Question about EliteGroup 648FX-A2 Motherboard
Invalid filename when i open setup - EliteGroup 648FX-A2 Motherboard
    Problem Solver:
  • 7 Answers
You better find the cd oif the motherboard and install it
Posted on Jun 02, 2010
How do i fix an invalid path or filename error when saving
I answered this once, but it didn't seem to post. Invalid Path or Filename error is generated when a logo (.bmp) file is specified in the header or footer, but is not found in the default folder "Clipart," usually found under SureTrak in Program Files or Program Files(x86). Either set the logo in the footer to None, or copy and paste the missing .bmp file to the Clipart folder, then in the Footer (Page Setup, third tab) re-browse the logo setting to the correct location.
May 21, 2014 | Primavera SureTrak Project Manager 3.0 for...
Tip
Editing The Registry?
The Registry Editor (REGEDIT.EXE) is included with most version of Windows (although you won't find it on the Start Menu) it enables you to view, search and edit the data within the Registry. There are several methods for starting the Registry Editor, the simplest is to click on the Start button, then select Run, and in the Open box type "regedit", and if the Registry Editor is installed it should now open and look like the image below.
An alternative Registry Editor (REGEDT32.EXE) is available for use with Windows NT/2000, it includes some additional features not found in the standard version, including; the ability to view and modify security permissions, and being able to create and modify the extended string values REG_EXPAND_SZ & REG_MULTI_SZ.
Create a Shortcut to Regedit
This can be done by simply right-clicking on a blank area of your desktop, selecting New, then Shortcut, then in the Command line box enter "regedit.exe" and click Next, enter a friendly name (e.g. 'Registry Editor') then click Finish and now you can double click on the new icon to launch the Registry Editor.
Using Regedit to modify your Registry
Once you have started the Regedit you will notice that on the left side there is a tree with folders, and on the right the contents (values) of the currently selected folder.
Like Windows explorer, to expand a certain branch (see the structure of the registry section), click on the plus sign [+] to the left of any folder, or just double-click on the folder. To display the contents of a key (folder), just click the desired key, and look at the values listed on the right side. You can add a new key or value by selecting New from the Edit menu, or by right-clicking your mouse. And you can rename any value and almost any key with the same method used to rename files; right-click on an object and click rename, or click on it twice (slowly), or just press F2 on the keyboard. Lastly, you can delete a key or value by clicking on it, and pressing Delete on the keyboard, or by right-clicking on it, and choosing Delete.
Note: it is always a good idea to backup your registry before making any changes to it. It can be intimidating to a new user, and there is always the possibility of changing or deleting a critical setting causing you to have to reinstall the whole operating system. It's much better to be safe than sorry!
Importing and Exporting Registry Settings
A great feature of the Registry Editor is it's ability to import and export registry settings to a text file, this text file, identified by the .REG extension, can then be saved or shared with other people to easily modify local registry settings. You can see the layout of these text files by simply exporting a key to a file and opening it in Notepad, to do this using the Registry Editor select a key, then from the "Registry" menu choose "Export Registry File...", choose a filename and save. If you open this file in notepad you will see a file similar to the example below:
Quote:
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\Setup]
"SetupType"=dword:00000000
"CmdLine"="setup -newsetup"
"SystemPrefix"=hex:c5,0b,00,00,00,40,36,02
The layout is quite simple, REGEDIT4 indicated the file type and version, [HKEY_LOCAL_MACHINE\SYSTEM\Setup] indicated the key the values are from, "SetupType"=dword:00000000 are the values themselves the portion after the "=" will vary depending on the type of value they are; DWORD, String or Binary.
So by simply editing this file to make the changes you want, it can then be easily distributed and all that need to be done is to double-click, or choose "Import" from the Registry menu, for the settings to be added to the system Registry.
Deleting keys or values using a REG file
It is also possible to delete keys and values using REG files. To delete a key start by using the same format as the the REG file above, but place a "-" symbol in front of the key name you want to delete. For example to delete the [HKEY_LOCAL_MACHINE\SYSTEM\Setup] key the reg file would look like this:
Quote:
REGEDIT4
[-HKEY_LOCAL_MACHINE\SYSTEM\Setup]
The format used to delete individual values is similar, but instead of a minus sign in front of the whole key, place it after the equal sign of the value. For example, to delete the value "SetupType" the file would look like:
Quote:
REGEDIT4
"SetupType"=-
Use this feature with care, as deleting the wrong key or value could cause major problems within the registry, so remember to always make a backup first.
Regedit Command Line Options
Regedit has a number of command line options to help automate it's use in either batch files or from the command prompt. Listed below are some of the options, please note the some of the functions are operating system specific.
* regedit.exe [options] [filename] [regpath]
* [filename] Import .reg file into the registry
* /s [filename] Silent import, i.e. hide confirmation box when importing files
* /e [filename] [regpath] Export the registry to [filename] starting at [regpath]
e.g. regedit /e file.reg HKEY_USERS\.DEFAULT
* /L:system Specify the location of the system.dat to use
* /R:user Specify the location of the user.dat to use
* /C [filename] Compress (Windows 98)
* /D [regpath] Delete the specified key (Windows 98)
on Dec 02, 2009 | Computers & Internet
Is setup.exe.vbe safe to run?
probably not. .vbe means Visual Basic Encoded script. It seems as though someone tried to camouflage their script with a familiar filename (by prepending setup.exe in front of it. Is this on a CD or a file you received in email or downloaded?
Feb 04, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Suretrak 3.0b: When I go to page setup on some projects and change the parameters and click ok I get an error message ?Invalid path or filename?. It will not let me change anything in page setup. I have...
When I had this issue it was fixed by removing any references to a logo that was not valid anymore. Go to Page Setup-Footer and if any of the Footer Blocks reference a Logo you can either click on each one, which will bring up a Flie Path selection box, or remove any logos by hitting the down arrow and changing from Logo to none.
Aug 03, 2010 | Primavera SureTrak Project Manager 3.0 for...
PC CHARGE - "INVALID EXP. DATE" ERROR MESSAGE ON 2013 & LATER
when you have PC Charge open, go to Setup and Preferences. A window will open. In the "maximum/latest year" or something like that, change 2012 to something later like 2016. That should fix it
Apr 15, 2010 | Go Software Inc. PCCharge Payment Server...
Firmware update for netgear router
I was having the same issues too. I followed the steps dotted all over the internet and was getting stuck in exactly the same place. No matter how hard I tried, I just kept getting the 'invalid filename' issue.
Eventually I figured it out - the way that Netgear/Virgin have blocked firmware updating is to break the filename checking page so it doesn't accept any files. What we need to do is bypass the filename checking code so that the firmware upgrade system can then handle the file, and we're going to do this by manipulating the web page using a tool called Firebug.
Here is the solution:
1) If you haven't already got it, install Mozilla Firefox 3 (there is good reason for this - I'm not just shamelessly plugging it! :P).
2) Install the 'Firebug' extension for Firefox from https://addons.mozilla.org/en-US/firefox/addon/1843 and restart your browser when requested.
3) Navigate to your router's admin page, and fill in your login details (if you don't know them, it's likely to be the one written on the bottom of your router).
4) Navigate to the router upgrade page (the one where you select the firmware to upload' and select the location of the firmware file, like you would normally. Now, instead of clicking the 'Upload' button, press F12. This should bring up Firebug in the bottom quarter of your screen.
5) Now, click the moz-screenshot.png2193448.jpgbutton at the top of the Firebug panel and then click on the 'Upload' button. This will bring up the code for the upload button, where it does the filename checking. It'll look like this:
6) It looks like Netgear have actually stripped out the real checking code so it can't be used, so we'll need to fool the page into thinking everything's fine and dandy with the filename so it can update the firmware. Click where it says "return checkData();" and replace it with "return true;".
7) Finally, click the upload button. The router should now accept the file and start updating.
And hey presto! You have a non-nargled wireless router with the latest firmware!
Mar 13, 2009 | NetGear WGR614 Wireless Router
When I try to open a link or a file I get the microsoft works error
Gues you have created a shortcut for the aplication , try to location that is to Start > My computer > C drive and open directly from the location ..........
Oct 12, 2008 | Microsoft Works 8.0 for PC
I get an error 6 the handle is invalid
While running setup or autorun file directaly from the CD error msg comes as:- The handle is invalid
Email :- kumar.sanjit@mahindra.com
Jul 24, 2008 | Computers & Internet
You have sent driver for MFC240C how do I load it?
I apologize for not giving you the instructions for retrieving the file.
In Step 1 double click Drivers.
In Step 2 double click the operating system that you have installed.
In Step 3 double click the language that you need.
Click Search.
On the next page choose the package you want. I would suggest choosing the file in the Full Driver & Software Package.
To do this, find the section that you want to downland and click the More Information at the right of that row. On the next page you will need to click the Download link. You can also find installation instructions at the bottom of this page. On the next page you will need to click the Accept link. Once you click the Accept link you will be prompted to open or save the file. Click Save. Click the Save in: feild at the top and choose Desktop. Then choose Save at the bottom. Make note of the filename. After its finished downloading you will have an icon on your desktop that matches the filename you noted earlier. Once you find the file, just double click it to start the installation.
Thanks
Jul 24, 2008 | Brother MFC 240C All-In-One InkJet Printer
Invalid filename
I am having the same problem with mine it has even lost all pictures, ringtones and graphics even the default ones. I spent most of the day on Thursday on the phone with AT&T and none of the 10 people that I spoke to could help me they had never heard of this problem before and they said I would have to buy a new phone. I really like this phone and would like to fix it if I can but don't know what to do HELP!!!!
Feb 21, 2008 | Pantech C300 Cellular Phone
EliteGroup 648FX-A2 Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
