Tv makes alot of buzzing noises and a huge banging sound.its a toshiba
    President:
  • 1,099 Answers
If the buzz is coming from the speaker suspect a bad saw filter in the if circuit (very common).
If it is coming from elsewhere in the set it could be the flyback transformer, line input choke, or most common on those sets - the deflection yoke. I have repaired many of these yoke by using a wooden shim and some silicone rubber. In the collar of the yoke just ahead of the lock down clamp, there are some metal strips under the plastic. These are magnet that are used for convergence correction at the top and bottom of the picture. If you disturb them too much it will throw off the convergence.
Hope this will help...
Posted on Jun 02, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Picture and sound go after a while will come back after switching to standby Or the old fashion Bang on the top. Also a Loud buzzing sound in Standby.
U have tools like a soldering iron,a roll solders,also can u do basic soldering?Yes.This tv have cold solders joints in the(CRT-Tv tube) video board connections pins socket that connected to the(CRT-Tv tube).The tv loud buzzing sound is comming from the FBT-the flyback transformer,that is a big black block of plastic with a red wire with a cap that hook to the(CRT-Tv tube).Resolders both the FBT and the video board CRT socket holes connections.Will solved these 2 problems.
Dec 03, 2010 | Toshiba Televison & Video
My tv toshiba md13p1 combo tv is not working. when i plug in makes a noise like a bee buzz. the only way to turned off is to unpluged.how much it cost to repair?
That buzz sound most probably are from axed horizontal output transistor. If your tv is a CRT type. Some other reason for that are faulty regulator, and diode on flyback side, or the expensive one is the flyback itself.
If age is the reason transistor can be replaced as soon maybe thirty minutes. Please get a quote and estimate first to calculate if new tv is more ideal than having it repaired.
Oct 05, 2009 | Toshiba MD13P1 13 in. TV/DVD Combo
Have a Toshiba 42hm66 and it has started to make a humming/buzzing noise. At first it would make the noise for a few minutes and then quit...now it does it the whole time the tv is on. Any ideas?
Sounds like a fan getting cought on some dust inside you might want to have this serviced if you do not know how to clean it.
The humming would be a fan the buzzing would be the fan getting stuck!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 17, 2009 | Toshiba 42HM66 42" Projection HDTV
Toshiba 36zp18q buzzing noise.
Humming sounds come from the power supply and buzzing sounds come from other circuitry. Most likely a capacitor somewhere.
Feb 18, 2009 | Toshiba 36A40 36" TV
Toshiba 44NHM84 won't turn on
Usualy these problems are due to solder evaporating under the heat of the component.If you are a competent technician,by opening the tv set and by looking closely on the solder part of the board,
you should see a few that are not as shiny as the other, or look like a donut around the pin.these should be redone.those failiure are around the components that heat up:voltage reg,h-v reg and the
resistor around them.
good luck
Jan 28, 2009 | Toshiba 46HM95 46" HDTV
My 61" Samsung DLP has loud Buzzing sound - Everything else ok
There are only 2 moving parts on a dlp tv the color wheel and the fan. The color wheel needs to be replaced about every 4 to 5 years. Some start to make noise and others like mine blow up with a bang. Go to utube to get instructions on how to replace it only cost me for part $100 good luck
Dec 14, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba 62hm15a
my tv was making a similar sound so i took off the back. There was a bundle of wires that had come loose and were rubbing the fan blades. I retaped them back and no more noise. seriously.
Jan 20, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
