Question about Yard Machines Garden
Fuel line routing
I have a Yardmachine 21A-121R900 tiller that was given to me in a not running state. I have rebuilt the carb and got it running at this point, but it is difficult to start. I suspect, since I am not the first one to work on it, that the fuel line routing may not be correct and might be causing some of my starting problems. The engine is a 6MTDS.0314MR:EM and has a regular line to the carb from the tank and also a line to a starting primer. Any ideas where I can get info on this engine?
  • 97 Answers
SOURCE: routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Posted on Mar 21, 2009
  • 15 Answers
SOURCE: Tiller won't stay running
Hmmmm.....it sounds like restricted fuel flow to me, but explain "rebuilt the carb" so I can get an idea on what you did.
Though it sounds right off like you whooped it good and got the basics.
Right off, go back through the "system", check the fuel flow, check that spark on the plug. Eyeball for any loose wires (E.G., Kill Switch, etc.) that are grounding (you never know!)
Stick to KISS on this one, since it ran before the carb got bad and got rebuilt, it will be one of those things you replaced, rebuilt, or changed. Sometimes, it is the SMALLEST thing......
Posted on May 28, 2009
wadembly
  • 489 Answers
SOURCE: fuel lines on my cultivator corroded. I do not
ok you have two fuel lines coming in from tank the one that has the fuel filter atached inside should go to the top & the other is just the return line try that & let me know if it helps wade at wadembly@aol.com
Posted on Jun 06, 2009
moretons
  • 155 Answers
SOURCE: LOOKING FOR INFORMATION ON FUEL LINE ROUTING
most trimmer fuel lines run from line in tank with pick up filter to bottom of carby then out of top of carby to inlet on primer usually the smaller tube then out of the longer tube on the primer and back to the tank.
Posted on Jul 25, 2009
  • 52 Answers
SOURCE: String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Posted on Apr 19, 2010
Yard Machine Model 21a-121r900 tiller's pull starter recoil pully slipping
Bend the ears on the flywheel so that they are 90degrees. They are not lining up right.
Feb 16, 2013 | Mtd Garden
21A-121R900 Won't stay running
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ~~
Feb 14, 2012 | Yard Machines Garden
I have a Yard Machrines by MTD Yard & Garden Cultivator 31cc: Model No.21A-121R900 Ser.No.1A246DG1150 and I need to replace the primer bulb. How do I do that?
hello l, how to change primmer bulb,,remove the two fuel lines making note which line came off where,use needle nose pliers to push the two ears down and pull bulb out,make note on where the long and short stem was at,go to the mower shop and get a new bulb and install,put lines back on, done start engine,,hope this helps,,
Jan 27, 2012 | Yard Machines Cultivator
21a-121r900 Yard machines tiller. Flywheel key part # or size????
You can download manuals here. Find your serial number also.
http://manuals.mtdproducts.com/mtd/Public.do?langId=-1&BrandCode=10451
Most motors have an soft woodruff key for flywheel,but this ond looks like it's splined, if it is the right model.
Aug 19, 2010 | Yard Machines Garden
2 stroke won't run not getting fuel
Clean the carb and make sure your fuel lines are in good condition.
Jul 18, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Where is the fuel pump on yardmachine rototiller Model # OHH60
THERE IS NONE ITS A GRAVITY FED CARB, THE CARB NEEDS TO BE CLEANED. IF YOU DO IT YOUR SELF TAKE PICTURES SO YOU CAN REASSEMBLE IT !! THE FLOAT IS STUCK. THATS WHY YOU ARE NOT GETTING GAS.. IF'N I WAS OF HELP PLEASE VOTE..JAY
May 25, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Fuel line routing yard machine 31cc cultivator 21A - 120R000
unit with primer bulb,,,,,line from gas tank with filter, goes to bottom of carb, from top of tank to suction side of primer bulb, from output of primer to tank return
Apr 29, 2010 | Yard Machines Cultivator
Only runs on starting fluid.
no fuel getting into carb pull apart and rebuild if water or fuel was left in lines than possible the float valve seat or fuel in line has a clog best is to let soak than blow out lines and use a wd40 or such little red tube and sruirt into the carb body to blow out and clean the nooks and crannies of the carb-- the well keeps fuel in and around fuel line for when u tilt or turn unit
Mar 13, 2010 | Craftsman Garden
Tiller wont get fuel to start
Try disconnecting the line at the carb. Then carefully blow back to the tank. It may have something blocking the outet from the tank. If that doesn't do the trick, the float may be stuck and not allowing the needle to open for fuel to enter the carb bowl. Good luck...Lee
Aug 05, 2009 | Yard Machines Tecumseh 148cc Front Tine...
Garden Logo
298 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
