If mail send to your Gmail-Address disapper:
- check your Spamfolder
- Mail settings -> forwarding -> check if the mail gets forwarded
- Mail settings -> filters -> check if there is a filter affecting it.
Gmail is not deleting any mail without your permission.
Sign in your account and go to INBOX section of your account, all your mails will be displayed to you. If u want to check your sent mails, go to "Sent mails" of your account, all your sent mails will be displayed to you.
It's possible that their e-mail service is automatically putting your e-mail into a "Junk Mail" folder because of your yahoo.com e-mail address. Have them check for your e-mail in this, or similarly named folder.
Another way to help ensure delivery is for them to add your e-mail address to their Address Book. Many e-mail services treat this as a "White List" meaning any e-mail received from an e-mail address found in the recipient's Address Book is a known "good" e-mail and is not spam / junk e-mail.
Finally, check to make sure you have your friends' correct email addresses.
The next time you try to send an e-mail, cc yourself using your own e-mail address. This way, you will know if your e-mail was properly sent and the problem is somewhere on the recipient's end.
in your e-mail account settings check that your outgoing mail server setup is correct. the mail server will look something like 'mail.host.com'. check with your e-mail provider if you don't know the mail server settings.
In the text box labeled Display Name, type your name and click "Next."
In the Email Address box, type your Yahoo! Mail address (be sure to include "@yahoo.com") and click "Next."
Under "My incoming mail server is a…" select "POP3."
Type "plus.pop.mail.yahoo.com" in the Incoming Mail (POP3, IMAP, or HTTP) Server box.
Type "plus.smtp.mail.yahoo.com" in the Outgoing Mail (SMTP) Server box.
Click "Next."
In the Account Name box, type your Yahoo! Mail ID (your email address without the "@yahoo.com").
In the Password box, type your Yahoo! Mail password.
If you want Outlook Express to remember your password, check the "Remember password" box.
Do not check the boxes labeled "Log on using Secure…"
Click "Next."
Click "Finish."
Select 'plus.pop.mail.yahoo.com' under 'Account,' and click 'Properties.'
Click the “Servers” tab.
Under “Outgoing Mail Server” check the box next to “My server requires authentication”
Click the 'Advanced' tab.
Under “Outgoing mail Server (SMTP)”, check the box next to “This
server requires a secure connection (SSL). Enter port number “465” in
the “Outgoing mail (SMTP)” field.
Under “Incoming mail (POP3)”, check the box next to “This server
requires a secure connection (SSL)". The port number in the “Incoming
mail (POP3)" field should automatically change from 110 to 995. If it
doesn’t, make sure the port number is set to 995.
step 1:
Try to check the mail using a browser(internet explorer). check whether that domain is under blocked list or not. Click on mail options and go to blocked domain list. check in your mails as well as your sister's mail.
step 2:
You can also check the blocked list in outlook :
click tools menu -> select options -> preferences tab ->click junk mail button-> click blocked senders tab -> check for any domains listed there.
I had the same problem, but what I did was so helpful. I changed my mail to "Mail Classic" and I have no problem. I hope it works for you, too!!!!!!!!!!!!!!!!
You can add additional (POP) accounts in Outlook 2003. Or if you still prefer OE (from help.yahoo.com):
Here's how to "POP" mail from Yahoo! Mail Plus into your Outlook Express:
From the Tools menu, choose "Accounts."
Select the "Mail" tab.
Click the "Add" button.
From the Add menu, click "Mail."
Click "Next."
Click "Next."
Click "Finish."
Under “Outgoing mail Server (SMTP)”, check the box next to “This server requires a secure connection (SSL). Enter port number “465” in the “Outgoing mail (SMTP)” field.
Under “Incoming mail (POP3)”, check the box next to “This server requires a secure connection (SSL)". The port number in the “Incoming mail (POP3)" field should automatically change from 110 to 995. If it doesn’t, make sure the port number is set to 995.
