Question about Seagate U6 (ST340810A) 40 GB Hard Drive
What is the cause of a clicking hard drive? - Seagate U6 (ST340810A) 40 GB Hard Drive
  • 192 Answers
If you think of a hard drive as an old phonograph/record player it makes this easier to understand (assuming you are old enough to have seen a record player..SMILE) The data is stored on platters or circular metalic disks that spin at 5400 or 7200 revolutions per minute. A "Head" or needle like arm extends from the corner of the drive and actually reads and rights data to those platters. When the arm motor goes bad the "HEAD ARM" typically will chatter against the HD case as the head doesnt stop where it should and hits the case. If your hard drive is still functional I would suggest backing up your data as this chattering always indicates an impending failure of that drive. If the chattering is happening and the drive is not being read then the motor has gone bad on teh arm already and its a goner. If the data has SIGNIFICANT value the platters can be remounted by a professional company and data retrieved but that service usually starts at about $1000 dollars and is usally used only by companies to recover data for business reasons.
Posted on Jun 02, 2010
I have a clicking noise coming from my hard drive, and now nothing happens when i plug in just clicking and light blinking....im lost and scarred i have everything on that...whats wrong?
The cause of this clicking sound is the arm of the hard drive platter moving as far as it can to the right, in a pattern or randomly.If this write head touches the platter of the hard drive and scratches it, all the data that is stored on that portion will be erased and be unwritable. The hard drive repeatedly attempts to recalibrate the write head, causing the abrupt clicking noises. In most of these cases, the problem is caused by a manufacture defect or physical abuse of the hard drive itself.Unfortunately this is a sign that its worn out also.
Jun 12, 2011 | Western Digital My Book Essential 1TB...
Describe your samsung sp0822n how to removing a bed sector in hard disk
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer hope this helps
May 07, 2011 | Samsung (SP0822N) 80 GB Hard Drive
Help me
since you have not stated what the problem with your hard drive is i will have to list any cause and solution
Fist clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error computer error a computer needs its connections continue its cycle and have an end to function
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
hope this helps
Apr 10, 2011 | Computers & Internet
I have 2 problems , the first is cyclic redundency (i can't copy files from my labtop to it) then after 2 days when i placed it in the labtop it couldn't be read by it ( it's name didn't appear)
A cyclic redundancy check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive.
Here are some steps fixed the issue:
Rule out problems with your computer Start by defragmenting your disk. Click the "Windows or Start" button in the lower-left corner of your computer screen and select "Control Panel." Click the "System and Security" icon. Choose "Administrative Tools," then "Defragment your hard drive." This will clear up clutter on your hard drive that could be causing the error
Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the "Tools" tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
If the hard drive is not detected by the sytem try if to a different usb. If still fails check the warranty of the drive then call the manufacturer or store you purchase it you might have a bad drive.
Thanks for using Fixya.
Feb 07, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
Before formatting my laptop i transwereed all my data to my external hard disk. after formatting when i trnswering the data from hard disk to laptop the error comes redundancy check error mostley in...
Hi jrawat7,
A Cyclic Redundancy Check, known as a CRC error, often occurs when you're attempting to transfer data to a hard drive. It's most commonly caused by an interruption in the recording process, but also can be a sign that you've got problems with your hard drive or optical drive.
Rule out problems with your computer Start by Defragmenting your disk. Click the Windows or Start button in the lower-left corner of your computer screen and select Control Panel. Click the System and Security icon. Choose Administrative Tools, then Defragment your hard drive. This will clear up clutter on your hard drive that could be causing the error
Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the Tools tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
Don't Forget to say Thanks. Thanks for using Fixya.
Feb 05, 2011 | Computers & Internet
I am getting the data error (cyclic redundancy check)
  • Rule out problems with your computer Start by defragmenting your disk. Click the "Windows or Start" button in the lower-left corner of your computer screen and select "Control Panel." Click the "System and Security" icon. Choose "Administrative Tools," then "Defragment your hard drive." This will clear up clutter on your hard drive that could be causing the error
  • Use the CHKDSK program in Windows to see if there are other problems with your hard drive. Click the Windows or Start button and select My Computer or Computer. Right-click the drive with the CRC error. Choose Properties, then select the "Tools" tab. Click Check Now. Make sure the program will fix disk errors by checking the top square in the dialog box. Click Start.
  • Thanks for using Fixya.
    Jan 31, 2011 | Western Digital My Passport Essential...
    Computer causes new hard drives to click within 3 months.
    A.Perform a Disk Check 1. Double-click My Computer,right-click the hard disk that you want to check. 2. Click Properties, and click Tools. 3.Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed, Click Start. Now, restart the computer and Disk check would be performed.
    B.Perform Disk CleanUP to remove the useless stuff. 1. Click Start, double click My Computer. 2.Right-click the disk in which you want to free up space, and then click Properties. 3.Click the General tab, and click Disk Cleanup. 4.Click the Disk Cleanup tab (if it is not already selected), click to select the check boxes next to the files that you want to remove, and then click OK. 5.Click Yes to the proceed with this action, and then click OK.
    Please follow steps in the link given below also. http://www.fixya.com/support/r4507477-fix_computer_infected_viruses_malwares
    Apr 30, 2010 | Computers & Internet
    My hard drive has been making a clicking noise for a while, the computer freezes up at times, I do not think the cooling fan is working, could this cause the issue with the hard drive making noise, and if...
    More than likely, your hard drive is failing. This COULD be the cause for the freezing. The other thing that could cause the freezing is if the processor is getting too hot due to the failed fan. Either way you will need to have your HD replaced before it fails completely. The clicking you are hearing is the read head hitting the case of the hard drive. It might have started from being too hot. If the parts of your computer are getting too hot, it will increase the chances that they will fail in the future.
    Jan 24, 2010 | Dell Inspiron 530 Desktop Computer
    Clicking noises
    clicking in hard drives basicly.. it comes out from the head going up and then droping down, then going up and droping down.
    Id say the harddrive is faulty, would need to be replaced.
    I cant say more without actually haveing a look at the drive from here...
    Apr 13, 2008 | Trekstor Datastation maxi t.u SATA 500 GB...
    Can't find the cause for clicking noise and BSOD
    From what I've read, the "clicking" is a sign that the hard drive is about to fail. The cause is using two devices (hard drives, CD-ROM drives, etc.) with different read/write speeds on the same IDE cable. For instance, you MUST not have an ATA100, ATA66, or ATA33 hard drive or CD-ROM drive on the same IDE cable as a faster ATA133 hard drive. Hope this helps
    Mar 16, 2006 | Maxtor MaXLine Plus II 250 GB Hard Drive
    Seagate U6 (ST340810A) 40 GB Hard Drive Logo
    161 people viewed this question
    Top Seagate Computers & Internet Experts
    Arora Singh
    Arora Singh
    Alun Cox
    Computer Links
    Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
