Question about Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo
Left half screen black, rt half appears normal.
Only analog channel reception now, HD channels too weak. Same symptoms w/ DVDs (left half blank, rt half OK). All other functions good.
  • Sharp Master
  • 12,061 Answers
Www.scribd.com/doc/.../LG-Training-Manual-LCD-TV-42LG70 Training manual above,
http://www.eserviceinfo.com/equipment_type/TV_2.html Above and below, are service and repair manuals. Follow troubleshooting steps.
http://elektrotanya.com/sharp_lcd_ctv_training_manual.pdf/download.html
This is a common problem, and is discussed in the training manuals above, please download and use these manuals to troubleshoot your issue, you will no doubt have to replace a board or two, but just work through the troubleshooting steps, starting at the power supply and work out, you should be able to isolate and repair your issue. When servicing try not to let the entire thing overwhelm you as one, treat the set as a conjunction of “Units”. Meaning that we can break the unit up into sections, for instance we have a Power Supply, and Audio section, a Remote Control section, we have a Input Control section, we have a Video Control section, and so on. Now all these connect to specific parts of the circuit. Some have no relationship with each other and some are dependent upon each other. What we need to do is try to understand our “Fault” and isolate it to at least an “Area”. Now when we have isolated the apparent problem, we then need to check our “Input” to that section and also the “Output” of that section, also we must first check that sections supply voltage and current, are correct. Depending on the unit being serviced, the Repair options, may be limited to changing a “Board” to clear the fault. Often these boards are exchangeable, and you get a rebate back, if when you purchase the new board, you send them you old broken board, and they then repair that, and around it goes. Other times, one must go down to “Board level” to effect a repair, always double check, before determining some component is faulty, it is best to isolate/remove, the component to test, often an “in situ” test can give erroneous reading due to “Other” components connected, altering the readings. Always replace with as good if not better components that you are replacing, skimping of component costs is counterproductive, in the long run. It can often be a great troubleshooting method, to completely isolate the “Faulty” part of the circuit, if you can, isolate the in & out, and also remove, the “Native” power from, it too. You power from and external source, then also you can provide an External “Drive” to this circuit which you will NOW, be able to test under a, “know good” situation, which is so important to gain a benchmark for operation. NEVER EVER simply replace a Board or Component without ascertaining WHY, it has failed, as seldom does anything spontaneously fail, unless placed under stress at all operating times, such as a power Supply or the like.
Of course, it is my professional opinion though that everyone should take their units to their manufacturers approved service center, contacting a head office, of your unit & getting an approved service center is just SO important, even worth the extra to ship it, you see, at those places, the Engineers, are trained on the equipment you have, they usually have parts on hand, and do the job quicker. Anyway do that and get a "Quote". This way, at least, you'll know weather to repair or replace.
Posted on Jun 02, 2010
  • src821 Jun 02, 2010
    what a bunch of general common-sense ho-hum ********! Thanks for nothing.
Just bought a vew 65 inch LED toshiba and it says digital channel signal is weak. Why
Make sure you have the menu set on digital channels not cable. Set antenna to air to pickup digital hd channels.
Nov 27, 2011 | Televison & Video
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Is it the TV or Comcast?
I'VE SEEN QUIT A FEW SAMSUNGS DO THIS AND THE DIGITAL BOARD IS THE PROBLEM YOUR MODEL NUMBER DOES NOT HAVE A DASH HLR4667W AND YOU NEED YOUR VERSION NUMBER AND MAYBE THE BEST THING IS GET THE PART NUMBER OFF THE BOARD.
Apr 17, 2009 | Samsung HL-R4667W Rear Projection...
HL-R6167W tv reception problems
Are you using a Hd cable box/directv or dishnetwork box?Or you are using your coaxial cable straight into your TV coax input?
Solutiondoct
Aug 30, 2008 | Samsung HL-R6167W 61" HDTV
TV blank, sound okay, picture comes for half a second while switching channels
i am a technician and i too have this issue. if any of you can get a schematic and service notes, send them to trae3@live .com and i WILL find the problem and report to each of you. i cant get any help from sears all i need is to speak with a technician who actually works on these things, get the paperwork and then i am sure it is a matter of a module swap. any info will help us!
Jun 23, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
I have the HD LCD model 40X787. To program the channels I have to scan in analog and then the programing will associate it with the digital HD channels. What will happen after feb 2009 when there is no...
The only people effected by the changeover are those that use external antennas for TV reception. I am assuming that you use cable or satelite correct?
Dan
Apr 17, 2008 | Televison & Video
Aspect ratio
Problem is solved. I unplugged my DVR from my receiver for about a minute, reconnected it, and the that solved the problem.
Dec 08, 2007 | Audio Players & Recorders
Channel jumping
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Apr 10, 2007 | Sony KV-36XBR450 36" TV
Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
