Question about Candy CPC220 Bottom Freezer Refrigerator
Light comes on, no sound, fridge rapidly
Candy cpc220 fridge freezer. Light comes on, no sound, fridge rapidly defrosting. Been told its the thermostat but don't know where it is. any suggestions?
  • Candy Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerLight comes on, no sound, fridge rapidly - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 04, 2010
Fridge not cooling, compressor running constantly
is the evaporator fan running ? good luck APPLIANCES R EN
Mar 15, 2013 | Candy CPC220 Bottom Freezer Refrigerator
Why is my fridge freezing up in my candy fridge freezer
Hello there,
The reason your fridge is freezing up is simply because there is a problem with the defrost unit of the refrigerator. The defrost thermostat simply could have gone bad and therefore is not getting the defrost heater to start work.
Have the defrost thermostat tested and replaced once found faulty.
Hope this was of help to you. All the best Elect_Comp
Sep 26, 2011 | Candy CPCA240FFK Bottom Freezer...
My freezer is producing to much ice causing the door not to shut properly
The fridge needs a DEFROSTING and then the thermostat must be kept to a lower level so that the frost formation is low.
Jun 17, 2011 | Candy CPC220 Bottom Freezer Refrigerator
I have a candy frostfree fridge freezer GL90AA; it never switches off,i.e. I can hear it run all the time.
If it is not reaching the cut off temp because
the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everythinghttp://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 08, 2009 | Candy CPCA240FFK Bottom Freezer...
Fridge Icing up on N1B Candy frost free fridge freezer
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Sep 02, 2009 | Refrigerators
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Candy fridge freezer
it should come back after about 20 mins only and should cool back after about 10 mins.
i'm afraid the buzzing sound could be coming from your compressor which can not start. the over current relay is tripping off after 20 seconds to prevent the compressor from burning up.
i suggest to unplug the ref, let it cool for 1 day, re plug it after a day and observe the compressor if would run.
if the buzzing sound is still there and the unit is no longer cooling, then the compressor is not running.
check the relay of the compressor. it could just be the relay.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
Candy CFC 290 FF
Candy frost free freezers have a 'self defrost' mechanism to remove excess ice build up. What happens is the ice gets packed around the heat exchanger in the back of the freezer and it can't self defrost. This is easy to fix but will require the fridge to be left switched off with the door open for a couple of days so all the ice can melt. Make sure you left the appliance off for as long as you can as if there is any ice left the problem will just come back.
Aug 30, 2008 | Candy CPCA270FFK Bottom Freezer...
sounds like a defrost problem it could be one of the following:derost timer,defrost therm. or defrost heater
Dec 03, 2007 | Freezers
Candy CPC220 Bottom Freezer Refrigerator Logo
168 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Billy Detlefsen
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
