Question about Lexmark C760 Laser Printer
Does the lexmark c760n print continuous forms
  • Official Brand Answer
  • 3,344 Answers
I'm sorry but unfortunately the Lexmark C760n does not support continuous forms. I hope I can assist more on this.
Posted on Jun 02, 2010
Testimonial: "Ta very much"
Skips pages while printing
check the page length set on printer/ system/print server in printer & fax
Jul 26, 2013 | Lexmark Forms Printer 2590 Dot Matrix -...
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Lexmark x6170 not printing magenta
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to improve the print quality:
On the printer operator panel:
  1. Press Copy.
  2. Press Options until Maintenance appears on the display.
  3. Press the right arrow until Clean Cartridges appears on the display.
  4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print your document again to verify that your print quality has improved.
Using the Lexmark Solution Center:
  1. Click Start > Programs > Lexmark X6100 Series > Lexmark X6100 Series All-In-One Center.
  2. From the Maintenance tab, click Clean to fix horizontal streaks.
  3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  4. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working cartrdidge or better yet replace it with a new genuine Lexmark cartridge.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
How do I align the top of form position & for adjusting printing position on my pre-printed form?
Make sure continuous forms are in the printer.
Press Alt and then press Setup to enter Setup Mode.The
printer prints out the Main Menu.
To select a function, press the buttons listed on the printout.
To save the setting and leave Setup Mode, press Start/Stop
until out of the menu.
Jul 13, 2010 | Lexmark 2380 Plus Matrix Printer
Lexmark T632 printing about 1/32" too high on form.
Hi, the only way to solve your problem is to change the layout of your form on your system. Good luck, Gerrit Jan
Jul 29, 2009 | Lexmark T632 Laser Printer
Lexmark Z2420: How to nudge margins to align a form
Go into your printer software before printing, tell the software what you are printing on letter, 4x6 labels etc.... then print
Jul 08, 2009 | Lexmark Z2420 Printer
Lexmark x2650 after scanning computer will not save photos
Mohammed Mohiuddin
Bangladesh
+8801818788171
Lexmark X2650 Print problem…………
Fast time Print comment come Print the Alignment page
click print to pritn a page that will help you align and achieve the best quality.
I click print next come resend the print job
the recent print acrtidge chage modifed the forme of your print job.
evry time i print same problem. please solution & solve this problem.
my email : systemengineer_08@yahoo.com
Nov 08, 2008 | Lexmark Office Equipment & Supplies
My printer Lexmark 7100 series (all in one) X7170 don't print from a DOS accounting program. The accounting manual tell me that it is necessary I enter the "Printer Control Codes" in order to...
Looks like your Lexmark is a GDI (AKA Windows-Only) printer, as no "emulation" or "control codes support" is listed at http://www.lexmark.com/US/x7170/specs-tech.html
You may want to have a look at Printfil to enable your DOS program printing to Windows printers, including GDI and virtual printers.
Please find more info and a free trial do download at http://www.printfil.com
Sep 05, 2008 | Lexmark Office Equipment & Supplies
Lexmark 2380 Top of Form
Can't get printer to set top of form. Can you help?
Dec 10, 2007 | Lexmark 2380 Plus Matrix Printer
Lexmark C760 Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
