Question about Toshiba Satellite A205-S4587 Notebook
Cec_main.exe Any time I boot, there is always a notice on the screen that the CEC_MAIN.exe is not installed properly. How to fix the problem with my Toshiba Satellite U405D installed in it widows vista ultimate?
  • 53 Answers
This file is associated with the web cam software. You can try to uninstall the software and reinstall it. You can find the web cam software here (page 6):
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1702259&rpn=PSAF0U&modelFilter=A205-S4587&selCategory=3&selFamily=1073768663
Posted on Jun 02, 2010
How do the hmi on tv withe control
How to Enable HDMI-CEC on Your TV, and Why You Should
www.howtogeek.com/.../how-to-enable-hdmi-cec-on-your-tv-and-why-...
Jan 16, 2015 - The devices can have some control over the TV, and the TV can have some control over ... AOC: E-link; Hitachi: HDMI-CEC (Thank you, Hitachi!) ...
How to find out if your device is HDMI CEC capable?
hdmicec.blogspot.com/.../how-to-find-out-if-your-device-is-hdmi.html
May 18, 2012 - Hitachi - HDMI-CEC ... You can control your computer with your TV'sremote control and you can set up that your laptop shuts down or goes to ...
[PDF]OG S606 U516 Eng - Hitachi Service
Dec 26, 2015 | Hitachi Gst Hitachi 46" Class LED-LCD...
Why does it turn on, then off?
"HDMI-CEC", short for HDMI Consumer Electronics Control, is an HDMI feature many TVs and peripherals have.
If the TV is connected to an HDMI or a programmed remote is being used on the cable box the TV may be getting a second command via the HDMI cable.(CEC) Suggest disconnecting the HDMI cable and manually turning on the TV and see if it will remain on with just a blue screen, Try changing the input to antenna-DVD etc and see if the TV remains on.
You may need to check the settings in the cable box or DVD to change the auto control(CEC) feature. Or if you prefer controlling the TV via the cable box remote then you would not use the TV remote for turning on and off.
This can get very confusing because the TV and the DVD or the TV and the cable box will interact between each other. The problem can be more confusing if the components are not exactly compatible with the CEC. Also many remotes have the additional feature of controlling other components in your AV setup. Many times the operation is alternate action. So each cycle of the remote the TV changes state from on to off. If the two components are out of sync than one is on and the other is off. In that case not using the master on off of the remote but using the individual component setting allows for the two to be sync again. (both off or both on)
Nov 15, 2015 | Sanyo Televison & Video
Where do I find the cec connection for setting timing?
cec.
timing of what, cam or spark.
what engine, is there.
Computerized Engine Control or Computerized Emission Control (CEC)
the 4.0L and 2.5 liter , uses the RENIX ecu. and not the CEC. tje REnix has fixed, CKP sensor timing.
the 4.2liter has distrib timing.
see below.
my guess is you have the instructions and
get lost at the find VACUUM switch on top of valve cover words?
yes?
Jun 28, 2015 | 1988 Jeep Wrangler
Is my Sony Grand Wega Consumer Electronics Control (CEC) compatible?
Consumer Electronics Control (CEC) What is Consumer Electronics Control (CEC)?
Consumer Electronics Control or CEC is a function that allows you to control multiple devices over HDMI using one remote control by having a secondary device receive commands from a primary device. Although CEC wiring is required for every HDMI port it does not mean that every HDMI port will have the function enabled.
If your device has the CEC function, this information will be located under your setup or settings menu.
To enable the function you will need to turn the CEC function on and then search for any devices that are CEC enabled that are connected to the TV.
Was this article helpful? 2 out of 4 found this helpful Have more questions? Submit a request
Related articles
Jun 13, 2015 | Sony Grand WEGA KDF-50WE655 50" Rear...
Is there an option to turn off cec. So I can use ir control .
Go into the menu on your device. Look for HDMI settings. There is normally an option to turn off HDMI CEC. A lot of manufacturers have their own name for CEC, so you may have dig a little to find it.
Feb 14, 2015 | Televison & Video
Yamaha purple screen rx-v373
I had this same issue. I think I finally resolved the issue by turning off HDMI Control (HDMI-CEC) on my Blu-Ray player. I had the Blu-Ray player plugged into a Yamaha RX-V375 (almost an identical receiver). I think the source of the issue was that my TV does not not support HDMI-CEC. Turning off HDMI-CEC on the Blu-Ray player fixed the issue. The Yamaha receiver already had HDMI Control disabled, and all the other HDMI devices appeared to have HDMI-CEC disabled or not supported.
In my case, the symptoms of the issue were that I would see the correct picture for a second on power up, then the picture would go away. For the Blu-Ray HDMI input selected on the receiver, I would see a solid purple screen and a blank screen for the rest of the inputs. Sometimes switching inputs fixed the issue, sometimes power cycling would fix it, but it was getting very annoying.
Dec 03, 2012 | Yamaha Audio Players & Recorders
I have Toshiba laptop with built in camera, but whenever i try to open the camera i recieve an error message 'CEC_Main.exe' reinstall. Kindly help how do i go about.
You also have Kasperkey ?
The error message 'CEC-MAIN.exe' is connected with the Camera Assistant Software,
You are unable to run the camera software because your KIS (Kasperkey Internet Security is blocking it by keeping "CEC-MAIN.exe" in the 'Untrusted File'.
Resolution:-
1) Launch your web browser
2) In the Notification Area (Down by your clock - Right click on the KIS icon and select "Pause Protection" > select "Resume manually"
3) In Notification Area: click on KIS icon elect "Applications under Control"
4) In the "Applications under Control" menu relocate "CEC-MAIN.exe" from the "Untrusted File" to the "Trusted File" - click "OK"
5) > Start > All Programs > CEC-MAIN icon to run your web camera program
Or My computer >> Local Disk (C) >> Program Files >> Camera Assistant Software Folder >> CEC-MAIN icon
Your webcam should now be running
Worth putting a shortcut on your Desktop at this stage .
6) With the webcam still running, then In notification Area - Right click on the KIS icon and select "Resume Protection"
7) Check the "CEC-MAIN.exe" in "Applications under Control" and confirm it is still in the "Trusted File"
8) Restart your computer
Aug 19, 2010 | Computers & Internet
Ceccmdll.dll cec-MAIN.EXE HAS STOPPED WORKING
Have you just installed a new security app such as Kaspersky?
If so you could so allow CEC_main.exe in the firewall which should cure the problem.
Sep 10, 2009 | Gateway Computers & Internet
HD Video Recorder - CEC connection with HDTV
My first question would be, Is your Panasonic HD recorder CEC compliant? CEC means Consumer Electronics Control. That simply allows for the consumer to have better control over their Home Theater set up through the connection of you HDMI cable from their remote control without programing the remote control for every single device that is connected. If your recorder is CEC compliant the television should have automatically recognize the recorder and control you recorder via remote control (I am assuming that your recorder is an HD Camcorder, since your description was very vague). Once you connect your HD camcorder to your panasonic tv the tv should have turned on switching to the correct input and the same for any other CEC comliant devices. If your Panasonic HD recorder is not CEC compliant the you would have to start viewing your recorder the old fashion way, by using the recorder remote control or if your Toshiba remote is universal punch those codes in so that you can control your devices that way. If that don't work, try a different HDMI input and select the input and make sure your recorder is set to output on you tv. Hope this helps.....before I forget, check out this site to learn more about Consumer Electronics Control (CEC) http://www.videsignline.com/howto/207400325
Nov 23, 2008 | Televison & Video
Users booket
Here ya go.
http://www.wellesley.edu/Knapp/Borrowinglaptops/PDFManuals/Cameras/740-Basic_Manual.pdf
Make sure you have Adobe Acrobat Reader installed.
It's 9.3 Meg in size.
Mar 07, 2008 | Olympus Camedia C-740 Ultra Zoom Digital...
Toshiba Satellite A205-S4587 Notebook Logo
114 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
