Question about Avaya 700340193 Corded Phone
Caller ID how can I check the last 10 calls made to my phone number?
  • 532 Answers
Firstly, goto menu.
secondly, goto log
lastly, goto to all call.it will show your your lastten calls.
Posted on Jun 02, 2010
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
How do you get the number of a previous call? I cannot figure that out. For example. Call comes in. Phone chat. THEN, afterwards, wanting to retrieve the number of person who called. Thank you very,...
You need to enable caller id in order to see the numbers of the people who are calling you. Caller id costs about $6.50 per month depending on which phone company you use. When you have it activated, and you want to see the number of the last person who called you press the down button on the dial in the center of your phone and it shows the last one. If you continue pressing the down button you can see all callers as long as they have not blocked their numbers.
Aug 16, 2011 | Uniden DECT 6.0 Cordless Telephone...
KX-T7730 HOW TO REDIAL 10 LAST NUMBER AND 10 LAST NUMBER WHO CALLED ME
If your system is a TA-824 or higher and you have Caller ID, you can set a button that will capture the CID of the last calls you have answered on your set. The feature is called Caller-ID Personal and it requires 2 left side buttons on the phone to be preprogrammed for that feature.
Label them CID-S and CID-I. I put them on buttons 11 and 12 (counting from bottom to top) in the S and I order. To do that, press PROGRAM the button and dial 7 STORE for Indicate and 6 STORE for Select. Now, when a call comes in, it will save under the buttons and you can view them with tie I and S buttons and the navigator up and down arrows.
Carl
Feb 27, 2011 | Panasonic KX-T7730 Corded Phone
How do i block my number on an outgoing phone call?
i found the answer at http://support.sprint.com/support/article/Block_your_Caller_ID_on_your_outgoing_calls/case-wh164052-20100907-100732?&INTNAV=SU:SP:HDIB
Last Updated: Sep 08, 2010You can block your Caller ID information (name and phone number) on a call-by-call basis. Just dial *67 before dialing the number you're calling, and your information will not show up on their Caller ID display.you can also go to http://support.sprint.com/support/article/Know_the_difference_between_restrict_and_block_on_Caller_ID/case-wh164052-20100907-101149?&INTNAV=SU:SP:HDILast Updated: Sep 08, 2010Restrict Caller ID is a restriction that is placed on your account to completely block your information (name and phone number) from being displayed on any call you make. This has to be done by contacting our Customer Care team.Block Caller ID is something you can do yourself directly on your phone by dialing *67 before the number you're calling. This only affects one call at a time, so you have to dial the code before every call you want to block your Caller ID.**************i did some research and found the answer, please provide me with FAIR feed back i.e. 3 or 4 thumbs up. according to sprints website and also htc support forum there is no way to block the caller id automatically. dont kill the messanger i just wanted to pass the info found on htc and through sprint.
Jan 07, 2011 | HTC Snap S522 Cell Phone
Memory
The phone can store upto 10 24 digit numbers with 15 character names this memory is in addition to the caller id memory which stores the last 40 caller id numbers.
Apr 03, 2009 | GE 25952EE1 Cordless Phone
Caller ID
battery weak change ur battery
Sep 23, 2008 | Astra Meridian 9417 Corded Phone
Long distance text message will not send. error code 00107. I would like know what that code number means. bat999@videotron.ca
The caller has caller ID block placed on their acct/ this can interfere with sending sms messages to a phone that does not accept sms or voice calls from a line with caller id block/ I had cust resprond to a text with send new to area code plus 10 digit number/ success/ removed caller id block from service and had cust click *star 67 then area code plus 10 digit number/ if you choose to have your contacts entered with *82 area code plus 10 digit cell number you will get error 00107/ can not receive or respont to blocked calls particularly long distance/resolves iss/ I am a technical suport agent for sprint/ Happy Texting
Jun 06, 2008 | Cell Phones
Caller id
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
Feb 01, 2008 | Uniden TRU9480 Cordless Telephone
How do I view caller ID?
The KX-T7731 is a proprietary system phone. You have a Panasonic phone system. Caller ID is transmitted between the first and second ring but the phone system itself is the only part that gets this information. The system has to be compatible for caller ID and it has to collect the caller ID data and send this information to your phone(s). Your phone can be used on many different Panasonic phone systems. The phone's part number does not help you. First thing you need to do is find out what system you have and if it has caller ID. The phone system part number should start with KXT like your phone.
Sep 17, 2007 | Panasonic KX-T7731 Corded Phone
Avaya 700340193 Corded Phone Logo
298 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
