Question about InFocus Office Equipment & Supplies
Last year I purchased a clearco hd9000 projector the cooling fan on the left hand side shed it's blades. i replaced the fan but the overheatinghad damaged the lcd panel, which you were kind enough replace free of charge however when i reassembled it the filter had also been scarred as had the hinged lens.i would be obliged if you could send me these two parts and a sketch showing the assembly of the lcd and filter, I do hope this makes sense. peter coe tel and address alredy with you
4 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: I wish to connect my MP3 player to a Clearco
any adapter that will go to an rca connector.
Posted on Jan 15, 2010
  • 17 Answers
SOURCE: My clearco HD9000 projector works when connected
Right click your desktop, go into your video card control panel and set up the projector as a clone or extended desktop. Make sure the resolution is 1024x768 or less for both laptop and projector if cloned, or for the projector only if extended desktop. Toggle through with the PC/AV button on top of the projector until you gen an image.
Posted on Feb 05, 2010
SOURCE: Image Upside-down
acer projector cuts off after a few minutes.
Posted on Apr 20, 2010
Where can I buy a new bulb for my Clearco HD9000 projector
Its a 150 w metal halide bulb. any electrical supply store or online. about 5 pounds cost
Dec 22, 2011 | Office Equipment & Supplies
Why is it that my Clearco HD9000 projector defaults to 1080i when connected to my SKY HD Satellite box, which is great but when connected to my Pansonic Blueray it defaults to 1080p resulting in lines down...
> 1080I
This is "interlaced" output -- the 1st horizontal line on the screen is painted,
then the 3rd, 5th, 7th, 9th, etc lines are painted, to the bottom of the screen,
then the 2nd, 4th, 6th, 8th, etc. lines are painted.
Your satellite box probably outputs both 720p and 1080i.
> 1080p
This paints the screen in order: 1st line, 2nd, 3rd, 4th, 5th, etc.
which some video-philes indicate produces a "better" picture,
i.e., smoother display of moving objects on the screen.
Your BluRay player probably outputs 1080p, because BluRay has been designed for High Definition displays.
So, check the manufacturer's web-site for the CLEARCO, to see if it supports 1080p mode.
Mar 09, 2011 | Computers & Internet
I have purchased 3 new lamps. one lasted 900 hrs.
Your lamp is rated for 3000 hours. Is the fan working to cool the lamp? When you turn off the projector do you allow the fan to continue to run? If not the lamp is not cooling evenly and the lamp will fail. Th filters should be cleaned regularly and the vents be unobstructed.
May 14, 2010 | Toshiba TLPLMT70 Projector Lamp
Image Upside-down
i think you should enter the setting mode and check their for image flip settings or something.
Apr 12, 2010 | Office Equipment & Supplies
Connecting Clearco HD9000 Projector
I'm not familiar with that particular projector, but I believe I can help you get a couple cables to hook them up.
According to some specs I found * the projector has a VGA connection. Next we need to figure out which MacBook Pro you have. Does it have a silver keyboard or a black keyboard? If the keyboard is silver, you need a "DVI to VGA" cable, at least a metre long. You might want a longer one. If your keyboard is black, your MacBook Pro probably has Mini Displayport. That's a bit more exotic, but I'm sure you'll be able to find a "Mini Displayport to VGA" cable.
You can also get adaptors and then use regular cables.
For audio, I believe they're called 3.5 mm stereo plugs. So you'll neet a 3.5 mm stereo plug to 3.5 mm stereo plug cable. Make sure it will be long enough.
Apple sells both kinds of cables. If you want to save money, you might shop around. I don't know UK stores, so I don't know if I can help much there. I buy my cables at www.monoprice.com, an American site.
* http://www.electrobuys.co.uk/special_detail.asp?prod_id=458&grpid=458
Hope this helps.
Good Luck!
Bot
Apr 09, 2010 | Apple Computers & Internet
My clearco HD9000 projector works when connected to my PC, but does not work when connected to my laptop. I get a no signal message. Any suggestions?
You must enable external video on the laptop for one. Also, verify that the resolution is within the projector's range. Most likely, you do not have the external video connector enabled. There should be an "F" key with a symbol that looks like a TV screen. Holding down the function key and pressing that "F" key should toggle between the following 3 options:
1) External screen only
2) Laptop screen and External screen
3) Laptop screen only.
Toggle through the above as well and you should get the projector to work.
Dan
Jan 04, 2010 | Office Equipment & Supplies
The post between the doors of my side by side refrigerator is hot. If you open the doors and put your hand on the outside,it is hot. I cleaned the bottom of the frig last nite and noticed the cooling fan...
The fan motor needs to be replaced . Pt # W10124096 , is the part number for the condenser fan motor ( compressor cooling fan ) . It costs about $ 100.00 for the part , but is easily replaceable ( 2 or 3 screws ) .
Nov 20, 2009 | Whirlpool Refrigerators
NEC LT260 PROJECTOR NOISE
To open this projector, you need to undo six screws at the underside of the case. That means you have to turn the projector upsidedown.
Pls note that one of these scews is a little hidden under the carrying handle.
After removing the screws, return the projector to it's normal 'up-side' up, standing position.
Remove the bulb cover srews and remove the bulb cover.
Lift up the top cover carefully starting from the front then all together.
The cooling fan is mounted very near the bulb assembly.
Carefully check the fan blades for any obtacles, wires or even a broken fan blade, that could be causing the noise.
Baba Anji.
Dec 18, 2007 | NEC LT 260K Multimedia Projector
223 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
