Question about Pentair Minimax NT Heater
Have a Pentair MiniMax NT 6800 Low NOx heater that will not light
I have a Pentair MiniMax NT 6800 Low NOx heater that will not light. I havent attempted to start if for about a year. On the outside panel, the Power Light, TSTAT light, Aux light, Press light, Power Light and Service light are on; (not the Heat Light). On the back of the panel the the HTemp light and Tfuse Light are on, but not the PV light. The fan is blowing the entire time but never seems to attempt to light. Any suggestions?
4 Suggested Answers
  • 15 Answers
SOURCE: Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Posted on Jun 23, 2009
  • 990 Answers
SOURCE: E04 comes on after fan purge cycle-Pentair minimax nt pool heater
This is a fan falure code. It can mean the fan has problems (not likley if the fan goes and isn't labored) You have a sensor in your exaust (probally not this if you don't get a good start) The culperet is probally in the negetive pressure sensor. This is a 2-3 inch disc with wires going to the controls and a rubber tube going to the fan. Pull the tube from the fan and make sure the fan fitting is clear (poke with a tooth pic) Be sure their are no kinks in the hose. If the heater is 4 years old the diaprahm could be bad in the pressure sensor. Check the other things first but this is probally your problem. Good luck, hope this helped.
Posted on Jan 26, 2010
  • 64 Answers
SOURCE: error code e04
If the fan was seized, it is likely bad, even if you freed it. If it doesn't sound the same, or is not as loud as it used to be, it is also most likely bad. If it doesn't move enough air to close the air pressure switch, then you will get an 04 fault, which is an air flow fault. HTH
Posted on May 24, 2010
I have an mini max nt w 6800 controls ignitor
The voltage to this ignitor should only be 120 volts. If you are getting 240 volts to the ignitor, there is something really wrong with the wiring to the heater or in the heater.
Jul 27, 2011 | Pentair Minimax NT Heater
Error code lo and eo4
The LO is just telling you the water is below 58 degrees. The EO4 is the fan sensor. If you haven't used the heater for a while you should check for rat and bird nests then you can check your air pressure switch to be sure it is OK. The NT LN model will have the gas pressure switch in the same circut, so if you have the low nox model be sure to check all your gas valves and be sure they are on. If this is a LP heater be sure your tank is at least 1/3 full to have enough pressure to run the heater. If the heater hasen't been run for a while be sure to bleed your gas line also. Good luck.
Dec 04, 2009 | Pentair Minimax NT Heater
Err light on on pentair nt minimax. pushed power button, won't go off. any suggestions?
24 v at the transformer ? if yes unplug thesmostat probe if 888 change t probe if err change t board
Sep 06, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
May 29, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat, "err" message
temp sensor get the new one with yellow wires.should do the trick.
Jan 19, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
41 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
