The agitator is not moving - the drum is spinning but the agitator is not agitating (sp?)
  • 159 Answers
You will have a slipping or broken belt under machine tighten or replace hope this has helped
Posted on Jun 02, 2010
How to find out if belt needs replacement on a whirlpool WTW4800X02
Does it agitate? That is does it spin back and forth during the wash cycle ok? The agitate and spin are through the same drive belt, so if it does one and not the other its probably not a belt or motor issue. When it gets to the spin cycle does it try to spin, do you hear the motor or anything run or the drum try to spin?
Jan 02, 2018 | Whirlpool Washing Machines
Agitator does NOT spin along w/ drum during spin cycle
If this is the old style that uses a belt, it is not worth fixing. But the problem sounds like the wig-wam is not functioning properly. Most of the time it was a wire broken since it moves back and forth constantly.
Jan 28, 2010 | Kenmore Washing Machines
How to adjust new belt on maytag washing
sounds like you have a bad transmission. can you lift the top up so you can see what it is doing when it is trying to spin. does it adgetate and spin at the same time? If yes you have a bad transmission. also if you get 2 people one looking inside of the drum and the other turning the big pulley in one direction it should turn the whole drum in the other the agetator should go back and forth. Tell me what happens thanks.
Jun 10, 2009 | Maytag MAV4755A Top Load Washer
Both drum and agitator spin during wash cycle. Is this normal?
What is the age and model number of the washer? It could be as simple as a problem with a part inside the agitator or it could be a bad transmission. A complete model and serial number from the washer not the book.
Jan 10, 2009 | Washing Machines
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
