Question about Electrical Supplies
How to adjust fuel consume in gasoline generator?
    Scholar:
  • 142 Answers
The fuel consumption of a DG or Gas Generator is proportional to the power generated and the frequency  maintenance.
The fuel/air ratio can be adjusted only at one power point or free run in service conditions.
Posted on Jun 07, 2010
Runs but will not carry a heavy load eng boggs down with load and voltage drops
The engine isn't getting enough fuel. Your carburetor needs cleaning. Generators are notorious for gummed carburetors because of the ethanol alcohol in today's gasoline and the generator sitting idle for weeks, months & even years without use wicks moisture into the fuel. Drain your carburetor of gasoline, & remove the carburetor. Clean your carburetor with Carburetor Cleaner spray & make sure the float needle valve & seat are clear of gum & varnish. To help prevent this from happening again, shut off the fuel petcock at the fuel tank and run the generator carburetor out of fuel before you put it away. It'll help keep the carburetor free of gunk. Also, replace the old fuel in the tank with fresh fuel every 3-6 months.
Mar 06, 2016 | Electrical Supplies
Etq tg3000 portable generator is leaking gas from carburetor into air filter. Any suggestions
PDF]Manual - Northern Tool + Equipment
www.northerntool.com/images/.../166020.pd...
Northern Tool + EquipmentThe ETQ air-cooled gasoline generators are widely used when electrical power is scarce. Our generators provide a portable mobile solution in supplying power for field ... 5.5 Hours. Fuel Type. Premix 50 cups of Gasoline to one cup of 2 stroke oil ......Leaking carburetor, clogged fuel pipes, sticking valves, or other damage, ...
[PDF]Owner's Manual Model TG4000
Dec 08, 2015 | Electrical Supplies
What type fuel does a 5250 porter cable generator take
From p.10 of the manual
"Check fuel level, fill as required. Make sure generator is turned off and has been allowed time to cool down. Use clean, fresh, regular unleaded gasoline with a minimum of 87 octane. Do not mix oil with gasoline".
(taken from bottom of this webpage
http://www.cpoworkshop.com/porter-cable-bsi525-w-5-250-watt-electric-generator/pcbnbsi525-w,default,pd.html?cgid=porter-cable-delta-discontinued )
(Is this your exact model ?)
14.April.2014
Apr 14, 2014 | Electrical Supplies
I have a 5500 ppg generator that won't start. I've verified the fuel lines to the engine are delivering fuel, but won't start. I've been able to pour a small amount of fuel down the carb...
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Aug 23, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
I would like to know the exact ratio of oil and gas of my homelite 720 generator,i lost the manual and i have to be more specific in fuelling it.what does it mean by 50 is to 1? thank you
Find the manual here http://www.homelite.com/service_support/product_owners_manuals b> Mixing the fuel The Generator is powered by a two-stroke, air-cooled engineand requires a fuel mixture of gasoline and 2-cycle fuel lubricant. NOTE: Always mix two-cycle engine lubricant likeHomelite's Exact Mix Semi Synthetic Lubricant with gasoline before fueling theunit. Running the Generator ongasoline alone will ruin the engine. NOTE: Recommend you use ONLY Homelite or G-oil® inyour product.( Or any 2 cycle motor oil in this is not available) Use a mixture of 50 parts unleaded regular gasoline and 1part two-stroke engine lubricant (50:1). Use branded 87 octane (R+M+2) unleadedgasoline or gasohol (maximum 10% ethyl alcohol, or 15% MTBE, no methylalcohol.)
NOTE: Always mix lubricant and gas in the properproportions: 2.6 ounces of lubricant to one gallon of unleaded gaso­line. To mix the lubricant and fuel together for use: 1. Pour 1/2 gallon of gasoline into a clean gas canor other container approved for fuel storage. Do not mix the fuel and lubricantdirectly in the Generato's fuel tank. 2. Add 2.6 ounces of two-cycle engine lubricant tothe gasoline mixture. 3. Add the remaining 1/2 gallon of gasoline. 4. Close the container holding the gas/lubricantmix and swirl the can to blend contents together. NOTE: Do not mix more than you will use in a month,and shake the container to blend thoroughly before each use. Using an old fuelmixture can cause starting difficulty or damage. DO NOT USE E85 FUEL. IT WILL VOID YOUR WARRANTY. NOTE: Fuel system damage or performance problems resultingfrom the use of an oxygenated fuel containing more than the percentages ofoxygenates stated previously are not covered under warranty. Ethanol. Gasoline containing up to 10% ethanol by volume(commonly referred to as E10) or 15% ethanol by volume (commonly referred to asE15) are acceptable. E85 is not. Whenadding fuel to the Generator, make sure the unit is sitting on level ground andthat the engine is not hot. Fuelonly with recommended 50:1 mixture of gasoline and lubricant as described in Mixingthe Fuel. Toadd fuel to the Generator: 1. Cleanarea around fuel tank cap, if necessary. 2. Removethe fuel tank cap. 3. Inserta clean funnel into the fuel tank. 4. Slowlypour gasoline/lubricant mixture into fuel tank. NOTE: Filltank no higher than 1/2 in. from top to allow for gasoline expansion. 1. Reinstallfuel cap. 2. Clean up any spills. J
Thanks for using FixYa!! I provide my answer for free as a publicservice - a 4 THUMBS rating and POSITIVE Comment is really appreciated for theFREE answering of your question.
LtCmdr Spock said: "An ancestor of mine maintained, that if youeliminate the impossible, whatever remains, however improbable, must be thetruth."
May 26, 2011 | Office Equipment & Supplies
Will 10% ethanol in gas hurt generator? Mine seems to be idling a little rough these days.
I wouldn't say the ethanol is the problem, but perhaps the brand of gasoline. I can tell you that many cars including my own run crappy on certain gasolines (even though all gasoline contains 10% ethanol), when they get older. For example I get horrible gas mileage on Exxon gas, while I get wonderful mileage on Shell or BP gas. Experiment with that a little and if there is no improvement you (or if your not sure how a shop that deals with generators can do it for you) can adjust the idle and check any filters that may be one the generator.
Jul 07, 2010 | Watts Onan Portable Generator - 4000 ,...
Adjustments for carburetor
put the original jet back in and leave well alone,any weaking of the mixture will burn the valves out and possibly burn a hole through the piston crown .Want better fuel consumption then buy a citreon diesel
Dec 19, 2009 | 1997 Toyota Corolla
Hi output from generator
I found out that the gasoline motor was turning too fast so I had to turn down the speed of the motor with the adjustment screw.
Sep 06, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Engine cant run with air filter fitted, I have cleaned it .but the problem remains the same
This means that you are over fueling. There is more fuel going to the carberator than air. By removing the air filter you are allowing more air flow into the carberator, which is allowing the engine to run right. Natural gas and propane generator must have no more than 11 inches of water column. Gasoline engines should have no more than 3.5 psi out of the electric pump. If gasoline is gravity fed, then this means that you need to rebuild the carberator or purchase a new carberator, but try to adjust the flow valve on the bowl of carberator first.
May 19, 2009 | Kipor Parallel Wiring Kit, 30 amp...
Electrical Supplies Logo
118 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
