Question about JBL DSC 1000 Theater System
The dvd inside my dsc 1000 won't eject!! - JBL DSC 1000 Theater System
Where is the DVD emergency eject hole for DVD724?
If there is an eject hole, you should be able to see it on the front of the drive.
Dec 08, 2017 | Philips DVD724 DVD Player
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
Apr 10, 2013 | Apple Televison & Video
My dvd on my rtd325w won't open
find any small size hole near the dvd loader then inert the broom stick inside the hole and then pull automatically the eject
Dec 23, 2012 | RCA Audio Players & Recorders
LG v181 won't eject - it tries to load even when there is no disc and won't slide out the tray at all.
It's likely a belt that drives the tray has snapped or come off! If you take the top off you might well see it!
Dec 23, 2012 | LG V181 DVD Player/VCR
The dvd starts for a moment and the ejects
Hello
The sled motor of your dvd mechanism has damaged. Sled motor is one which spins the DVD inside as it has been loaded. If this motror does not work, that is, it has been stopeed, the disc won't spin inside the machanism, and your systems main control IC will detect this situationan; will give commat to the mechanism to eject the disc. That is happenig now with your DVD player. Replace that motor with an identical one both in size and number. Its number will be printed on its body. You can see and detect its size. OK.
Jun 29, 2011 | Televison & Video
E Machines T3302. DVD will not eject. In hitting the eject button, or right clicking on e-drive for DVD, and clicking on "eject", it sounds like it is trying to eject, but it won't eject....
On the dvd rom drive sound slike it catching on something on the inside stoppin git from ejecting you will have to use a flat head screw driver poke it from the top and very gently pry it open while pushing the eject button as soon as it ejects you can then remove any cds inside it and you can remove the dvd rom drive bezel and close it if it opens and closes freely while this dvd rom bezel is off then the piece of plastic you took off it is slightly made wrong you can get these bezels cheap or by finding an old rom drive and removing that one to replace with yours. any additional questions please use the comment box below Kronoguy
Jun 29, 2011 | E-Machines Computers & Internet
Grundig GR1000 DVD won't eject. Motor makes whirring noise but no action.
It could be either a gear or belt driven motor, you need to remove the top cover to check. If it is belt driven you can replace the belt make sure to take the sample with. If it is gear driven you need to replace the whole carrige unit.
Jun 02, 2011 | Grundig GR-1000 DVD Player/VCR
My cd/dvd drive is not working.
You could reinstall the CD/DVD drive software, but it sounds like the CD/DVD drive is faulty. You'll need to replace the drive.
Jun 12, 2009 | Averatec 1000 Notebook
JBL DSC 1000 Theater System Logo
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
