Question about Westinghouse LTV-19w6 Television
Cable picture is fine. no sound.
Hooked this TV up to cable, programed fine, picture (video) is fine. Getting no sound...it is as if the TV speakers have been turned off in favor of an external speaker set up.
    President:
  • 1,099 Answers
First check that any muting control is not activated. This might be a button on the remote or set itself. If you have a headphone jack, it may have dirty contacts as plugging in a headphone usually mutes the speaker.
If the set is mono or only one channel of a stereo set is out, then check for bad connections to the loudspeaker. Test the loudspeaker by disconnecting one of the wires (with the power off!) and measuring its resistance with an ohmmeter (it should be less than 100 ohms - probably less than 8 ohms). Or momentarily touch a 1.5 volt battery to the speaker terminals - you should get a click or pop from the speaker.
Next, trace back from the speaker output terminals to the circuit board and look for bad solder connections or a loose or dirty connector.
If these tests do not reveal anything, you probably need a scope (or audio signal tracer) and schematic. Or at least the part number off of the chip. Is the final amp a chip also or just a transistor? Have you tested the transistor? If there is little or no buzz from the speaker, that would indicate a problem fairly near the output. If the tuner/if were bad, I would expect some noise/humm pickup from the low level audio stages. Get the part number off of the chip. If it is in a socket, check the contacts for corrosion or looseness. Hope this helps...
Posted on Jun 02, 2010
I have no sound coming out of my speakers for the reciever that is hooked up to my tv. i have 2 of the spekers hooked up and the audio cable plugged in to the tv but im getting no sound from the tv t
hi,try going into your tv setting and see if thers a setting for ext speaker as sometime ther is ,this is the place i would look and the only place i would think the fault would be ,you say audio cable i take it you mean
rca cables [two cables] if not check them but i dont think its both of them faulty,def in setting somewere.good luck
Jan 21, 2013 | Kenwood Audio Players & Recorders
We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
Sep 08, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
Have blu ray player and dishnetwork hd receiver hooked up to receiver with hdmi cable. getting picture from both and sound from tv but not thru surround speakers.
Sounds like you have both inputs going into your receiver correctly since you're getting the right picture. Your problem is the output - are the speakers hooked up to the output on your receiver? Is the receiver switched to the right setting? Many receivers have settings so you can switch what inputs are on at the moment. Try looking at the back to see which input they're on and make sure the audio portion of the receiver is switched to this as well.
These are the most common solutions. Hope it helps!
Mar 07, 2011 | Audio Players & Recorders
We have our cable box hooked up to the tv and get a great picture but no sound. The previous owners had a stereo system hooked up to the tv and we are simply trying to get any sound at all. We went into...
Ok, I need more verifications:
1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
Feb 03, 2011 | Fujitsu Siemens PlasmaVision P42VHA40...
I have a Quasar TV that has worked perfectly fine until the other day. Picture is fine, but no sound. The speaker volume is on.
Check all your channels. If you are getting sound on some channels but not others it is a good possibility that your SAP setting is turned on. Simply go into your audio menu and disable the SAP. Not sure about your model tv but some Tv sets had a switch on the back to disable the speakers and some have a setting in the menu to disable the speakers. If you have a digital cable box hooked to the tv it is possible the cable box volume is turned all the way down which will override your tv volume. Check these options and hopefully one of them works for you.
Jul 10, 2010 | Quasar SP-3235 32" TV
Bose 123 system and Samsung LED TV problem.....
yes use the Av cables for this connection . at the back of the TV there should be video in and Audio in connection.
for video its usually the yellow pin so yellow will go with yellow tv & m system
just follow colour code
ansd now u will get visual on the screen .
good luck dude
Sep 08, 2009 | Bose Cinemate Digital Home Theater System...
Connected pc to logik 32in lcd tv, getting picture but no sound
Need clarification. Do you have speakers hooked up to your computer? Or did you just plug in a VGA cable from your computer to the TV? The sound can't magically go from your computer to the TV, because VGA cables don't transmit sound. So if you are indeed using speakers, which I doubt, it's a computer problem.
Basically, describe exactly what components you have and how they are hooked up.
Jun 27, 2009 | Compaq Presario SR1010NX (DW254A#ABA) PC...
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Can't get picture after connecting to receiver nad speakers
Sounds like something got confused in the re-wiring...if the TV signal from cable doesn't involve a box, then the co-ax should go straight to the "cable in" or "RF in" on the TV, and the sound equipment gets connected to output ports on the TV. Otherwise, try bypassing the video connections on receiver or whatever and go directly to TV...My surround sound has video in and out, but I've never used them, it doesn't matter.
Feb 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Westinghouse LTV-19w6 Television Logo
141 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
