Question about Whirlpool GH5184XPQ Microwave Oven
GH5184XPS4 door frame is broken
Need GH5184XPS4 door frame (plastic) part number
My Whirlpool GH5184XPQ will not turn on. I plugged it into another GFI plug that i know is working and still nothing. It is completely dead? Any ideas or guidance would be greatly appreciated, thnx.
SAUSUK
Posted on Jun 29, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You can buy its parts from this link:
Whirlpool GH5184XPS4 Parts
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Emerson microwave door latch
I have an Emerson MW8999RD that all of a sudden yesterday wouldn't latch. I don't think you have to, but I took the door off (three screws hold the case on which needs to be removed to get at the top hinge). Then I took off the inner plastic picture frame - pretty easy with a thin blade to move the fragile tabs. Then I removed the metal frame that has the little microwave blocking holes. This was the hardest part because the plastic retaining tabs are even more fragile and I broke one. Then I found the loose spring due to broken plastic hook as described above. I was able to make a new hook by simply looping a small zip tie where the old plastic hook tip broke off. Now works great!
Aug 22, 2013 | Microwave Ovens
NEFF H5430NOGB Integrated oven - door won't close, the ;hooks on the door itself seem to have gone loose so they ill not clikc inot place when trying ot close, door just flops open.Amy ideas???
I had this problem. The spring inside the door which pushes the the latches down had broken (plastic peg had broken off).
I managed to fix it by attaching the broken end of the spring to the door frame using a small nylon cable tie using the small hole in the plastic fingers which was already there. Note you need to remove the inside door surround.
See the following link to remove the plastic cover on the door
http://www.fixya.com/support/t1267577-replace_front_glass_door_neff_microwave
I had an interim solution which was to tie some thin string to the latch and feed it under the door and pull on the string when closing the door (when it should be latching.
It was
Dec 06, 2010 | Neff H5430 Convection Microwave Oven
Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Nov 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
The plastic frame around the door has broken, how do I remove the door so I can super glue the crack? It is a GE JVM1631Wjo1 spacemaker
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 14, 2008 | Microwave Ovens
Panasonic microwave door is stuck. The door is not opening
If you push in on the open door button and it just goes in and does not open the door, then the problem is that the plastic piece that actually opens the door has broken. You can verify this by removing the cover from the microwave and look inside. If you are handy just buy the part from the panasonic parts store in your city and replace it. If not take it in and they will replace it for you.
Good luck
Tom
Jun 12, 2008 | Panasonic Microwave Ovens
Jvm 1410 spacemaker xl1400
not the easiest thing in the world to do. From my notes, that requires actually removing that door. ughhh/
Apr 02, 2008 | Microwave Ovens
You need to use the entire correct model number at their site, but you can find a helpful exploded view PDF diagram by searching for "Repair Part" at the GE parts site: http://www.geappliances.com/shop/prts/ Normally you can separate the door panels without removing the door. I've included a diagram from a Sharp model that might help. If you do have to remove the door, you have to be sure you reinstall it exactly where and how it was, or you may get microwave leakage. You should definititely mark the locations of all the hardware before disassembly.
Nov 06, 2006 | GE JVM1650 1000 Watts Microwave Oven
Whirlpool GH5184XPQ Microwave Oven Logo
154 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
