Where is ac orifice tube on 2000 jeep cherokee
    President:
  • 1,515 Answers
Hi, you must be referring to the txv or metering device that meters freon into your evaporator coil. It is also called the thermostatic expansion valve. If you follow both the high and low side freon lines from the compressor to where they head back toward the firewall of the engine, that's where you will find this metering orifice. It is soldered or flared to the high side refrigerant line where it meters freon into the evap coil throttling back and forth as needed on a call for cooling. The coil is more likely a squared type and is sealed to keep out heat and everything else. You may have to excess from both inside and outside of the firewall as I don't have the book in front of me, but you will no quickly. I hope this has helped you out. If you need more information on this, and what the a/c is not doing, keep me posted. Best of luck to you,
Shastalaker7
Posted on Jun 02, 2010
Ac not cold cool but not cold
Have you recently added R-19 refrigerant to your Jeep? The 1989 model base requires R-19 Freon, not the newer R-134A designed for the newer cars...Has your stock system been re-fitted for the new R-134A refrigerant? If cool but not cold, the system could be low...or need a clean/new orifice tube...Try for a free inspection in your area...
Aug 06, 2015 | 1989 Jeep Cherokee
Location of orifice tube in 2000 chevy venture
best advice is the method i would use to located the orifice tube in the 2000 chevy venture. check the automotive repair book section in your local library. Most libraries have repair manuals on their automotive shelf section. find the a/c manual for your year and model car. make a copy of the page that has the information you need. you will need to make a copy because the library will not let those manuals be checked out. you might want to google for the location of the orifice tube location. I hope this helps.
Jun 18, 2014 | 2000 Chevrolet Venture
Where is orifice tube on a 2007 jeep liberty
think i just fouond it. it is near the firewall on the same line where you find the fitting to add coolant. it is in the rubber portion of that line ( i htink that is called the liquied line)
Aug 03, 2012 | Jeep Liberty Cars & Trucks
Where is the AC expansion valve on a 1995 Jeep Grande Cherokee?
For the 93 it is in the line before the evap core, should be about the same for the 95, unless an orifice tube was used in that model.
Aug 08, 2010 | 1995 Jeep Grand Cherokee
We are trying to clear a clog a/c in a 1995 jeep grand cherokee
Do you mean a clogged orifice tube in the a/c system?
Aug 01, 2010 | 2001 Jeep Grand Cherokee
2000 jeep cherokee no power to clutch or low side
I have the diagram. The pressure switches run off ground and they just go to the ecm. Then the ecm grounds the compressor relay. Is the auto climate control or manual controls?
Jul 25, 2010 | 2000 Jeep Cherokee
How do you blow out the ac drain line on a 2000 Jeep Gand Cherokee?
It has a tube with a rubber elbow on it,just pull the elbow off,and there is a plastic tube that you will see,use compressed air to do this,you will find this directly below the evaporator,where the ac lines go in the fire wall.
Jun 05, 2010 | 2000 Jeep Grand Cherokee
Condensation water from ac on passenger side floor of 2000 jeep grand cherokee laredo
evaporator drain is plugged... Look at the bottom of the firewall on the passenger side... should see a rubber tube (Short, only an inch or so long) coming out... need to squeeze it and see if anything is plugging it.
Sep 14, 2009 | 2000 Jeep Grand Cherokee
1994 Grand Cherokee Laredo Blocked Orifice tube
I have a 1994 jeep laredo. When I make a u turn there's a loud sound while making the turn and the car starts skipping until I turn the wheel straight. What causes that?
Jun 13, 2008 | 1994 Jeep Grand Cherokee
Heating & Cooling Logo
242 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
