Help with dvd player DRC282 remote code
I just got comcast universal remote with my newly opened account and also a new RCA DVD player DRC282 and I can't find the code for it anywhere. I searched the remote manually for the code but the one it gives me won't let me scroll through the menu or use the play key, etc
  • Anonymous May 28, 2008
I tried that with my Comcast remote and didn't get anything.
DJ
Posted on Dec 27, 2009
I purchased this same DVD player (DRC282) and none of my universal remotes worked for it. Since I was lucky enough to buy one without a remote, I ended up purchasing an RCA universal remote (RCR3273). Once again, none of the codes worked so I had to unplug the unit for 5 minutes, then plug it back in and hold the Standby button for 15 seconds to return it to it's factory settings. I manually searched through 71 codes before I found a match but the play, pause, rewind and many other functions failed. I tried again skipping over 71 and found the right code at 115 tries. That one had all the functionality I needed. You should try the same strategy with your Comcast universal remote. Skip the first match and keep going until you hit the second manual match.
Posted on Aug 21, 2008
I need a remote for my RCA DVD player, model DRC282. I haven't had much luck with a couple of universal remotes. Any help would be appreciated.
Just try a code search process. Sometimes it might help you:
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
May 12, 2012 | Televison & Video
Need remote code for Apex AD-1201 DVD player w/Comcast universal remote (red OK button, black Comcast letters)
I don't have the original control remote for Apex Ad-1201 DVD player. I would like to use my Universal Remotes: Radio-shack USA "flag" 4-IN-ONE Remote and / or RCA 312W three component remote. I got the codes from the manuals but my DVD player doesn't work or turn off (only ejecting; open and close) with pause button. Could I get a possible code (s) for these Universal Remotes?
Dec 30, 2010 | Apex Digital AD1201 DVD Player
I need codes for my universal comcast dvr remote to a norcent dvd player.
http://www.eliztech.com/remotes/rca-codes-4digit.php hope it works.... rate please
Dec 06, 2010 | RCA 3-Device Universal Remote with...
Looking for comcast remote code for a rca truflat tv/dvd combo
<a heref="http://universalremotecodes.blogspot.com/">Magnavox Universal Remote</a> check the codes here
Jul 12, 2010 | RCA 20F610TD TruFlat TV/DVD
Remote code for RCA DRC277
my rca dvd player model # drc277 will not play .i put a dvd in and it opens and closes. Is there a code to play all region disc?
Jun 21, 2009 | RCA DRC277 DVD Player
Comcast remote code using RCA universal remote control
After hours of research I managed to find a code that works. It does not control the built in DVD player but just having to power and volume functions is a life saver for me.
The code is 12002.
Enjoy.
Oct 18, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Need help finding DVP3140 remote programming code for comcast universal remote
Since the codes that Comcast gave you did not work, there is a very high possibility that the remote control is not compatible with the DVD player. You cannot expect universal remote control to work with all devices, regardless of its make. Philips does not have codes for this DVD player because it is the maker of the universal remote control that sets the codes.
Mar 24, 2008 | Philips DVP3140
Trutech dvd player
www.funai.us
Customer Support Representatives may also be reached by telephone at 800-242-7158
Dec 30, 2007 | TruTech TT1620 DVD Recorder
I NEED REMOTE CODES FOR THIS DVD RCA DRC200N
I finally found a code that works. Code 3144 worked. I am using the RCA universal remote control RCR412S and RCA DVD player DRC200N. The code 3144 is listed under Memorex in the code book that came with the remote control.
Oct 17, 2007 | RCA DRC200N
I need a Universal Remote code for this model.
I got it to work with code 12002. I have the Comcast DVR Remote.
Dec 04, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Televison & Video Logo
995 people viewed this question
Top Televison & Video Experts
