Question about Kidde Nighthawk Combo Gas/co Detector
Hi, I have a Nighthawk carbon monoxide/explosive gas alarm (KN-COEG-3)that now is displaying "Err" and chirping every 30 seconds. It is plugged in and has a new battery. I have reset it with no change in the reading or chirping except for the loud alarm sound when I press the reset button. After pressing the reset button, the unit beeps loudly and continuously at one second intervals as it should for propane/methane detection and will not stop until I unplug it and remove the battery. I have removed the unit from its position near a water heater and am now working with it in an area with no gas sources and fresh air flow. The problem with the unit continues. What is the "Err" reading and how do I remove it? Thanks.
3 Suggested Answers
  • 3 Answers
SOURCE: what does an err code E03 mean?
Correct. Intermittent beeping is a sign of "component failure". Time for a new one.
Posted on Dec 25, 2008
  • 7 Answers
Malfunction signal - Component failure. An intermittent "chirping" alarm will sound every 30 seconds, and an "Err" message will appear on the digital display. The only solution is to discard it entirely and replace with a new gas & carbon monoxide alarm.
Posted on Nov 10, 2012
My unit keeps chirping every 30 seconds even after replacing the batteries. The unit is over 5 years old.
The manufacturer has written this in their manual for your unit...
"Err" displayed -battery icon may show any state of battery capacity. One quick beep every 30 seconds. Unit is Error condition
Replace batteries. If "Err" (or blank display) continues, unit has malfunctioned. Replace immediately.
Link to manual...
http://portalgb.knowledgebase.net/utility/downloadArticle.aspx?aid=294720
Feb 03, 2011 | Kidde Nighthawk 9000089 Carbon Monoxide...
Nighthawk carbon monoxide alarm model number KN-COPP-3 err beeping every 25-30 seconds, I replaced battery they still beep. They say to seek users guide, which can't be found. It seems to have started...
1. Change batteries.
2. Clean it.
3. Swap it with another location if you can.
If it still does not work properly consult the local fire dept. for free.
You may have to take it in repairs if all fails.
Nov 08, 2010 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk carbon monoxide alarm model KN-COPP-3. ( ERR appears in the window, what does this mean ....
Readings You May See When Unit is AC Powered
Display Shows Alarm Sound Unit Status Recommended Action
Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer
and flashing dot 30 seconds AC powered service at 1-800-880-6788
Readings You May See When Unit is on Temporary Battery Backup
Flashing dot None Normal battery-only operation - Plug in to AC as soon as
unit will show reading only if it possible to conserve battery
senses CO
Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer
"Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here:
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
Oct 26, 2010 | Computers & Internet
Chirp every 30 second
There are 2 things you can do:
1. Check and change batteries.
2. Clean them. Ensure they are completely clean.
If that does not work, you can ask the local fire dept. to look into it free.
Other than that you will have to take it in for servicing/repair.
Samsung SHR-2082
Apr 21, 2010 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk chirps and displays err
I took the following from the Kidde website. They only answer the phone from 8am-5pm, Mon-Fri, EST.
The next time your carbon monoxide alarm has ERR on the display, push and hold the Peak Level button.You will see an E and an O followed by a number.Contact our hotline at 1-800-880-6788 and provide us the error code, along with the model number, assembly number and date of manufacture from the back of your unit.If your unit is under warranty, a replacement will be mailed to you.
Nov 23, 2009 | Kidde Nighthawk Combo Gas/co Detector
My Kidde Model # KN-COEG-3 keeps going off and lists 217 now 205 now again 217 and this is with the door open and fresh air coming into my place ??
I took the following from the Kidde website. They only answer the phone Mon-Fri, from 8-5, EST. I checked it out because my almost new Kidde CO detector is showing an Error code.
Nov 21, 2009 | Kidde Nighthawk Combo Gas/co Detector
What does an err code E03 mean?
the sense is bad, unfoturally the unit need to be replaced.
Nov 24, 2008 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk carbon monoxide alarm model kn-copp-b
Here is a link to the manual, or you can call the consumer hotline at 1-800-880-6788
Nov 10, 2008 | Kidde Nighthawk Combo Gas/co Detector
Carbon monoxide detector err code
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (It's not worth to buy just a sensor). Take a look on amazon: Amazon com Carbon monoxide detector (watch out on reviews). I hope this was helpful. cheers
Aug 13, 2008 | Kidde Nighthawk Combo Gas/co Detector
Kidde Nighthawk Combo Gas/co Detector Logo
63 people viewed this question
Top Kidde Home Security Experts
richie46
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
