Question about HP Photosmart C5180 All-In-One InkJet Printer
My HP C5180 All-In-One printer says full ink cartridge is empty
My HP C5180 All-In-One printer is reading that the black ink cartridge is empty just days after I replaced it.
    President:
  • 1,138 Answers
Hi!
There are two ways to make your cartridge work again.
The first one will be basic....turn on the printer...remove the black cartridge from the printer.. using a moisten cloth, clean gently the contact terminal of the cartridge..after letting it air dry for a couple of seconds return the cartridge.. then try printing again..
The second one is to reset the ink cartridge.. how?
1. While your printer is on.. disconnect the usb cable from the back of your printer.
2. Remove the cartridges.
3. Wait until the message "Insert Cartridge" display on the control panel.
4. Disconnect the power cord from the back of the printer.
5. Wait for 60 seconds.
6. Plug the power cord at the back of the printer...If printer does not automatically on..press the "Power" button.
7. Reinsert the cartridge and close any open doors of the printer.
8. If prompted to Calibrate, do so..
9. Reconnect the usb at back of the printer...and try printing again..
After that you can print easily.
If you find this information helpful....Please rate this solution and vote on this on the YES below..thanks..
Posted on Jun 02, 2010
I just replaced the yellow ink cartridge but it
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jul 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
Windows Ink Cartridge Empty false error message.
Oct 28, 2009 | HP C6280 All-in-One Printer
I have a printer HP c5180 all in one, only have black ink , not color, i dont want print in color . can I use the printer black and white (not color) only?
You can go into the print properties and set it to print black only, however if any of the color cartridges are empty the printer may not print until you replace whichever cartridge is empty.
Aug 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
Same problem with the black ink.
I have the same problem; have spent hours and days on this...no help from HP; they sent me to a web site for cleaning and the pictures did not even look like the C5180. Am ready to toss and go by a Canon.....
Aug 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
How can I print black only color cartridges are empty black is full . this is for HP photosmart C5180 all in one printer
sir when you chose the print option please select the settings button there in the color tab you can find this option that print with only black ink
alternative solution is that before you print please open the flap of the printer where the heads are and remove the color cartridge.. then print it will give you a warning saying that printing in reserve mode but ignore this warnings
Thnx and i hope this solves your problem
Jul 16, 2009 | HP Photosmart C5180 All-In-One InkJet...
Will not scan because ink empty I want to scan only
remove the ink cartridges. try it now, should work if not, reinstall the cartridges don't do a print alignment. Go directly to scanning, printer should think the ink is full again.
Jun 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
MyHP Photosmart C5180 has stopped printing colors and all ink is
v:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}w:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Solution
Complete the following steps to resolve this issue.
Step one: Check the printin grayscale setting
If the self test page printed in color, the ink cartridgesare okay, and the ink levels are well above empty, the printer software hasprobably been set to print in grayscale. Follow the steps below to check thissetting:
  1. In the software application you are trying to print from, click File, then Print. The Print dialog opens.
  2. Make sure your printer is selected, then click Preferences. The printer Preferences dialog opens.
  3. Select the Color tab, then make sure that Print in grayscale is not selected.
  4. Try the print job again to see if this step resolved the issue.
    • If the issue is resolved, you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved, continue to the next step.
Step two: Check the inkcartridges
NOTE:- HP cannot guarantee the quality or reliability of non-HPink.
  1. Check the ink cartridges to determine if they have been refilled. If they have been refilled, try replacing them with genuine HP ink cartridges.
  2. Try the print job again to see if this step resolved the issue. If the issue is not resolved, continue to the next step.
Step three: Check inklevels
Replace any empty print cartridges.
  1. Press Setup .
  2. Press clip_image001.gifto select Tools , then press OK .
  3. Select Display Ink Gauge and press OK . The ink levels are displayed.
Figure 1: Ink levels
    • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
    • If an icon is empty, the corresponding cartridge may need to be replaced soon.
    • The ink levels in non-HP, refilled, and remanufactured cartridges cannot be read by the printer. Instead of an icon, a question mark is displayed for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
  1. Try the print job again to see if this step resolved the issue. If the issue is not resolved , continue to the next step.
Step four: Service theproduct
If you have completed all the steps listed above and arestill experiencing a problem, service the product.
Nov 23, 2008 | HP Photosmart C5180 All-In-One InkJet...
How can I print Black only?
Hi
HP Inkjet printers work only if both the cartridges have ink unlike HP Laserjet printers.
If you want the printer to print only in black, Follow the steps
Start --->Control panel -- >Printers and faxes ---->Right click on the printer icon (HP c5100) select printing preferences.
Under printing prefences there u will see an option to print with black or print in gray scale.
Note:HP Inkjet printers like Photosmart C5180 will work only both the cartridges have ink.
Thanks
Riz
Jul 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
219 people viewed this question
Seeker5211
Seeker5211
