Question about LG 37LG60 37 in. HDTV LCD
Lg scarlet 37'' Hdmi audio input to av2 Output (dvd surround)
How do i get my hdmi audio to my dvd surround that is plugged into the av2 port on my Lg scarlet 37'' tv? I get surround from my virgin box (plugged into av1) and from the tele itself but when i switch to hdmi there is only sound to the tele and not the surround. On my old lcd tv i had an option in the menu as to which audio in i wanted to play through av2. I had to change this everytime i switched to hdmi but at least i had the option. I have trawled the menus and cant seem to find anything at all..
  • 244 Answers
SOURCE: AV1 / AV2 Connections don't work
No picture or dark picture
Check R516 (56Kohms, 0.5w) or R517 (27Kohms, 0.25w) for high
Will not come out of standby, no picture
If at power on voltage on pin 37 of the micro drops low then reverts to 5v suspect memory chip ICA07 (Toshiba 23319016)
No picture No sound
Faulty IC TDA6107q on crt board
No picture on e-e, I.F output ok
This was due to switching chip IC3901 (M51292FP) on the scart panel
Posted on Nov 26, 2007
  • 979 Answers
SOURCE: Unable to display HDMI Input
Okay so you have the HDMI cables from both the DVD and the Cable box plugged into the reveiver?
Posted on Feb 28, 2008
SOURCE: LG 42Inch lcd tv and LG ht963pa surround home theater
most programs don't have the 5.1 so you won't hear it
Posted on Oct 19, 2008
  • 458 Answers
SOURCE: LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Posted on Apr 18, 2009
enoch_cog80
  • 33 Answers
SOURCE: no sound through surround
this is because the home theater receives 5.1 channel... change it it will work...
Posted on May 18, 2009
I just purchased a roku streaming stick HDMI. I'm suppose to plug it into the surround sound HDMI (in) and then plug another HDMI (out) to the TV. The problem is, the receiver only has 1 HDMI port (ou
I hear you. Don't modern, inexpensive products just tick you off? Here's the solution. You leave it plugged into the the TV in HDMI 2. Because the receiver only has an HDMI out connection, you will have to use the digital output from the TV(usually an Optical cable), and plug it into any input on the receiver that has an Optical input. When you switch to that input on the receiver, you should be set, however, if you still have no sound, most AV receivers have assignable inputs. You may have to go to the audio menu on the receiver, and reassign that particular input as digital, and not analog. If you need more assistance, it would be best to visit my website at audioserviceclinic.com. and contact me there.Thank you.
Dec 22, 2014 | Philips HTS3544/37 Theater System
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
I installed a HDMI cable and an Optical cable to whatch movies and shows from my LG HD LCD TV, but nothing seems to work. The stereo is also a LG LHB336 system. Which is compatible with the TV. We were...
Hi,Even though you have done some cabling already,for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 24, 2011 | LG 42LC2D 42 in. LCD HDTV
I tried hooking up my laptop to my 37lh20 tv. I connected the avi to the pc input and an audio cable fro the headset jack on the tv. If I put the tv input on rgb pc I get the picture but no sound and if...
Unless you hook HDMI to HDMI, you won't carry sound across the HDMI cable. If you're using a VGA to HDMI converter, you'll get the picture but no sound.
I have a feeling the headset jack on the TV is an output rather than an input. Most TVs accept HDMI, RCA, or a digital audio input (either coaxial or optical). Unless you have a S/PDIF optical output from your laptop (and you obviously don't have an HDMI output), then your only other choice is likely to get a cable that splits a 1/8" headset type connector into two RCA plugs that you'll plug into an AUDIO IN input on your TV.
Jul 14, 2011 | LG 37LH20 37 in. LCD HDTV
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
Jun 25, 2011 | Audio Players & Recorders
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
I want to connect my denon 790 to my 5:1 surround, HDMI DVD player and HD samsung 55'' LCD. what cables do i need and where to put them. thanks
You will need 1 HDMI cable to link between your DVD player and the Denon,plug the HDMI cord into the HDMI port on the back of your DVD player and the the other end into the Denon 790 HDMI port labeled DVD,then you will need another HDMI cord to go between the Denon and your LCD TV,plug one end of the HDMI cord into the Denon 790 HDMI port labeled HDMI monitor out and the other end into one of the HDMI ports on the back of your TV, it doesn't matter which one you use, just remember that you will have to change the input on the tv to that specific HDMI port when you play back a DVD and you will also have to change the Denon to DVD as your source to send the audio through the Denon to your surround sound speakers.( The Denon owners manual will help!!)
Nov 26, 2009 | Audio Players & Recorders
Audio on HDMI(2) output with external audiocord?
The audio from the hdmi out on your computer is turned off. Try connecting another device such as a dvd player to the hdmi input on your tv . If audio works on tv then you know no audio is not available from the hdmi output on you computer.
Nov 21, 2009 | LG 42PC1R 42 in. Plasma HDTV
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Sep 11, 2009 | Audio Players & Recorders
I have the LG Dn798 hooked up through my Yamaha receiver
Does it work via component or in a different HDMI port? If it does it sounds like either a bad HDMI input on the tv or a bad HDMI output on the receiver.
I would also verify that the receiver is 100% compliant with the HDMI standard as not all devices are.
Jun 03, 2009 | LG DN798
LG 37LG60 37 in. HDTV LCD Logo
233 people viewed this question
Computer Repairing
Computer Repairing
