Question about Boating
How to change gearbox oil on a seabee tempest outboard motor the gearbox is on the leg made by ocean outboards of southport england what i want to do is drain it then ship it jamaica the gearbox oil is shell dentax 90 as recomended on the top which is a 4 stroke air cooled tacumse lawnmower motor the gearbox has FNR in aluminum casting but has no filler I have been looking for a workshop manual of the tempest but no luck any help would be appreciated regards peter
  • manxrover Jun 04, 2010
    this could be true the block says aspera motors liec to tecumseh on the block, as a tacumseh its a lav 35 still used in snapper lawnmowers
    may be seabee just made the bottom end and sold it as a tempest the bottom is black top white
    but there is no drain plug at the bottom and only two machine bolts above the gear box caseing 1 inch apart verticaly which is what made me think. may be your suppossed to screw in a grease nipple and pump waterprofgrease in till it comes out the top?
    could send photos
  • 59 Answers
These I think you will find were made in Yugoslavia by the Tomos company and sold under the "sea Bee " brand in the UK for some reason.
I may be stating the obvious here but usually outboard gearboxes have 2 plugs one top and one bottom. Take out both to drain the oil and then fill from the bottom hole forcing in the oil till it comes out of the top hole, then refit the top plug followed byt the bottom one.
Posted on Jun 03, 2010
Can I use high pressure gear oil in my outboard motor leg 80 / 90 with out damageing it?
none of this answered my question ! can I use high pressure gear oil in my in/out board mercury motor leg???
May 06, 2017 | Boating
Steering wheel wont move right or left engine wont move don't want to force it
inboard or outboard motor ??
unbolt the steering cable from the steering point of the engine or leg unit , then try turning the wheel and if it moves then try moving the engine or leg unit and see if it moves !?
Mar 27, 2015 | Boating
Coleman outboard overheating
You should change your impeller.
It is located at the top of the gearbox, around the vertical engine shaft.
First, disconnect the gear control. Underneath the steering bracket, you'll see a long nut with a counternut. ( Maybe you'll have to shift FWD or BWD to get better access ). Loosen the counternut 1/4 turn and then turn the long nut up ( 2 open box wrenches 10mm ).
Then remove the 4 bolts holding from lower to upper the gearcase ( just above the anti-cavitation plate )
The gearbox should drop down easily.
Then remove the 4 screws of the waterpump ( top of gearcase, around the long vertical shaft ). Lift the waterpupp housing, you'll get the impeller.
To reassemble the waterpump, grease the cup in the housing with PTFE or silicone grease, and while pushing the housing down over the impeller, rotate the shaft clockwise.
Reassemble all the rest in reverse order.
Check and adjust the gear shifting...
Apr 01, 2014 | Coleman 9.9 HP Manual Start Outboard Motor...
How to Change the impeller on Suzuki 140 outboard motor
Suzukis are normally a mission to work on especially if it is a two stroke,so I suggest you get a workshop manual.all gearbox bolts must be undone,the gear linkage is under the bottom carb,this is the tricky part,you have to loosen a nut at bottom of gear arm where gearcable fits,then push in with screw driver,this releases gear change shaft.the biggest problem is trying to see what you are doing.good luck
Oct 08, 2013 | Suzuki Outboards - Zinc 115-140Hp Outboa
Water pump
The water pump is a flexible impellor located in the top of the bottom section of the leg of the outboard. It is driven by the drive shaft to the prop that is spinning all the time the motor is running. You will find it behind or near the water inlet slots at the bottom of the leg
May 14, 2013 | Seloc Mercury Outboard Engine Repair...
Johnson 235HP Outboard - oil leaking from bottom leg - dark black so picking it is the two stroke oil
most 2 stroke motors will not burn all the oil in the mix and that unburned oil coats the exhaust leg and leaks out the thru hub exhaust and parting line of the lower to the housing. so keep some windex handy and clean it up.
Oct 09, 2012 | Clymer EvinrudeJohnson Outboard Shop...
Im looking for a workshop manual for a 1995 Honda 90 HP outboard motor any ideas Im working on the gearbox at present
We bought the Clymer Honda outboard shop manual (B757) which covers Honda 2-130 HP from 1979 to 1999.
It was $20 and worth every penny.
Hope this is helpful.
-Steve
Aug 03, 2012 | Light Outboard Motor Boat Bass Fishing...
What type of oil for a 90 horsepower 1998 engine for a boat?
The outboard leg/transom leg oil is most important, where the gears drive the propeller it will need a heavy oil like hypoid gear oil No. 90. If it is a four cycle motor which doesn't need to have oil mixed with the gas, the base of the motor will have an oil plug and dipstick, and most likely take a high performance oil which acts as a coolant as well as a lube oil, so keep it right on but not over the full mark to avoid deadly engine heat.
If it is a Two-cycle motor you will need a 2cycle oil to mix with the gas according to that engine's particular mix strength on the instructions. Some are automatic oilers - 2cycle injection so you just keep the 2cycle oil tank full. You need to find a sticker on the motor or brochure to get the right oil weight and weather it can take the new multi-weight synthetic oils or not. Also oil the cables and steering pivots and all joints after you take it out of salt water and do your routine flush-out for the leg coolant water system with a hose - the coolant pump in the leg is not rust proof at all, even for fresh water boating.
Jun 21, 2011 | Garden
Briggs and Stratton Outboard - There was a response to a previous question which suggested that it was possible to lock up the lower end of one of these outboards. I have a 5hp Briggs & Stratton...
drain the g/box and see what comes out.if its got water and oil mixed,Id try for a claim.being aircooled motors,there should be no problems for long time,no impellors,just a B
Sep 18, 2010 | Boating
Boating Logo
199 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
