Question about SoftMath Algebrator - Algebra Homework Solver (689076614429)
Solve for x : 4x+9=6x-13 - SoftMath Algebrator - Algebra Homework Solver (689076614429)
  • valvestem Jun 02, 2010
    Learn my son.
    President:
  • 1,138 Answers
The answer is 6..
please rate this solution..thanks
Posted on Jun 02, 2010
All three sides of a triangle are equal in length of one side is 2x+5 and one side is 4x-3 find the perimeter of the triangle
If all sides are equal then 2x + 5 = 4x - 3
2x = 8
x = 4
so the perimeter is 3 times either expression above
3 * (8 + 5) = 39
Jan 12, 2017 | The Computers & Internet
Y=-3/4x+13
Assuming we're dealing with the straight line y=(-3/4)x+13. the y intercept is 13.
If we're really dealing with the hyperbola y=-3/4x+13 then there is no y intercept since there's a vertical asymptote at x=0.
Mar 20, 2014 | Computers & Internet
How to find the polynomial roots in TI-83 Plus
One way is to use the Polynomial Root Finder and Simultaneous Equation Solver app.
Press the APPS key, then select PlySmlt2 and press ENTER. Press ENTER to get past the opening screen, then select "POLY ROOT FINDER" and press ENTER. Select the order of the polynomial and other settings as desired. Press F5 (the GRAPH key) to go to the next screen. Enter the polynomial coefficients, then press F5 to solve. The next screen will show you the roots (unless you selected real roots and the polynomial doesn't have any real roots).
If you don't have the app installed, you can download it from
http://education.ti.com/educationportal/sites/US/productDetail/us_poly_83_84.html
Jan 20, 2011 | Texas Instruments TI-83 Plus Calculator
4x-y-2z=-7 -4x+8y+5z=46 8x-3y+z=13
Type solve(exp1 and exp2 and exp3, {x,y,z})
See cap images
Dec 15, 2010 | Texas Instruments TI-89 Calculator
Give an example of a linear equation, solve it, and then check your work. Explain step-by-step what procedures you used and upon arriving at a solution, carefully check to see that your solution is correct...
4x+7=11 Solve for "x".
subtract 7 from each side of the equation
4x +7(-7)=11(-7) = 4x=4
divide both sides of the equation by 4
4x/4=4/4
therefore
x=1
Correct?
Dec 06, 2009 | 2006 Harley Davidson FXDI35 35th...
For instance if I have a problem of 4x+1-x=2x-13+5. how do I enter it in my T E to find wha is X
This calculator does not have a Solve function or a solver. However this example of yours is very simple that you can do it by hand. If you do not mind I will show you how to solve it. Not everything needs a calculator.
You want to solve for x. OK
  1. Start by gathering similar terms 4x-x =3x; -13+5 =-8
  2. Rewrite your equation as 3x+1=2x-8
  3. Make the +1 change side while changing its sign
  4. 4x+1 -1 = 2x-8 -1 or 4x=2x-9
  5. Make +2x on the Right hand side go to the left hand side, changing its sign in the process 4x-2x=-9 or 2x=-9
  6. Divide both members by 2. This gives
  7. x=-9/2 or -4.5 if a decimal result is required.
Hope it helps.
Dec 06, 2009 | Texas Instruments TI-30XA Calculator
4x+3y=6 how do you solve for y
I am not lecturing you but I would rather you understand how to do the manipulations involved in isolating a variable.
You want to isolate y, Ok
Start stripping it of all that is not y.
3y + 4x =6. (Addition is commutative, I can change the order of addition)
The term with y is added to 4x. If I want the term in y alone on one side I perform the inverse operation of addition, a substraction. I subtract 4x from both sides.
3y+4x-4x=6-4x. But 4x-4x=0, and we are left with
3y= - 4x+6
This operation is sometimes summarized as make one term change side while changing its sign
It would do no harm to put the right side of the foregoing equation in parentheses. I do that to avoid errors)
3y= (-4x+6).
Now y is multiplied by the number 3. To isolate y I have to perform the inverse operation of the multiplication, namely the division by 3
3y/3 =(-4x+6)/3. The left hand side is just y
y= (-4x+6)/3.
While result is correct, I can also open the parentheses
y= -4x/3 +6/3
y= -(4/3)*x +2.
Hope it helps.
Oct 22, 2009 | Texas Instruments TI-89 Calculator
Find the value of the variable ''x'' 6x+6=4x+12
6x+6=4x+12
Since 4x contains the variable to solve for, move it to the left-hand side of the equation by subtracting 4x from both sides.
6x+6-4x=12
Since 6x and -4x are like terms, add -4x to 6x to get 2x.
2x+6=12
Since 6 does not contain the variable to solve for, move it to the right-hand side of the equation by subtracting 6 from both sides.
2x=-6+12
Add 12 to -6 to get 6.
2x=6
Divide each term in the equation by 2.
(2x)/(2)=(6)/(2)
Simplify the left-hand side of the equation by canceling the common factors.
x=(6)/(2)
Simplify the right-hand side of the equation by simplifying each term.
x=3
Good Luck
Sep 10, 2009 | Audio Players & Recorders
Algebra
Paul 3 years younger to his friend peter. In seven years, the product of their ages would be 5 more than the product of their ages 5 years ago. How old are they now?
Oct 31, 2008 | Texas Instruments TI-30XA Calculator
Computers & Internet Logo
177 people viewed this question
Top SoftMath Computers & Internet Experts
k24674
ali_zulfikar
ali_zulfikar
Starnley Johnwells
Starnley Johnwells
Are you a SoftMath Computer and Internet Expert? Answer questions, earn points and help others
