Question about Cameras
Very very Bright pictures outside and lines thru them inside
I have a Cannon Power Shor 7.1. It is brand new. When I take pictures outside, they are all flashed out, so bright, I can barely make out an image. When I take them inside, there are lines thru them and the are not clear at all and it looks like the flash was also taken. They are on the bright side also. I am very frustrated. I am on vacation in Bangalore India and cannot take pictures. I bought the camera because it is suppose to be one of the best. It is not in this case. Is there some place here where I can take it? Please advise or help me. Thanks to whoever answers me.
  • uncled Apr 09, 2008
    The first 20 or so pictures were perfect. The problem did not start until after I downloaded them to my PC. Ever since then, the problem has existed. There seems to be no setting to correct the issue, it almost looks like some kind hardware or manufacture defect issue.
  • Anonymous Aug 27, 2008
    Have a dsc s650 7.2 Taking pictures inside or out still results in white lines thru the pictures. What should I do?
I think that is becoz of the light in your surrounding....
Posted on Apr 09, 2008
1998 Pace Arrow 30e, hot to remove hot water heater
open outside access panel turn off LP turn off shore power and disconnect all batteries disconnect LP line remove all screws around frame remove drain plug and turn off water go inside and remove water lines and wiring take picture before unwiring gently pry on outside to slide unit out transfer what needed then install new one
Jul 11, 2017 | RVs
Screen is not bright like in advertising photos and the there is a line on the screen shaped a bit like an S . Screen grey one side,black the other.
The watch is brand-new, and you have every reason to expect that it would appear and function correctly. Return the item and ask for refund or replacement.
Oct 10, 2016 | The Watches
Very bright pictures from ouside
When you go outside, do you change anything in the settings? I think the camera should be in the auto, sport or something like that. If it is not in auto but in the night Scenery, night Portrait or high Sensitivity, pictures inside, with less light will be ok, but outside they will be over blown.
Nov 26, 2013 | Vivitar VC-7340 Digital Camera
My BRAND NEW Reebok 2.2 Motorised Treadmill Trips the electrics when swithced on. What is causing this? :(
See my block diagram for treadmill and see the fuse.
1) This ocurre for varios reason a) test the swicht power for short circuit.
2) the capacitor shor 3) the coil is short 4) the board is short.5) The power cord some wires is touche the carcase from treadmill, or some other wires inside is touching , test it
Now you must isolate the short with DVOM.
God bless you
May 10, 2012 | Reebok Exercise & Fitness
How do you get a new fuel line thru the hole in the plastic gas tank of a Homelite weed *******. It's a tight fit.
Hi toddisstan...
Use a piece of wire12-14 inches long and slightly smaller than the size of the inside diameter of the fuel line and push it into the new fuel line and thru to the other side of the line, make a hook in the wire to hook over the end of the new fuel line and pull the wire tight against the new fuel line.
The wire will collapse the fuel line when you go to insert it into the tank, that is why the wire must be smaller than the inside of the fuel line..
Then lube the outside of the new fuel line with a light oil or vasoline, grab the wire and fuel line combo and insert it into the gas tank...
Once you have the fuel line into the tank, then push the wire all the way thru the new fuel line and remove it from the fuel tank with a set of needle nose pliers.
Please take time to rate me thumbs up
Sep 10, 2011 | Homelite Garden
Why does my camera take white pictures outside,
Do you have the ISO set to a very high number instead of "auto ISO"?
Apr 18, 2010 | Kodak EasyShare C763 Digital Camera
Glaring nothing but bright can't see the picture
Try to adjust LCD Brightness.
Press Menu.
Go to LCD Brightness.
Dec 09, 2008 | Samsung Digimax D53 Digital Camera
Shuts the lcd down ?
Is it possible that the brightness of the LCD was turned down?
You might want to try turning it full bright. There are directions in the instruction book on how to do this.
Next select the viewfinder to turn on when you pull it out. Close the LCD panel and pul out the VF and look thru it in doors first and see if the picture is normal, now go outside while looking in the VF and see if the picture slowly goes dark. If it does looking at it this way then it would indicate that the Iris is closing too much. Go back inside.
In the menu there is an option to reset everything back to factory settings. Sometimes it is possible to have accidentally changed a setting while you were in the menu. Go thru the menu and execute all of the pages that have a reset option. Then test the camera again. If the image goes away in bright light it is possible that the adjustment settings for the Iris have been corrupted and the camera will need to be brought into an authorized JVC service center that has DVC camera experience and they will be able to readjust the Iris. It could also mean there is some kind of malfunction. If the image stays visible in the VF then the LCD might have just aged and lost its intensity to where you are unable to see it outside anymore. The DV5000 is 4 or 5 years old now?
Apr 23, 2008 | JVC Cybercam GR-DV500US Mini DV Digital...
Very very bright pictures outside and lines thu the inside ones
Check that the camera is not in night mode or overesposed from menu setting, I think you need the manual. Put it in daylight mode
Apr 09, 2008 | Cameras
White lines, all white pictures
I have the same problem have you been able to fix it ?
Sep 23, 2007 | Pentax Optio M20 Digital Camera
Cameras Logo
209 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
