Question about GPS
I just got an Airguide auto dashboard compass. How do I calibrate it? And what battery is need for the light? I tried a AAA but the top won't close. HELP PLEASE!!!!!!!!!
  • gingit96 Jun 02, 2010
    I still cannot get the Airguide working properly. And I still please need the answer to what is the gold line on one side of the dome of this Airguide auto compass. PLEASE PLEASE HELP. Even if I can figure out approximate north - the directions just don't make sense to me.
  • 3,083 Answers
I couldn't find any information about the battery, but here is a blog about calibrating the compass:
ADJUSTING THE COMPASS
DO NOT USE STEEL SCREWDRIVER (THIS WILL AFFECT THE COMPASS MAGNETS) USE A DIME TO TURN REGULATOR SCREWS
1. Head North. Turn the regulator marked NS, very slowly, until the dial reads either N or S.
2. Head East. Turn the regulator marked EW, slowly, until the dial reads E.
3. Head South. If the compass does not read exactly on "S" -- Then turn the NS regulator just enough to remove only one-half of error.
4. Head West. Turn EW regulator just enough to remove only one-half of the error. Follow the same procedure as in step 3.
I'm not sure what the problem is with the battery. I saw units that took the AAA battery, so it might be a question of seating the battery fully into the compartment. Did the unit have a AAA in it before? My suggestion would be to take it into an Auto Shop or Boat Shop- they will often know about the unit, and how to replace the battery. Without being able to see the unit, that's all the help I can offer. Good luck, and hope this helps.
Posted on Jun 02, 2010
  • 2 more comments
    That's what was sent to me before - but it doesn't help. Also -
    and I repeat - there is a gold vertical line on one side of the
    dome. What is it for? Do you actually know the item/
  • Lynn Eldridge
    Lynn Eldridge Apr 23, 2018
    You need a carbon zinc battery, NOT alkaline! The compass magnet will be messed up by alkaline battery. I got my batteries on eBay, $4.95 shipped for 4 AAA Evereadys, carbon zinc. The battery case is Ground. You need to cut about 1/16” of the paper away at the positive end. Gently place the spring over the base of the bulb. Then place the battery, positive end, in the other end of the spring. Be SURE the spring contacts the battery case where you cut the paper away! Put the bulb/spring/battery assembly in the clear plastic tube. Bulb will protrude out the front when you put the tube into the compass. Replace the square black cover on back of the compass. Press the bulb, light should come on. The bulb is a number 112, also avail. Online. Good luck!
  • Lynn Eldridge
    The gold vertical line is your direction indicator! If the letter “S” is behind the gold line, you’re heading South!!
  • Lynn Eldridge
    I use a souvenir flattened copper penny to turn the calibration screws. Big enough to grasp, thin enough to seat in the adjusters, doesn’t harm the compass!
  • 2,069 Answers
*To Calibrate the compass,
* 1. Head North. Turn the regulator marked NS, very slowly, until the dial reads either N or S.
* 2. Head East. Turn the regulator marked EW, slowly, until the dial reads E.
* 3. Head South. If the compass does not read exactly on "S" -- Then turn the NS regulator just enough to remove only one-half of error.
* 4. Head West. Turn EW regulator just enough to remove only one-half of the error. Follow the same procedure as in step 3.
For Battery, it is surely AAA. check properly your fitting.
Regards
  • 1 more comment
    OK - I had seen those directions on-line - but how do I truly know what is precisely
    north?? And there is a line on the plastic dome - what is that to indicate? The
    directions you gave (and I saw online) are totally confusing. Can you please be
    clearer about what to do? I'm generally quite good at instructions - but these are
    just not helpful. HELP!
    Thanks.
  • Muzahura Frank Jun 02, 2010
    Instructions are ok. and for the north issue, check here.
    What is the line on one side of the dome of the compass for?
My 2007 checy impala read "calibration complete" what does that mean ????
CALIBRATION COMPLETE
Refer to Electronic Compass Calibration do you have an owners manual ?
Compass Calibration
The compass direction will show CAL if it needs to be calibrated. Before calibrating the compass, drive the vehicle to an area that is magnetically clean (free of large metallic objects).
  1. Turn ON the ignition.
  2. Before calibrating the compass, make sure the compass is set to the variance zone in which the vehicle is travelling. See Compass Magnetic Variation Adjustment below.
  3. Press the vehicle information button until the PRESS TO CALIBRATE COMPASS screen is displayed.
  4. Press the set/reset button to start the compass calibration.
  5. The DIC will display CALIBRATING: DRIVE IN CIRCLES. Drive the vehicle in circles at less than 8 km/h (5 mph) to complete the calibration. The DIC will display CALIBRATION COMPLETE when the calibration is complete.
Oct 02, 2016 | 2007 Chevrolet Impala
How to "Turn" a Centrios digital compass mod. 63-8162
It is a fun thing calibrating a vehicle compass. Find a large EMPTY car parking lot. Press the Calibration buttons and drive in 10 tight circles clockwise and then 10 tight circles anticlockwise. The light on my compass flashes as you start the circles.
May 31, 2016 | Cars & Trucks
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
Compass direction wrong
Compass Calibration
Before calibrating the compass, drive the vehicle to an area that is magnetically clean or free of large metallic objects. Verify there are no magnetized objects on the inside or outside of the vehicle close to the mirror.
Start the engine.
Press and hold the switch for the compass, which may be depicted as COMP, COMPASS, or On/Off (w/UE1) depending on the type of mirror on the vehicle, until the letter "C" or "CAL" is displayed.
Drive the vehicle in circles at a speed of less than 8 km/h (5 mph) until the "C" or "CAL" is replaced by a proper vehicle heading. The calibration procedure is now complete.
Magnetic variation adjustments are required when the compass displays a constant error in heading. Variation is the difference between magnetic north and true north due to geographical location.
Nov 09, 2010 | 2004 GMC Envoy
Built in electronic compass on 2004 GMC Envoy is giving the wrong directions
Try the following;
Compass Calibration
Start the engine.
I have an opel corsa lite, Today I tried to switch...
You probably need a new battery. All cars require that the battery be replaced every 5-10 years. If you have AAA, they can come out and replace it for you. If not, you may have to get the car towed to the nearest auto shop.
Dec 23, 2017 | Cars & Trucks
How can i calibrate my phone
iPhone 3GS has a built-in digital compass that works just like a magnetic needle compass. The accuracy of digital compass headings can be affected by magnetic or other environmental interference, including interference caused by the close proximity of the magnets contained in the iPhone earbuds. The compass may need to be calibrated from time to time. iPhone 3GS alerts you whenever calibration is needed. To calibrate, hold iPhone 3GS in your hand and move the device in a figure 8 motion until the calibration screen disappears. The digital compass should only be used for basic navigation assistance and should not be solely relied on to determine precise locations, proximity, distance, or direction.
Nov 14, 2009 | Apple iPhone 3G
I have 2002 Yukpn Denali XL. There is a OC code that appears in the rear view. What is the cause of this and how can I fix it?
The "OC" indicates your compass is "Out of Calibration". Below is the proceedure to recalibrate your compass.
Compass Calibration
The compass may need calibration if:
 After five seconds, the display does not show a
compass heading (N for North, for example), there
may be a strong magnetic field interfering with the
compass. Such interference may be caused by a
magnetic antenna mount, magnetic note pad holder
or a similar magnetic item.
 The compass does not display the correct heading
and the compass zone variance is set correctly.
In order to calibrate, the letters CAL must be displayed
in the mirror compass windows. If CAL is not
displayed, push in the COMP button for approximately
eight seconds or until the letters CAL are displayed.
The compass can be calibrated in one of two ways:
 Drive the vehicle in circles at 5 mph (8 km/h) or less
until the display reads a direction, or
 drive the vehicle on your everyday routine and after
several turns the compass will become calibrated and
will display a direction.
Good luck.
Oct 23, 2009 | 2003 GMC Yukon XL
Garmin HCx GPS unit
The Vista HCx has an electronic compass. You don't need to be moving for it to work, but you do need to calibrate it. To calibrate the compass:
  1. Go to the Main Menu
  2. Select Setup
  3. Select Calibration
  4. You will be asked "Which Sensor Would You Like To Calibrate", select Compass
  5. You will see a page that says "To Calibrate Compass: Slowly Turn Two Full Circles In The Same Direction While Holding The Unit Level", select Enter and do this.
You need to hold the unit level for the Magnetic Compass to work correctly. The specs for a properly calibrated compass are +/- 5°
May 15, 2008 | Garmin eTrex Vista HCx Handheld GPS...
Compass dosent work
The compass is very sensitive. Anything magnetic will intefere with its ability to calibrate. Try taking the unit outside, far away from anything metallic, and lay it down on a flat level surface, then follow the compass calibration procedure. Make sure you rotate the unit clockwise and turn it very slowly. If that doesn't work, you could have a defective sensor.
I'm not sure what you're using the compass feature for, but on mine I disable it. It draws the batteries down faster and I find that my track, or course over ground, is more reliable than the compass heading. The only real advantage to the compass is if you want to get a bearing while you are standing still.
Feb 08, 2008 | Garmin GPSMAP 60CSx GPS Receiver
GPS Logo
1,739 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
