Question about Avaya Corded Phone avaparp18d
Avaya Partner line always lit
The office I work at is using avaya partner 18d phones, and for some reason in the last couple of days the line 1 button has lit up and has stayed lit even though no one is on it. Does anyone know why this would happen? We can't use line 1 at the moment because it is always lit.
    President:
  • Avaya Master
  • 860 Answers
If the line button is lit then something within the system has picked it up. If the phone is a multiline set, the line 1 light on the set that is using the line will show green. The line could also be held by either a cordless phone on the system or the voicemail system. The easiest way to clear the line (if the held set isn't apparent) would be to cycle down the power to the phone system for a moment. That will clear the line if its held by the voicemail
Posted on Jun 02, 2010
My avaya partner 18d phone does not ring how can I turn on my ringer
Hello Tom,
Avaya actually has SEVERAL "PARTNER"
models referred to as 18D... but when I was associated... they WELCOMED CUSTOMER CONTACT opportunities in the
continental U.S. ... call their toll-free Heipline,
available 24 hours a day, at 1 800 628-2888.
You should first check your owners manual...
The most likely cause:
is the "DND" (do not disturb) Feature is "ON".
If you books are not immediately available AVAYA customer support can assist your EVERY COMMUNICATIONS NEED.
For free manuals check out the URL (link) below...
If you are still stunned (a lot of buttons) comment me back with the EXTRA 3 characters in the name... and I'll look up your precise model.
Results 1 10 of 10
Nov 04, 2016 | Avaya Lands Phones
How do I Change Tine on a AVAYA PARTNER 18D Phone?
Press Feature 00 (zero, zero) from station 10 or 11. Press left intercom button twice, press #103, and then enter time in military format (24 hr). Press feature 00 again. This is all done with the handset down.
Mar 15, 2010 | Avaya Eurostyle 18D Corded Phone
Avaya 18D phone only speaker works not the handset. Order a replacement phone and the new phone does the same. We swapped locations snd the problem goes with the phone. Handset placed on a known working...
Avaya Partner 18D Button phone:
Two possible solutions,
First, could have a bad handset cord.
Second, I have come across a bad handset connection ports on the Euro style phones. The handset cord and the port just don't mesh well or the port itself is bad.
Feb 09, 2010 | Avaya Partner 18 Eurostyle 18D telephone
Phone static on the partner 18d
Is it on the same line? What about when you call other extensions, is there static?
If it is a line, swap that line and another. If you have static on the same line port, then it is a port problem of the system. If it follows the dialtone, the line from the phone company is the problem.
Jan 14, 2010 | Avaya Partner 18 Eurostyle 18D telephone
Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
Apr 13, 2009 | Avaya Corded Phone avaparp18d
Avaya 18D unable to make outgoing calls
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Press feature "00" to logout
Hope that helps
Mar 20, 2009 | Avaya Partner 18D Display Phone (315807BA)
Which button is the 'feature button' on the Avaya Euro 18D phone?
It's the gray button labeled FEATURE just to the left of the #1 on the keypad.
Mar 09, 2009 | Avaya Partner 18 Eurostyle 18D telephone
Manual
A simple Google search found a manual covering the Avaya (Partner) 18d phone.
It can be found here:
http://www.getempire.com/media/guides/manuals/partner/456804_6.pdf
Good luck.
Mar 05, 2008 | Avaya Lucent Partner 616 Phone
Avaya Partner-18D office phone-After an intercom call, the receiver's phone rings
Try hitting the speaker button and intercom your boss. When you hit the speaker button to hang up, do you get the same thing? If not. It could be that the gray "clicker" switch that pushes down when you put the handset back isnt going all the way back down...
Let me know.
Dec 28, 2007 | Avaya 700340193 Corded Phone
Avaya Corded Phone avaparp18d Logo
454 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
