Question about Maytag MSD2456G Side by Side Refrigerator
Maytag wide by side ice dispenser lite stays on.
Maytag wide by side:
Exterior ice dispenser light will not shut off. When pushing exterior light switch, light brightens when turned on, but then goes back to a dimmer level when light is shut off. Does go completely out when freezer door is opened. Problem just started, but don't know why.
HVACRH20
  • 237 Answers
SOURCE: Outside door light won't turn off
Please post the model number so I can pull up a schematic. Some models have a "night light" mode that may have been activated so check the owners manual, other than that the control board could be bad, providing a slight "leakage" of power to the lamp (depending on the type of lamp control circuit).
Posted on Dec 29, 2006
SOURCE: ice and water dispenser for Maytag H20 not working
Ice 2 0 ...lights flashing and ice door flapping... i called 1-800-4maytag like someone else suggested.. they are sending me new high voltage board for free..and they will install it for free.. even though it is 2yrs old.. for once someone stands behind there product..
Posted on Sep 03, 2008
  • 4 Answers
SOURCE: Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Posted on Apr 19, 2009
SOURCE: The ice maker and water dispenser does not work. There is no power to the exterior dispensing unit on the refrigerator.
I'm assuming you are saying there is no ice and water being dispensed, but that the ice maker is producing ice.
Actual ice maker operation is independent of the fountain which is for dispensing only.
The power is checked at the fountain board on wires Red/Black and White. The door must be closed when doing this check as power goes through the door switch. If no power is present, check the same wires at the connector under the upper door hinge cover.
The next check would be Red/Black to Blue while depressing the actuator pad button.
Outputs off the board are Pink to auger motor, Black to fountain water valve, other Black to fountain light, Violet to cube solenoid, the two brown wires go to the ice chute door solenoid.
The ice maker can be checked by removing the plastic cover up front. Check test points L to N for 120VAC. Short test points T and H to cycle the ice maker. Make sure it does not have ice or water in the mold already, or it will run over.
Of course last but not least, check water to the refrigerator. It is a dual valve and unlikely both solenoids could fail at the same time.
Posted on May 04, 2009
  • 35 Answers
SOURCE: Ice maker sprays water...
sounds like the inlet part on the ice maker is froze over or not lined up in the opening of it right or a possibilty that the ice maker is leaking out the water if that is the case the ice maker needs replaced
Posted on Jun 07, 2009
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
Exterior warning lite stays on
The corning light only works when the turn signal is on is normal.
What are you talking about with an exterior warning light ? The light on the dash that tells you one of the exterior lamps is not working ?
Aug 19, 2012 | 2000 Ford Windstar
My brand new side by side with exterior ice/water dispenser barely dispenses water. It comes out in a tiny stream that after a few seconds only drips out. Why?
you might want to check the shut off valve on the house end. follow where the wate line goes and see if it is a self percing valve. if it is shut it off all the way to re-tap the cold water line on the house end. if there is a filter on the line with also cause this problem. Is the waterline new? if so it might not be tapped all the way.
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
When water dispenser is pushed the water supply line rattles and very little water comes out. The water supply line has good pressure and the ice maker works. I also changed the filter.
Our water dispenser will work for about half a glass then the pressure immediately stops and the water flow goes to a small stream. Maytag MDZ2667HES Wide by Side. HELP! Filter was changed approx 3 months ago.
Oct 12, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Whirlpool Gold Model GD25SFXHS03 exterior ice lever not working
Your problem is probably a broken plastic switch bracket . Pt # 2180226 . To access , use a butter knife between the dispensor grill and the lower portion of the dispensor cover . FIRST , remove the cover on the top freezer hinge , and disconnect the plug there . This removes all power to the door . Insert the knife about 1 " from the side , and push down and inward , to push the plastic tab of the cover , outward . Do the same for the other side . Lift upward to slip the top tabs free of the mount . Disconnect the plug to the dispensor cover , and remove the cover . The white piece with the 2 switches , probably has a short plastic stub , broken off which holds the ice dispensor switch . Looks like maybe 4 small screws , hold the switch bracket on . Transfer the switches carefully ,because you are working with plastic . When reinstalling the dispensor cover , after attaching the receptical , slip the top portion of the cover in place , and pop the bottom to latch the lower clips .
Aug 30, 2009 | Whirlpool Refrigerators
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
May 04, 2009 | Jenn-Air JCD2295HES Side by Side...
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Exterior lights blink, ice door opens and closes on own?
im honing my psychic powers here, it a french door bottom freezer right?? Its built by samsung and the High Voltage board has failed. Had the same problem with one here
Sep 28, 2007 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Maytag MSD2456G Side by Side Refrigerator Logo
48 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
