Question about Onkyo DV-SP404 DVD Player
My Onkyo DVD/CD Player CP704 plays CD's with no problem, but DVD's are a problem: I get "loading" but does not play and I get "no disc" on many occasions. What gives, any solutions? Thank you.
  • budhadley Jun 02, 2010
    1st, my Onkyo player is CP704 not CP404, and if lens is dirty, which is best DVD lens cleaner. As I stated my CD's play perfectly, it's Just DVD's where the problems lie.
  • 5,138 Answers
Laser Beam could be dirty, use disc cleaner or clean the eye beam on the laser pickup but the Laser ickup could also be bad, Mats has them
1-800-628-1118 First try Cleaning Eye Beam.
Posted on Jun 02, 2010
  • Onkyo Master
  • 6,993 Answers
the problem is from the laser (lens) of you player. The lens is weak such that it cannot play DVD's. It still play CD's because the file or data on CD are lighter than that of DVD's. DVD disc carries about 4GB (4000MB) size while CD's carries about 700MB (Less than 1GB). So the laser (lens) is too weak to load files/data on DVD's. It needs to be extra active to be able to load data/files on DVD's.
I hope you understand the point I am tying make.
Now the solution to this problem is to change the laser (lens), that is, the laser (lens) need to be changed/replaced to a brand new one so that is can play DVD's.
Once you have the laser (lens) of your player changed, your player then be able to play DVD's.
Good luck.
My Onkyo DV-CP704 randomly stop playing, and switching DVD's
I recently had a similar problem with my Onkyo DV-CP706...the "DVD mechanism" part was bad. I sent the unit to the ABL Electronics in Michigan and they fixed it. They are an authorized Onkyo repair center. If you're still under warranty they'll fix it for free. My unit was not, but I opted to fix it rather than purchase a new one. They will clean your unit, inspect it for other potential problems, and it will come back to you better than it was when it was new from the store.
Sep 28, 2012 | Onkyo DV-CP704 DVD Player
"Bad Disc" message when reading a disc with JPEG files
Hi
Similar Issue happen to one of my client what we have done is putting the JPEG files into folders (Not Subfolder). It worked well however some JPEG images being skipped if the size is unusual. JPEG images will appear as tracks. Hope this will be helpful. If issue persist please post once more. Also let me know if WMA files are being played.
Good Luck
Jan 24, 2008 | Onkyo DV-CP704 DVD Player
My ONKYO DVD player has totally hanged up.It turned on and started searching the dvd, BAD DISC or NO DISC appears on the DVD player screen.. All the buttons became jammed and didn't work.How to solve my...
I had a similar problem with Onkyo DV-CP706--it would play CD's but wouldn't play or recognize DVD's. Looking at other people with Onkyo problems, it looks like this is the most common part to fail on their DVD players. I had mine fixed by an authorized Onkyo repair center, ABL Electronics, located in Michigan. They said a part called "DVD Mechanism" was bad. They replaced that part, cleaned the machine and ran diagnostic checks for other problems, then sent it back to me. It now works perfectly and makes less noise than it did when it was new. If your Onkyo unit is still under the limited warranty, they will fix it for you for free. Mine wasn't, so it ended up costing just a little less than buying a new machine, but I feel like it was worth it. You never know what you'll get with a new machine, especially if you buy online.
Mar 27, 2011 | Onkyo DV-CP704 DVD Player
My Onkyo DV-CP704 will not play any DVD's but will play CD'S. I have always used it to play music but now would like to use it both ways. I have had this unit for 3 years but have used it very little. ...
clean the laser using a lazer disc cleaner not only does the disck get dirty but the lazer too when its too dirty it wont read the disc -- disc error
heres a piture of one you get them from electronics shops
Jan 02, 2011 | Onkyo DV-CP704 DVD Player
My onkyo DV BD-507 only play dvd disc, and dosent play blu-ray disc
Sep 25, 2010 | Onkyo DV-BD507 Blu-ray Disc Player, Black
DvD disc won play
the lazer might not be seeing the disc properly try a disc cleaner which has nylon string on it and they clean the lazer lens
Jul 06, 2010 | Onkyo DV-SP800 DVD Player
My onkyo dv-cp704 powers on but frrezes after
HI...
A problem like that will need tech service.
Check the onkyo consumer site for service people
Dec 05, 2008 | Onkyo DV-CP704 DVD Player
Multi region code for DVD
You need to hack the dvd reinstalled firmware, I can see if I find hacked firmware for your dvd
May 01, 2008 | Onkyo DV-CP704 DVD Player
Play all region dvds
Multi-Region Hack:
Press the Open button on your Onkyo DVD-player to Open the drive tray.
Using the remote press 9, 9, 9 and 9 on your remote control.
Press the 1 button on your remote control for region 1, 2 for region 2, and so on, or 9 for multi-region.
Press OK and the tray will close.
Reset the unit by powering Off and then back On again.
Jan 14, 2008 | Onkyo DV-CP704 DVD Player
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
Onkyo DV-SP404 DVD Player Logo
192 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
