Question about Microwave Ovens
Cardboard in Oster OGF41101 microwave?
There's a piece of shiny cardboard covering a hole inside my Oster OGF41101 microwave...I didn't know what it's for but when trying to remove it it ripped...what's this for and do I need it?
3 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: Set up Oster Microwave
No, that is the "waveguide cover".
It provides very important protection for the magnetron.
And always keep it clean according to your manual's instructions.
Posted on Jan 18, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave turns on for 5 seconds, then shuts
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well your symptoms "Microwave turns on for 5 seconds, then shuts off".
Please also not whether the display stays on or shuts off.
The object you're describing is the waveguide cover. It needs to stay clean and secure. If it's damaged, it will need to be replaced.
It provides critical protection for the magnetron.
Posted on Nov 29, 2009
There is a piece of cardboard inside covering a metal panel, do I need to remove it?
Interior of microwave ovens are metal, never cardboard. Must be something used for shipping purposes, pitch it.
Jun 17, 2015 | Microwave Ovens
Is the mica cover crucial?
sad to say but YES it is critical . .
Mar 25, 2015 | In Microwave Ovens
My emerson microwave #mw8999rd shoots out fire from a silver piece of cardboard thats on the righthand inside of my microwave oven. whats with that?
There is electrical problem in your microwave heating circuit. This is a fire hazard and you should stop using this microwave and unplug from the outlet. This is not something you can fix and the fuse does not protect your system anymore. The best choice is to purchase a new one and throw this away.
Dec 06, 2011 | Emerson Microwave Ovens
How do I lay lino round the base of the toilet?
Mark out and cut the base of the bowl size, using a old Cornflakes packet is useful, cut the hole and behind the bowl part of the cardboard test piece cut to the edge in a straight line. The cardboard will now open (a bit like a keyring) and alow the cardboard cut out hole to be placed around the base of the toilet bowl. Trim it to fit perfectly.
When you have the exact size in you cardboard cornflakes packet, transfer the cut out on to your lino, cutting in a straight line at the rear of the lino where is will not be seen, to allow fitting over the bowl. Trim your lino edges and there you have it, lots of scrap cardboard but a professionally fitted lino floor covering.
I hope that helps.
Feb 03, 2011 | Microwave Ovens
On the inside top right side of the microwave there was a cardboard cover held on by 4 corner points. The cardboard has fallen out now as it has come unsecured from the points holding it in place. Is it...
That's the waveguide cover.
If your waveguide cover is burned or damaged, it will need to be replaced.
You should be able to get Galaxy parts from the Sears site.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
A full Galaxy/Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 06, 2010 | LG MS-0744Y Microwave Oven
Microwave keeps shutting off
The magnetron is overheating, tripping the thermostat, which shuts off all power until it cools down.
This is usually caused by a blocked air vent, failed internal cooling fan, or failing magnetron.
If it's out of warranty, I'm sure you'll find it's uneconomical to repair, even if you could get parts for this brand.
Good luck.
Dec 26, 2009 | Oster Microwave Ovens
IS MY MICROWAVE NOW UNSAFE TO USE - CAN I DO OWN HOME REPAIR?
It sounds like what you are describing is called a "waveguide cover". You can purchase a replacement from a local parts supplier, or on-line at www.repairclinic.com. It is very easy to replace.
Jun 30, 2009 | Microwave Ovens
What is the cardboard cover inside my microwave for?
It may not be cardboard - it may be a material called mica which is located over where the magnetron is located in the unit. This is a protective cover and if it is what I think it is, do not remove under any circumstances, otherwise you may render the microwave unsafe to use.
Mar 23, 2009 | Microwave Ovens
My Sanyo 1000W microwave is shooting sparks!!!
you need to replace the cavity cover "the cardboard like",the antenna bearing set "the gun barrel like" and the gear motor.If the "gun barrel like" is stuck up because the gear motor is not rotating excessive heat will occur inside the microwave thus burning the cavity cover.
Mar 20, 2009 | Sanyo EM-A5200SW Microwave Oven
Jan 18, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Microwave Ovens Logo
254 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
