted on Jun 30, 2010
Low water pressure from wand
The pressure in a watering wand extension to a garden hose is related to the water pressure from the hose itself.
The point of a watering wand is to provide a gentle and widespread flow of water. If you are looking for a powerful stream, then a different type of attachment is required.
Check to make sure that there is no leaking at the faucet, or at any connecting point. Leaks will lower water pressure at the end point.
Check to be sure the wand itself is free of dirts and clogs. If the wand is dirty or blocked, it will affect the pressure.
If there are several hoses hooked together, the water pressure is more likely to be low at the last point, the wand itself.
When the water pressure drops as a result of another use, like a shower, dishwasher, another hose faucet, then the water pressure will drop in the wand.
Aug 06, 2017 | Water Garden
Pressure washer stalls out when wand nozzle is released
Remove the hose and run the machine. If the machine works and the flow of water is ok. Start checking the hose for a restriction and trigger. Make sure this is correct before you start taking the pump to bits
Feb 23, 2016 | Simpson WS4050V Water Shotgun 4000 Psi...
How do i know if the control unit is bad on an aquastar 1600H
That voltage does not seem high enough. Supposed to be 1.6 VAC and I got 2.5 VAC. Do you have the water flow turned to the maximum? Is there something blocking water flow? The hydro voltage should be checked separetly from everything else, so if you can't get the VAC higher, my guess would be that's the problem.
Nov 19, 2014 | Bosch 1600H-NG Natural Gas AquaStar...
My steam cleaner wont pick up water i have checked everything and its fine but still isnt sucking up water
Well Sexy mama ..are there any on~board screens that require clearing? Pet hair clogging up vac wand end? Is there vacuum power for attachment hose? Also, check that the wand /attachment switch is to vacuum and not set for attachments. Good luck !
Apr 30, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
KOHLER HYDRO 13 When pressure washer engine is
first sheck the inlet screen where the garden hose attaches,if there is water flow then see if it has a manual pressure regulator, this will be a knurreled knob somewhere on the intake manifold of the pump, ifyou have one, turn it clockwise and see if there is a difference. If still no luck, disconnect the high pressure hose from the pump, start it and see if warer flows at that point, Your gun may be clogged or your hose may be delaminating on the inside and need to be replaced. If all this fails I suggest you bring it to an expert. These pumps can require special tools and expertise to repair internally
Nov 08, 2009 | Karcher 2500 PSI Pressure Washer
Hoover steam vac..F7452-900. not working in wash-auto rinse mode
This problem sound like you hav a problem with the pump. I would take it to a shop for service
Sep 26, 2009 | Hoover F7452-900 SteamVac Upright Vacuum
Campbell Hausfeld PW1380 Pump won't run when water hose is connec
http://www.ppe-pressure-washer-parts.com/campbell-hausfeld-pw138000-pressure-washer-parts
Hope this helps. I have the same problem. It's not the switch but the mechanism that slides inside the switch, which activates the switch to go on and off. I fnally found it so hopefully they have the part in stock. It's not a clogged wand trust me I have torn it completley apart and found out it is the mechanism in the switch is plastic and breaks.
May 19, 2009 | Campbell Hausfeld 1,350 Psi Electric...
1986 buick lasabre heater fan workes, but no heat at all
could be a vacuum switch on the heater hose. The heater hoses are the small hoses ( 1inch, usually black or red) that run from the motor to the inside of the car. They should be warm when the car is up to temperature.
The vac switch controls the water flow to the heater core. If the vac valve is bad or the vac line that feeds it is bad it will not allow water to enter the heater core.
Could be a plugged heater core too.
Check the water level in the radiator as well. If the engine is low on water often the first to go is the heater.
Dec 20, 2008 | 1986 Buick LeSabre
Blinking red water light on SAECO ITALIA with full tank of water
Your tank may be full but water is not getting into the system. The only way for the red light to go away is to have water come out of the other end...either the coffee spouts or the steam wand. The word they use for this is "pump priming". Thus, either the motor is not sucking water in or there is blockage. Unless water gets out to the other side, the red light will stay on. Before getting dirty with the system, check the tip of the steam wand...if old milk is blocking that end. You will know this is the case when you turn the steam knob counter clockwise to release water but you only hear a semi-startup on the motor and then abruptly stops while the steam knob simultaneously pops out a little bit. It indicates a "blowback"...that there is blockage at one end of the pipe (ie steam wand). Get the residue out by dipping the wand in a tall glass of hot water...wait for a few minutes and blow it out with using the steam knob. Should be ok after that.--Mabada1
Jun 26, 2008 | Saeco Easy Espresso Machine
Electrical Supplies Logo
104 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
