Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Cycles Can't find manual, need to know what the normal cycle does, both racks, pots & pans. What is the best setting for full load.
  • 56 Answers
Normal cycle is the best load for normal loads you should be able to go to frigigdaire.com and print a manual
Posted on Jun 02, 2010
Wy is top rack not washing
top rack is for small plates & cups not pots & pans as they may obstruct the rotating of the sprayer & foul the water from getting to all the items
Aug 31, 2014 | Bosch Dishwashers
Frigidaire FFBD2403LW normal cycle hum
Hello ddux97 - Often this occurs because either not enough water is being pumped to the spray arm or in other words the full flow of water is not making it to the upper spray arm. Will the spray arm rotate freely? If it does not, then you might have to remove or replace the spray arm assemblies since it is possibly damaged. Confirm that the drain hose is strapped up properly under the sink to prevent the water from siphoning out during the cycle. If issue persists, I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
Jun 20, 2013 | Frigidaire Dishwashers
Model 664.15732000. The Normal Wash light on control panel will not light up however the Pots and Pans light will. I ran the cancel/drain cycle and re-tried. See my video. Could if be the fuse in the
Hi there, can you put it through the pots and pans wash cycle , see if it works with that first ?
also the drainage pipe might be blocked making the normal cycles unusable.
you might need to get in a plumber or somebody that can unblock a pipe.
Hope this helps .
Dec 29, 2012 | Dishwashers
Manual for hotpoint how to work it
  • Load the appliance with dirty dishes, placing soiled pots and pans on the lower rack where they will be subjected to the most vigorous cleaning. Glassware and dishwasher-safe plastics should go on the top rack. It is not necessary to rinse dishes before loading them in the Hotpoint appliance, unless the dishes have been sitting for awhile and the food particles have dried.
  • Fill the detergent compartment with your preferred brand of dishwashing detergent, and add glass rinse solution to the rinse reservoir on the inside of the door if your model is equipped with one, then close the door to lock in place.
  • Select the cycle you wish to use and press the button. For pots and pans, use the heavy-duty cycle. Normal wash is fine for dishes and utensils.
  • Save on your energy bill by running the dishwasher only when it is full and by allowing the dishes to air dry instead of using the heat dry function on the appliance.
  • Oct 10, 2010 | Dishwashers
    WHY DON'T DISHES DRY? MODEL ADW1100N10WW
    water tempt too low . use longer cycles like pot & pans . if d/w has a heater turn it on . always run tap at sink till water is hot then start dw . this is a common problem it's probably not the dishwasher . but how ou are setting the cycles .. mm hope this helps . feed back pls ..
    Dec 22, 2009 | Dishwashers
    How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
    Normal wash cycle is as follows..
    Wash1 8 min
    Rinse1 10 min
    Wash2 21 min
    Rinse 10 min
    Rinse 12.5 min
    Dry(hot or cool) 23.5 min
    Total of 85 min
    thats just a normal cycle. Pots and pan cycle is of course longer
    Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
    Stuck on wash cycle
    Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
    Aug 05, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
    Smeg oven cleaing cycle
    Typically on any self cleaning oven, remove the racks and any pots/pans etc and wipe any excessive food stuffs etc from the bottom and set it for 3 hours.
    Sep 17, 2007 | Smeg S1100MFX5 Electric Single Oven
    Not enough water in tub
    Mderford, on a normal fill, the water should be just above the filter screen. 1.8 gallons first fill, 1.7 on all other fills. Don't think it would be a siphoning problem as you are not having this on the pots/pans. Check the float, make sure it is not sticking. You can check the inlet valve filter screen to see if it is not plugged. Run it through the diagnostics cycle by pushing high temp-air dry-high temp-air dry. Some models it's heated dry-normal-heated dry-normal. It will run through a self test for about 20 minutes. See if any error codes come up. Fill time should be approx. 1:30 to 1:40 seconds. If any of the aformentioned doesn't turn up any results, then it's possibly a faulty fill valve drive circuit on the control itself...Catriver..post back.
    Oct 02, 2006 | Whirlpool 24 in. DU900PCD Built-in...
    Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
    78 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Robert Roath
    Robert Roath
    Level 1 Expert
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
