Question about Linksys Wireless-G WRT54G Router
My Linksys wireless-G WRT54G is plugged into my Cable Modem which is plugged into my desktop. I can still get online on my desktop but not on anything wireless anymore Not on my kids psp's or my PS3 or anything. When I go to my Linksys Easylink Advior It reads "No Internet Connection" but I can get online fine on my desktop, and you I followed all the steps the L.E Adviors gave me to fix it but still no fix! No Internet Connection. My Router will be four years old this fathers day. My PC is running XP Home Edition Service pack 3 The cable from modem to router is plugged into the Internet port and the ethernet cable is now plugged into port 1 but it has been tested in all 4 ports samething No Internet Connection I even tried another ethernet card, still No Internet Connection.
  • 4,737 Answers
There are many causes for poor wireless connections, and many solutions: First of all, give your network a unique SSID. Do not use "linksys". Try to connect to your neighbor's router if available. Also set "SSID Broadcast" to "enabled". This will help your computer find and lock on to your router's signal. Poor wireless connections are often caused by radio interference from other 2.4 GHz devices. This includes wireless phones, wireless baby monitors, microwave ovens, wireless mice and keyboards, wireless speakers, and your neighbor's wireless network. In rare cases, Bluetooth devices can interfere. Even some 5+ GHz phones also use the 2.4 Ghz band. Unplug these devices, and see if that corrects your problem. In your router, try a different channel. There are 11 channels in the 2.4 GHz band. Usually channel 1, 6, or 11 works best. Check out your neighbors, and see what channel they are using. Because the channels overlap one another, try to stay at least +5 or -5 channels from your strongest neighbors. For example, if you have a strong neighbor on channel 9, try any channel 1 through 4. Also, try to locate the router/wireless pcs or laptops about 4 to 6 feet above the floor, in an open area. Do not locate it behind your monitor or near other computer equipment or speakers. The antenna should be vertical. Also, in the computer, go to your wireless software, and go to "Preferred Networks" (sometimes called "Profiles" ). There are probably a few networks listed. Delete any network named "linksys". Also delete any network that you do not recognize, or that you no longer use. If your current network is not listed, enter its info (SSID, encryption (if any), and key (if any) ). Then select your current network and make it your default network, and set it to automatic login. You may need to go to "settings" to do this, or you may need to right click on your network and select "Properties" or "settings".
If the above does not fix your problem, download and install the latest driver for your wireless card. Some users have reported improved wireless performance by switching to WPA encryption. If you continue to have problems, try the following: Try setting the "Transmission Rate" to 54 Mbps. If you still have trouble, download and install the latest firmware for your router. After a firmware upgrade, you must reset the router to factory defaults, then setup the router again from scratch. If you saved a router configuration file, DO NOT use it. Hope this helps. Good luck. Thanks for using FixYa.
Posted on Jun 02, 2010
  • drobmonie Jun 02, 2010
    All of my programs (simplecenter, vuze, others) think that I not online. Linksys Easylink Advior say's there is no internet connection, all of the programs say that. How do I fix that? and how do I change the channels on WRT54G? It'a as if something is blocking the routers internet connection.
2 Suggested Answers
SOURCE: No wireless connection, It just stopped.
Bro please visit my profile, so that i can give you a tips how to solve your problem.
URL: http://fixya.com/users/chael890
Posted on May 28, 2010
May 27, 2010 | Linksys Wireless-G WRT54G Router
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Dec 19, 2009 | Linksys Wireless-G WRT54G Router
Is the only way to get the linksys wrt54g wireless broadband router setup online going to just be free trials. Is it nay where for free
You can configure the Linksys to work on your network of computers without the need to go on-line, but if you want to connect to the Internet then you need to sign up with an Internet Service Provider and connect the DSL or cable modem to the Linksys.
Dec 11, 2009 | Linksys Wireless-G WRT54G Router
Need to setup Laptop wirelessly thru Linksys WRT54G
The default password of Linksys device is admin without username.
Jun 06, 2009 | Linksys Wireless-G WRT54G Router
Trying to get my verizon dsl to link with my linksys WRT54G route
The ethernet cable needs to be run from the dsl modem to the plug marked "internet" on the back of the router.
Apr 05, 2009 | Linksys Wireless-G WRT54G Router
My linksys wrt54g v8 will not recognize the internet
Try to do a hard reset on the router. Hold down the button on the back of the router for 10 seconds. This will clear all of the settings out of its memory. Then try to connect again. If this doesnt work power down both your router and your cable modem. Let them sit for a minute and then plug in the modem and wait 30 seconds. THen plug in the Wireless router. The issue should resolve itself.
Gary
Jan 24, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
