Question about Peachtree Software Peachtree Complete Accounting 2003
Peachtree Complette Accounting 2003. I am now "out-of-blance" due to a change in the Retained Earnings account in mid year. In viewing the G/L the ending balance for the month does not equal the beginning balance, yet there are no entries that effect it. How di I correct this? The system does not allow a one sided entry.
  • gpollock Jun 03, 2010
    At first, it seemed like you were addressing someone else's problem. But I clicked on the "Answer ID 353" link and that gave me a procedure to do that corrected my situation. Thank you.
  • 503 Answers
It sounds like you will need to do a general journal entry to correct your cash balance. But before you do, you should check a couple of things.
The first thing that concerns me is when you said " I did notice that the beginning balance for the cash account was off so I adjusted that in the chart of accounts." The only time that would be called for would be if the beginning balance of an account on the general ledger report did not match the ending GL balance for the previous month. And even then, I would try running the Data Verification before I manually adjusted it. If your adjustment was for any other reason, then you should undo it.
Second, run a general ledger report for the account you are reconciling. Set the time frame to All. If you get a GL footing error, then there is an error in the balance that you can correct by following the steps in Answer ID 353. If you don't get an error, then the balance is calculating correctly.
Third, if I understood your post correctly, you have gone all the back to the Jan 2008 reconciliation to try to track this down. I would redo each month's bank rec. If everything is done right for each month, you will be off the same amount at the end of each bank rec. When that happens, and there is nothing on the outstanding items list that doesn't belong, then you know the problem was in the beginning balance. Then you can make a general journal entry to correct your cash.
Unless you have not filed your 2008 taxes yet, you will want to make the adjustment in 2009, since the offset to the cash account will probably be an income or expense account.
If you are unsure of what adjustment needs to be made after working through the 2008 reconciliations, I would suggest working with a Peachtree Certified Consultant or your CPA.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jun 02, 2010
Tip
How To Run Data Verification In Peachtree Accounting
<p>Data Verification is a Peachtree utility that allows you to verify if any of your data files are missing or possibly damaged. During the verification process, Peachtree makes any needed changes so that your data records are compatible with Peachtree data formats. For example, if an ID in a data record has more than the maximum allowable characters, Peachtree will truncate the ID. Also, any files that Peachtree finds to be corrupt and unusable are deleted during the verification process. <br /> Following verification, Peachtree generates a log that details all errors encountered and reports on any changes made, as well as any corrupt records deleted. Follow these steps to run the test:<br /> <ol> <li>In your company, from the <b>Tasks</b> menu select <b>System</b>, <b>Change Accounting Period</b>.</li> <li>Highlight the first <b>Accounting Period</b> on the list and click <b>OK.</b></li> <li>From the <b>File</b> menu, select <b>Data Verification</b>.</li> <li>Select the <b>Both Tests</b> (recommended) option from the menu and click <b>Start</b>. <br /></li> <li>You will be prompted to make a <b>backup</b> of your Peachtree data. This is a required step. Click <b>Save</b>. The data verification test will begin automatically when the backup is complete.</li> <li>If no errors were found, click <b>Close</b>. If errors were found, you can examine the details of the tests by clicking the <b>View Error Log</b> button.</li> <li>To change back to the current Accounting Period follow steps 1 and 2 above.</li></ol>
on Feb 21, 2011 | Computers & Internet
I want to change my accounting period from January to December to April to March how i can?
A company follows WDV method for charging deprecition on a plant. The total depreciation charged for 1st four years is rs 28000. It decided to switch over to SLM in the 5th year mhat would be the amount of resulatant.
Aug 23, 2010 | Peachtree Software Peachtree Complete...
I am denied access to change the accounting period in peachtree
I've seen this before with peachtree. What happens every time you work on an accounting file peachtree locks the contents of the file. Occasionally the software never gets the chance to unlock it. This can happen if the computer shuts down unexpectedly, a file gets corrupted etc. You should find in your installation depending on the version a scan utility that can scan your accounting main file and see if there are problems and correct them. If not next try a re-install of peachtree and run the updates and try opening the file. Finally if not it is time to restore an update you have prior to the problem.
Sep 04, 2009 | Peachtree Software Peachtree Complete...
HOW TO POST PAST YEAR ENTRIES INTO MYOB
You would have to post the entry as last financial year, just to keep it all ligit. After you have done so check that your retained years earnings are correct!.
Jun 30, 2009 | Myob Accounting Plus (BPJUBC00) for PC,...
I have peachtree and cannot change acctg period
I HAVE PEACHTREE. SOMEHOW OVER THE WEEKEND OR AT SOME POINT OUR ACCOUNTING PERIODS HAVE GOT OFF TRACK.
I NEED TO CHANGE OR EDIT THESE TO MAKE OUR DATES RIGHT.
CAN YOU PLEASE TELL ME HOW TO CHANGE. WE ONLY HAVE
1 YEAR OPEN WHICH IS 2010.
Apr 06, 2009 | Peachtree Software Peachtree Complete...
Federal Income tax
No it has not been corrected. After yesterday's experience with the sales tax not working it finally came out that apparenty Peachtree had installed a bug that would cause the system to fail after a certain age. Your techs from your premium side that attempted to fix it before that notice failed miserably. I know there is a code somewhere inside it that cause the problem but they apparently cannot find it. I believe it is an attempt by Peachtree to force the customer to upgrade which I do not want to do.
Feb 27, 2009 | Peachtree Software Peachtree Complete...
Using Peachtree Complete Acctg 2003 w/ Microsoft Vista
may be need to reinstall it again then make update for it
Dec 09, 2008 | Peachtree Software Peachtree Complete...
Peachtree Software Peachtree Complete Accounting 2003 Logo
64 people viewed this question
Top Peachtree Software Computers & Internet Experts
Don A
Don A
Are you a Peachtree Software Computer and Internet Expert? Answer questions, earn points and help others
