I have a maxell 1gb memory stick with security been using for several years but now it will not open on my windows vista laptop. I get a windows solution message saying can't find a solution . Anyone know how I can open it. Theres a password on it but I can't get to that.
    Sergeant:
  • 269 Answers
Sadly i will say to you, it wont open, i have personally had it done to me and the cauteous person i am i still have it.
It wont open sorry
Mel
i even called sandisk on mine
Posted on Jun 02, 2010
Maxell 4gB stick - no response
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Mar 19, 2012 | SanDisk 4GB Memory Stick Micro M2 Memory...
My memory stick Pro is not detected by my laptop, under My computer i dont find the memory stick pro at all... please help
Check to see that the memory stick is installed correctly. If it IS, and you are using Windows XP or Vista, then look under Administrative Services\Tools under the Start menu and select Computer Management. Make sure that the PlugnPlay service has been set up under automatic and that it has been started. The screen will show you a large selection of services and how they are programmed to start. Your computer will read your stick after the correct service, PlugnPlay, has been started. Please comment if this solves your problem. Thanks,
Sciencewoman
Apr 01, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
When I plug my Maxell 8Gb 360 usb thumb drive into my computer at work, which is running XP, the OS can see the whole 8Gb, but I cannot put a 4Gb file on the stick. However when I use my windows 7 laptop...
Your PC is infected ,which is running for XP 7and you should remove the virus.
Please download f-secure bootable disk and clean at the time booting.
How will you confirm?
Follow the steep. Press win key +R >type gpedit .msc and soon an windows will open.
Press win key +R>ms config and soon an windows will open.
Press win key + R REGEDIT an windows will open soon.
Go to tools option >folder option >view>check on show hidden file
Check off hide protected operating system file
Check off hide extension known type file.
BUT still there are no hidden file in drive C:
Think your computer has affected by serious virus.
start>program>accessories>system tools >system restore >set earlier date. If you have the strong
virus you can not do that.
You will take more infomation click here
Hope it will help you.
Good by
Jan 06, 2011 | Maxell 8GB USB 360 USB 308 - 503202 Hard...
Hi Dear ; When I install memory RAM of 1.0GB .. get ERROR
Cant find your motherboard on the support page, is the memory your trying to install the same speed?
Jul 16, 2010 | Intel Computers & Internet
Maxell 8Gb Venture flash drive not installed correctly on Windows Vista Home Edition - displays as secure 1Gb drive also impossible to write to.
If you are given a CD along the flash drive you can try installing the drivers and try back plugging in and using it. That might work.
Regards
Feb 22, 2010 | Computers & Internet
Have Sony 1GB memory stick "magic gate" that wont open on my laptop vista
ok
try
these steps:
1.plug your pen drive 32gb in your computer.
2.then open Control panel.
3. open administrative tools.
4.open Computer Management
5. a window label computer management will appear.
6. click disk management
7.locate you pendrive and select delete partition or format it fat 32 or other format convenient for your usage.
ok
hope this will help
cheers
uttam
Jan 17, 2010 | Lexar JumpDrive Classic Portable USB Data...
My usb 4gb flash don my computer only reads in a secure K with 1m
See http://www.maxell.eu/FAQ2/FAQ.html
Venture USB contain two partitions - one named 'Public' and the other 'Secure'. Unfortunately we have noticed a compatibility problem between these drives and some computers running Windows Vista. In these cases only one drive is showing in 'My Computer' - usually the 'Secure' drive. As a result you are unable to access the user manuals and software which are in the 'Public' drive and cannot alter the partition sizes to allow access to the entire capacity.
Please follow the below instructions to resolve the problem:
1. Connect the USB to the computer
2. Please unzip and run the attached program
3. After completion please unplug the USB
4. Re-insert the USB to the USB port
5. You should now be able to access both drives.
Please click here to download the program and instructions
Dec 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My Pc/Laptop (vista) is nolonger recognising my Sony memory stick duo adaptor; I have used it in the past 2 years but for some reason I cant get any of my photos or movies off it!?!?! ahhhhh.... please...
have you tried it on other computer, if not yet try it if it work there, then theres a problem with the port or card reader that you use, if it did not work there then your memory stick has reach it service life
Nov 23, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
I want to transfer files from an old desktop running Windows 98SE to a new laptop running Windows Vista Home Basic. I have bought a Maxell 2Gb memory stick: gone to the Maxell eu site and downloaded - as...
It should be unzipped and path to the unzipped folder provided while installing new hardware, when Windows (after plugging in the stick) finds a new plug&play device and asks for the location of drivers.
Also, go to your newer computer and check the USB stick's drive properties - it should be formatted using the FAT or FAT32 file system. If it's formatted using NTFS, Windows 98SE will not see it.
Nov 04, 2009 | Electronics - Others
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
