Vizio ;gv47lfhtv10a. no picture/no sound. power supply looks ok because 5.11,25 volt is there. If possible like talk to silverdragon.
  • kon kim Jun 02, 2010
    vizio;gv47lfhtv10a. no picture/no sound. power sully looks ok.
  • 12,061 Answers
Www.scribd.com/.../LG-TV-Plasma-Training-Manual - 3 hours ago
www.scribd.com/.../SONY-KDL42XBR950-TV-Plasma-Training-Manual Hi, well I applaud you for starting in the right place, The power supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins.
Troubleshooting say if it is shutting down, after a certain amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. Now just replacing boards will most likely just end up with more faulty, boards, as related you MUST ensure that you have the cause of the event, before we change anything. I have seen so called, "Techs" replace every board, and virtually every component, and that STILL didn't fix it, because the "Fault, or Cause" lay elsewhere, and had not be repaired FIRST, you see that FIRST STEP, like everything in life, is, CRITICAL.
Posted on Jun 02, 2010
  • electronic & computer repair&  servicre
    When servicing try not to let the entire thing overwhelm you as one, treat the set as a conjunction of “Units”. Meaning that we can break the unit up into sections, for instance we have a Power Supply, and Audio section, a Remote Control section, we have a Input Control section, we have a Video Control section, and so on. Now all these connect to specific parts of the circuit. Some have no relationship with each other and some are dependent upon each other. What we need to do is try to understand our “Fault” and isolate it to at least an “Area”. Now when we have isolated the apparent problem, we then need to check our “Input” to that section and also the “Output” of that section, also we must first check that sections supply voltage and current, are correct. Depending on the unit being serviced, the Repair options, may be limited to changing a “Board” to clear the fault. Often these boards are exchangeable, and you get a rebate back, if when you purchase the new board, you send them you old broken board, and they then repair that, and around it goes. Other times, one must go down to “Board level” to effect a repair, always double check, before determining some component is faulty, it is best to isolate/remove, the component to test, often an “in situ” test can give erroneous reading due to “Other” components connected, altering the readings. Always replace with as good if not better components that you are replacing, skimping of component costs is counterproductive, in the long run.
    It can often be a great troubleshooting method, to completely isolate the “Faulty” part of the circuit, if you can, isolate the in & out, and also remove, the “Native” power from, it too. You power from and external source, then also you can provide an External “Drive” to this circuit which you will NOW, be able to test under a, “know good” situation, which is so important to gain a benchmark for operation.
    NEVER EVER simply replace a Board or Component without ascertaining WHY, it has failed, as seldom does anything spontaneously fail, unless placed under stress at all operating times, such as a power Supply or the like.
    Copy and paste those links form the top, if no luck Google plasma training manual.
    first of all, this unit is not plasma. it is lcd. secondly, this unit is not shut down problem. set comes on but no picture/no sound.
  • 5,138 Answers
Go to Encompass Parts Distribution and type in your model number.
Vizio E550i-b2 has no picture
Could be an open internal fuse or power supply failure
Aug 16, 2016 | Vizio Televison & Video
Vizio tv has sound no image
If you can see an image on screen via flashlight test then the backlighting is not working. And the inverter board is the unit that powers those lights ..... So....................
Mar 05, 2016 | Vizio Televison & Video
Why is there no picture,no sound?
Your tv is fine! The power supply has a short or defective component. I suspect its a transistor or capacitor(s) on the power supply. These are easily replaced. This may not fix the entire problem. Its possible that the inverter board has shorted or malfunctioned as well due to a domino like effect caused by a failed component on the power supply.
Worst case scenario the entire PS (Power Supply) needs to be replaced. The cost for PS are roughly $50 (but as much as $200) and easily replaced. My charge is $40 to replace a board.
Have it fixed by someone you trust. It shouldnt cost more than $100 and be good as new when repaired!
Jan 23, 2016 | Vizio Televison & Video
Power shuts off by itself....
Hmmm ... Vizio can't identify symptoms of a failing power supply?
Feb 04, 2018 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Power on, no picture, no sound
more than likely you have a faulty main board, common problem with Vizio's. There is a slight possibility the power supply is at fault. I would recommend you get a diagnosis to be sure.
Apr 07, 2013 | Vizio VP422 42 in. Plasma TV
Vizio 19 inch no picture no sound
That capacitor could possibly be the cause. On some sets, the 12V supplies both the video and audio circuits. I would recommend replacing the cap and checking power supply outputs especially the 12vdc supply.
Sep 09, 2012 | Vizio VA19LHDTV10T 19 in. LCD TV
No picture power ups blacklights work no menu no
If you see the back light, then you should have 24vdc on the main power supply board which it gets the turn on command from the maun board. If you do have all those voltage, then it does sound like you need the new main board.
Nov 25, 2009 | Vizio L37 Television
Tv sound but no picture
The backlight inveter board may have gone out ,or the power supply is not working to supply power to the inverter board, those are the two places to look.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 08, 2009 | Televison & Video
Tv wont work
does the power indicator blink? If so how many blinks? also do you hear any sounds when you press power?
Aug 09, 2008 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
