Question about Electrolux Dishwashers
Where does the spring go in the HANDLE. TOOK FRONT OF DOOR OFF AND CANNOT FIND WHERE IT GOES?
  • 159 Answers
You need to take the top panel off with the handle in it too.then you should be able to see where it goes.the spring goes between the handle & the panel.
Posted on Jun 04, 2010
Remove door gasket
There is a spring that goes all the way around the door, just under the edge of the gasket. If you remove that spring starting at the bottom of the door, you should be able to remove the gasket for replacement
Mar 26, 2014 | Frigidaire ATF6000ES Front Load Washer
Door handle broke
This is not an identical one but is another LG that has the same latch setup. Hope these pics help.
Mar 07, 2012 | LG WD-16115FD Front Load Washer
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
Door handles slack feels like springs dropped so cant open door
You can release the catch from inside just keep trying and thern you need to replace the door catch itself this is a simple job
Jun 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Ford explorere rear door will not open
check the door handle in side door panel there is a rod that goes into the door handle that might have fallen out of it or more likely broken the door handles at a junk yard are about 5 dollars if you take off make sure it function that none of the teeth of the handle are broken and and make sure you have the right or left door handle it will be marked on inside of interior door handle . this handle slides forward towards the front of vehicle for removal then turn to remove rod from handle.
Mar 07, 2010 | 1997 Ford Explorer AWD
I need to fix the handle of a hoover washing machine hnf3157.I have the kit but can work out what way round the spring goes. Please help. Thank you Silvia
the hook faces away from the center of the door.
The handle goes around that.
The spring goes around both, on the inside of the hook, facing the center of the door.
Jan 16, 2010 | Hoover Nextra HNF 3157 Front Load Washer
How to put on new handle on indesit washing machine w133s
the spring will go so that it pushes the latch part in towards the outside edge of the door. the pin goes through the door frame, then through the spring's 'holes', through the latch, and back into the frame of the door. the spring ends should sit in a couple of grooves in the door part which may be marked/scratched by the previous one.
Feb 05, 2009 | Indesit W 123 Front Load Washer
Fixing a door
I took other hinge apart.
Removed front glass by removing handle -bar.
Removed upper screws of spring on both sides. loosened two bottom screws of spring assembly.
Removed control panel assembly by taking out 5 screws.
Started with one side hinge first.
Inserted larger arm of lever first then inserted small lever, pressed with small screwdriver to engage a little slot {bottom side} of smaller lever to little stud inside.
With the same screwdriver engaged a little hinge to the notch of larger arm..
Did the same thing for other hinge.
Put the upper screws back,
Tightened bottom screws back.
Put the front glass and handle-bar back.
Put control panel assembly back.
Now it is ready to go.
Door is Fixed.
Nanddas Bambhania.[Like to put things apart and putting them back.Helping friends solving their various mechanical and electrical problems.-big or small appliances]
May 09, 2008 | Cadco OV-250 Electric Single Oven
How to replace new door handle
Why can no-one supply a photo. Even with the last set of instructions there are still a lot of assumptions, e.g. which way is the handle pointing when it is face down!
Mar 10, 2008 | Indesit W 123 Front Load Washer
Dishwashers Logo
95 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
