Question about Neff V4380X0 Front Load Washer / Dryer
Washing machine keeps tripping the main fuse box
  • 142 Answers
Don't use!!! as this machine has a short and can hurt or kill some one call electric service to check out. If it was mine I would check it, but because it is not mine I don't think I can say for you what to do. Sorry but hope I helped a bit.
Posted on Jun 02, 2010
  • 333 Answers
SOURCE: My washing machine keeps tripping
Frequent tripping means a short in the machine. Disconnect from the supply and locate the drain plug somewhere at the bottom of the machine. You should be able to drain off the water and then open the door manually. Be prepared for a lot of water to be released. The fault will have to be fixed by a service engineer.
Posted on May 02, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
  • 10 Answers
SOURCE: Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
it might be too small of a fuse for your machine
Posted on Feb 12, 2008
lenwest
  • 150 Answers
SOURCE: Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Jan 31, 2009
  • 161 Answers
SOURCE: My washing machine keeps tripping the fuse box
You have a bad circut breaker.
Posted on Jan 28, 2010
Why does it keep tripping the fuse in the main fuse box?
A fuse of a device is for protection.
When there is a defect (such as shortcircuit) it causes the fuse to blow.
You will have to get the washer repaired by a repair man before reuse.
I fuse on the extension cable would normally be of lower rating than the main fuse on the washing machine line.
Apr 19, 2016 | Hotpoint Washing Machines
TRIPS FUSE IN MAIN HOUSE BOX
you may have to add a different fuse line in your box....PLEASE DONT ADD IT TO EXISTING FUSE LINE
Sep 23, 2014 | Zanussi Washing Machines
Trip switch cuts out when i use washing machine
Main board power circuit fault.disconnect main PCB and reconnect power cable .you can identify the fault. Replace main pcb.
Sep 01, 2014 | Indesit Washing Machines
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Nov 18, 2013 | Washing Machines
My washing machine kkeps tripping my fuse box
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Apr 30, 2012 | Hoover Nextra HNF 3157 Front Load Washer
My washing machine keeps tripping the main switch on my fuse box, i replaced the fuse but its still doing it. I ahve washing trapped inside and its in water, its important i get it out. Whats wrong with...
May 02, 2008 | Washing Machines
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Washing machine blown fuses
Hi - had a similar problem with about 3 different makes of washing machine - the RCD switch on the main household fuse box was continually tripping . Nobody could give me a right answer . Eventually ended up with a Hotpoint . Felt sorry for the delivery guys from the electrical retailers having to keep dragging machines in and out .
May 07, 2007 | Indesit WA 115 Front Load Washer
Neff V4380X0 Front Load Washer / Dryer Logo
541 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
