My laptop turns off.it has a remaining 60% of battery. what is the problem and how to fix it?
    Master:
    Sergeant:
  • 383 Answers
Check the power settings find out what the battery level is before it turns off usaully in the power settings on your control panel
Posted on Jun 02, 2010
Why do the ac led remain lit when its unplugged and only the battery is in?
Use this small secret. Disconnect the power adapter from laptop+ battery too.
2) Press the power button for 60 seconds EXACTLY. with the adapter+battery disconnected from the battery.
3) The idea is to eliminate de ESD from power supply, that impede to laptop to work o.k from starting.
Try again.
Hoowever if the problem remain, problem can be there in the power supply inside from laptop. You must open and repair or call some tech computer. for fix it.
God bless you
Mar 05, 2013 | Toshiba Satellite Computers & Internet
My acer laptop screen won't turn on. The entire
It sounds like either your Lcd data cable loose or graphic card fried from excess heat. If you feel excess heat at the bottom of your laptop near the fan ventillation, then most probably it is graphic card. A chiplevel technician can repair your laptop. Don't try any repair if you are not a technician. Any repair without proper knowhow will kill your notebook for ever. Hope i helped you
Dec 01, 2012 | Computers & Internet
Set dead
Did you plug your AC adapter in and then try to turn it on? It may be that your battery ran out of power. Try to plug your AC adapter into your laptop, wait about 2 minutes for the battery to charge, then turn on your laptop. If that doesn't work, you may need to replace your battery. The battery on that laptop is fairly cheap, ranging in price from $10 used to $60 new. If that doesn't work, your power button may need to be fixed. You then need to have it fixed by a reputable computer repair store.
Hope that helps. Good luck!
Jun 27, 2012 | HP Computers & Internet
Laptop wouldn't get out of update stage and I was wondering how I can get out of it
Hi There,
Remove the power cable and battery from your laptop.
Hold the power button for 60 seconds.
Replace battery and power cable, and turn on.
That should fix the issue
Jun 07, 2012 | Acer Extensa 503T Notebook
My netbook will turn on and sound like it's booting for about five seconds then it just stops. The power light remains on but the screen doesn't come on at all.
Hi
Please remove the battery, hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON,
Please tell us your results
Good Luck
May 14, 2011 | Acer Aspire One Netbook
When you turn the laptop on it turns off with 30 - 60 secs.
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Acer Aspire 5735 Notebook
Display not working for HP pavilion dv2000
Try to attach your computer to an external monitor to see if it is a screen issue or a motherboard issue. If the computer does not pick up on the external right away, try to toggle it by holding down the Fn key and striking F4. If you get a picture on the external, then you have only lost the screen and the motherboard shouyld be fine.
Sep 20, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Compaq presario v3000 (v3322tu) turns on but appears dead
According to your question ,there is a problem with RAM of laptop ,bring it out again install it properly.
if it not work you to replace it with new one.
Apr 06, 2009 | HP Pavilion dv6000z Notebook
Monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
glenn
Mar 07, 2009 | Compaq Computers & Internet
Turned off automatically on 60% battery
i thing this is an option you can choose it to protect your phone , change this from the battry setting,
Nov 12, 2007 | i-mate JAM Pocket PC
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
