Question about Hitachi 51G500 51" Rear Projection HDTV-Ready Television
Tv go thru different functions on its own after being on for a few minutes.
Turn the tv on and after about 45 minutes it starts switching to pip mode and zoom modes and colors greens and pinks and yellows start swirling around. Seems like it does it after it warms up. When you first turn it on it has no problems.
    Scholar:
  • 170 Answers
After it warms up, and starts your problem. turn tv off. unplugg it. then feel the tops off all the caps for heat. also check the hv wires for leak and fluid leakage on boards. could be a possible broken trace or cracks in solder. possible in signal board.
Posted on Apr 09, 2008
When you turn the tv on it starts scanning thru all the channels
in set up mode it does that , as it thinks you have just started it up for first time(it don't know any better) and its looking for what channels it can receive (and store in memory) it might take some twenty minutes or more to complete this function , if you use remote and interrupt it to watch something , it wont ever complete this needed function so it does it again next time you turn on
Jan 14, 2016 | Televison & Video
How do I hook up PIP on my Samsung 60 inh Series 6 LED TV. Pictures and instructions please. Thank You!
The manual is here... http://downloadcenter.samsung.com/content/UM/201007/20100708133121375/BN68-02698Q-00Eng-0607.pdf The PIP instructions are on page 20.
The PIP will function using one source (thru Component, HDMI, etc.) and another being the TV tuner. THE PIP by default is thru the TV Tuner.
Oct 12, 2010 | Samsung Televison & Video
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Magic focus problem
in the menu first check if focus is set to auto or manual, need to be auto, if it is then pop off the front cover and acess panel with TV on cafefully press small button on signal pcb front edge, this is service mode, press pip mode,then pip channel after intialize turn TV off then on, function should be restored.
Aug 09, 2009 | Televison & Video
Every 10 minutes my Panasonic plasma 720p turns mute
the problem is it is locked in store mode. I had to call panasonic to fix it, this is what they had me do.
1 hold the volume down on the tv while holding the menu button on the controller.
2 after the screen changes to the check menu, hold the off switch on the tv untill it turns off.
3 unplug the tv for 30 sec.
4 plug it back in and turn on the set.
5 select home option
6 your done.
Jan 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Green Screen
Turn Tv off by power point unplug even for 30 or 45 minutes then turn back on. that way the tv has time to reset back to normal
Sep 07, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
PIP function not working
Hi !
I'll have the same problem, but i solve it when i change the RESOLUTION OF THE COMPUTER of 1680x1050 on 1440x900 at 60hz
TRY IT !
Jan 11, 2008 | KWorld 1680 TV BOX HIGH-RESOLUTION...
PIP stuck
MrKevin, some Hitachis have 2 different pip buttons on the remote, I believe 1 says pip mode or something to that effect, do the rest of the functions on your remote work? Check and see if you have a second pip button and be sure the remote is set to "tv" if it has that little slide button on the side, good luck, hope this helps
Nov 27, 2007 | Hitachi 50EX01B 50" Rear Projection...
PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
Apr 13, 2007 | Sony KV-27XBR45 27" TV
Hitachi 51G500 51" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
