Does no drain
Hello :-)
I have INDESIT WM 12x. After washing the washing machine has the water in. It does not drain so I can not get my clothes out :-( please help.
  • juliana_sabo Jun 02, 2010
    Hello :-)
  • 159 Answers
This could be a easy problem, check your drain hose is not kinked or blocked. put your mouth on out let of drain hose and blow hard if you can not blow stick something up to unblock if it unblocks from blowing great hope this helped
Posted on Jun 02, 2010
How to take out water pump
There are two ways of fixing drain pump depending on serial number of appliance. One easy mounting with three screws and the other is using the anchor tab where you should turn the drain pump counter clockwise and remove.
25602824-2cx31aa5jn1eijqkorrs11s2-4-2.jpg Also, follow this link:
http://www.espares.co.uk/advice/0/2308/indesit-washing-machine-pump-replacement-and-f11-error-
Dado
Mar 23, 2015 | Indesit Washing Machines
Indesit 657w
CHECK TO SEE IF THE DRAIN HOSE IS RAISED ABOVE THE REQUIRED HEIGHT. IF THE WATER IS OVER FLOWING THE TUB THEN IT IS USUALLY THE A BLOCKAGE IN THE PRESSURE SWITCH HOSE, OR SOME INABILITY OF THE WATER LEVEL SWITCH TO MEASURE THE AMOUNT OF WATER IN THE TUB.
Dec 23, 2013 | Washing Machines
How do I open a lock LG WM 1832 CW front end washing machine with water and clothes inside?
First you will need to get the water out and really the only way to do that if the unit won't drain it is to open the filter to get the water out and besides that, there is probably a blockage at the filter that is preventing it from draining in the first place. You will need a lot of towels handy or a wet/dry vac at the ready!
Nov 28, 2012 | Washing Machines
My WD 12X machine is not drying the clothes. They get hot but not dry. Is there a filter somewhere that needs to be cleaned?
Presuming that this is an Indesit WD12X.
Yes, there is a filter at the bottom left of the machine (It can be clearly seen in the illistration on Page 14 of the manual, figure 6).
If you don't have a manual, you can download a PDF of it here:
http://www.indesit.co.uk/indesit/_pdf/manuals/19503326500_UK-USA-AUS.pdf
It's highly likely that the water isn't getting evacuated because the filter is blocked and so there is just too much water to dry. Unscrew the filter, clean and replace. I'm amazed to discover that (so far as I can see) The manual never even mentions the filter! Well done Indesit
Jul 19, 2011 | Washing Machines
HELLO, we washed clothes and the soap would not clear and the clothes were still water logged. Now in trying to fix it, it will not drain, Not sure what to do terri
Drain the water out by using the small hose located behind the access panel on the lower left side of the washer's front panel. After removing water, un-screw the big knob to the right of the hose and pull it out to check for blockage in the filter. If blockage found, remove and re-try cycle. If no blockage found in filter, replace pump motor.
Sep 07, 2010 | LG WM-2277HW Front Load Washer
W/Machine won't drain or complete wash cycle (Indesit w1335)
The drain pump could either be blocked or seized? Check the "coin trap" for any foreign material which should be located at the front of the unit behind a small door/panel.
Jun 16, 2009 | LG WM-2277HW Front Load Washer
Water not draining although spin still ok. Then went bang!
Called out a plumber who diagnosed that the machine was not worth mending. He charged me £25. Now have new Indesit WM.
May 23, 2009 | Bosch Washing Machines
Indesit wm 12x
Sounds like the pump is blocked. Lost a sock lately?
Mar 13, 2009 | Indesit WA 115 Front Load Washer
Help!! Indesit WM12X - cold wash only
Yes, they are easy enough to replace, but you need to test them with a multimeter to see if they are faulty..
There could be other things wrong.
Nov 22, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
