Question about Seagate U6 (ST340810A) 40 GB Hard Drive
How many hour i freeze my hard drive? - Seagate U6 (ST340810A) 40 GB Hard Drive
  • 39 Answers
1 hr is probably enough. Even if you freeze longer, it will heat up real fast once you start the recovery process. Get a small plastic cup, put ice in it & set it on top of the drive to prolong the cool temp. Keep an eye on moisture build-up.
Posted on Jun 08, 2010
Where can I get my hard drive mended it just ticking and will not work
I've had a pretty good success rate with freezing drives to recover data from a dying/dead drive. Much simpler and cheaper then most other methods of data recovery.
Freezing the drive shrinks everything inside, sometimes freeing up stuck/seized/trapped components, or keeping an overheating component from shutting the drive down right away.
Stick the drive in a ziplock bag(to seal out moisture) in the freezer.
While it's freezing, set everything up to quickly transfer your files off the drive if it does work. After a couple hours in the freezer, plug the drive in and see what it does. It may only work for a few minutes, for hours, or weeks. Pull your data off as fast as you can, if it stops again, re-freeze it and start where you left off. I've frozen drives 3-4 times to get everything off.
Dec 04, 2015 | Iomega Prestige Desktop 500 GB USB 20 Hard...
Internal Harddrive giving hissing sound.and not booting. Model: western digital WD5000AAKS 500gb SATA internal drive. On PCB it says: 2060-701640-002 REV-A Recorded sound .wav file:...
Your hard drive is probably either failing, or about to fail. The 5 hour freeze technique will at best buy you a few hours to backup your data. I would backup everything and prepare for that drive to fail.
Mar 03, 2011 | Western Digital (WD5000AAKS) 500 GB SATA...
Gateway E-4600 freezes even in bios setup, have upgraded power supply, new memory, reinstall system, swapped hard drives, happens after about am hour , but on hard reboot it freezes in a minute or two....
If your system freezes in the BIOS, then the issue is almost certainly the motherboard, which it sounds like you haven't replaced yet.
Good luck. Hope this helps! If so, please give a rating!
Mar 02, 2010 | Gateway Computers & Internet
Dell d600 freezes intermittantly
sounds like the hard disk drive is slow to spin up. Sometimes older drives don't get all the way up to speed at boot, then with repeated restarts, the drive warms a bit and the spindle friction drops allowing full speed on the drive.
Try running HDD Diags the 1st boot of the day Fn +power button, see if you get any diag failure. Generally, a drive has to be within 3% of rated drive RPM (5400 or 7200) to function
Jan 11, 2010 | Dell Latitude D600 Notebook
Will not open. clicks a few times and freezes up the pc
There is a very good possibility that this hard drive has crashed. However, there is a little trick you can try. Disclaimer: There is no guarantee this will work and there is a very good chance you will not be able to retrieve your data. If data is very important, I would recommend taking it to a data recovery specialist. If you would like to try on your own, seal the hard drive in a ziplock freezer bag and freeze overnight. Try to access your data as soon as you remove the hard drive from the freezer in the morning. (I have seen this trick give up to an hour or two of use out of a dead drive.)
Hope this helps
Dec 11, 2009 | Ximeta NDU10-120 (890345000151) 120 GB...
Getting ticking noise from the computer and it does not recognise the drive
The arm for the hard drive is probably bad. That is the ticking sound. The arm is loose and not reading the platters. If you have data that needs recovered from the drive, I wouldn't run it any more. Take the hard drive out of the case and find another computer you can put the drive in as a slave. You can try putting the hard drive in a freezer for an hour or so, plug it into another computer and try to get files off of the drive. This might work for a bit until the drive gets warm then you'll have to freeze it again. Freezing the drive might tighten the arm up enough to read for a short time to maybe recover files but the drive is probably toast.
Oct 01, 2009 | Western Digital 320GB MyBook External USB...
Laptop 'freezes' after about half an hour of operation
Is the hard drive making a clacking noise, and/or does the mouse freeze only once or freeze and unfreeze a few times before dying completely?
Nov 21, 2007 | Computers & Internet
Set has intermittent short freezes
It is possible for the hard drive to fragment and in that case doing an entire hard drive erase and format should clear up that issue, but if it does not try looking at a possible buffer issue and the need for a software upgrade, I have seen this happen in some cases. DVR should go through an erase and reformat at least once every two months since you really should be storing your movies on a separate hard drive and using the internal hard drive for just temporary storage for viewing.
Sep 07, 2007 | Philips DSR708R DirecTV / TiVo DTV...
Hard drives freezing up
Damaged drive controller on HDD a possibility. Pull drive and test as a slave to rule out a bad RAID controller. Let me know if the drive is failing under SMART setting in system BIOS upon boot.
Jun 22, 2007 | Iomega NAS P415m 180 GB Hard Drive Array
Crossfire 160 GB external hard drive
Dear Crewchief Try deep freezing your drive, really, I mean freezing it for more than an hour, take it out and attach as a primary or secondary slave and see if it cycles up. Sure hope this helps.
Jan 16, 2007 | Smartdisk - Peripherals - HARD DRIVE,...
Seagate U6 (ST340810A) 40 GB Hard Drive Logo
90 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
