Question about Galaxy Radios DX-99V 40-Channels Base CB Radio
Galaxy 33 no audio from speaker. i have a galaxy 33. it does recieve and transmit. but there is no audio from the speaker and no talk back. my power meter shows its transmitting and modulating and the meter on the front indicates its recieving but no sound from the speaker. i can hear it on te other radio with echo and all working. any clue why teh speaker doesnt work. i also tested the speaker thats fine. and used another speaker which is good also but to no avail
    Genius:
  • 1,274 Answers
Check the receive wire on the plug end of the mike, and the receive wire inside of the mike, just a starting point. ..hope this was helpful.....
Posted on Jun 02, 2010
I have a galaxy dx 33 hml it was doing fine till it fell off dash , now when I key up its really loud through my talk back, and it squeels . Does anybody know what could have happened?
you may have cracked the pcb board and its shorting out the audio and thus making it squeal. Best to take it to a tech and let them tell you whats wrong .
Oct 18, 2015 | Radio Communications
Ranger superstar 33 no recieve
If you're still getting loud squelch noise but do not receive on any channel, you must check the RF from the antenna to the audio stage(not included). There must be more than just one RF stage in this radio. Let me know what you find.
May 08, 2013 | Radio Communications
I have a galaxy 55 v that will transmit and receive but has no swing
I would turn do the watts to about 3.5 and that radio should swing.Sounds to me like its trying to but the wattage is stopping it.Experiment with it and find where you want to set it.
Jan 26, 2013 | Radio Communications
Rci 2950 no transmit
check your mic cord to see if you have a broken wire on the inside.You might want to get another mike for a spare but it could also be an audio transister.
Jun 30, 2012 | Radio Communications
Galaxy dx959 will not receive. Speaker is working. S meter is showing incoming signal.
the over power doides may be blown. you should start there .they should be marked D-1 and D-2. you may want to replace them with diodes of a higher rating.
Jun 26, 2012 | Galaxy Radios DX 959 SSB CB Radio
Got an A. P. Hill that will transmit and recieve but, no sound from the speaker or the external speaker jack. I connected my SWR/POWER meter and i get power out but, nothing thru the speaker even with the...
Here is a quick way to test to see if it is the speaker. Use a multimeter and set it to Ohms. Unsolder the two wires off of the speaker and touch the pos terminal on the speaker with the pos terminal on the multimeter on the multimeter. Touch the neg terminal on the speaker with the neg terminal on the multi meter. The meter should spike a bit and might crackle a bit as well. This says speaker is good. So then you know the problem is most likely the Audio Output Transistor (IC) In your radio you will look for IC8 on the board. It will be marked. Looking towards the back of the radio on the right side it will be a fairly long chip. The good news is that you can purchase one and install it if you are handy with a soldier gun.
Mar 11, 2011 | Connex 3300 240-Channels Base CB Radio
Popping through speaker then no receive sound but signal is their. also lost modulation but output power is their. galaxy 88
most likely you need to replace the mic. and maybe the speaker as well. how can you be sure it does not transmit when noone can answer you since you cannot hear them.
Aug 29, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Rushing sound (noise) galaxy 88 HL
RUSHING SOUND ?
1. Get the noise then disconnect the coax and see if noise goes away on receive, if noise goes away then address the ground on your antenna,
if noise still there then address the ground wire from power source
Mar 30, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Mic wiring for a cobra 85 base cb
Pin 1 is shield, thats the bare wire wrapped around the mic audio wire
pin 2 ic mic audio [usually white)
pin 3 is transmit or push to talk usually red
pin 4 is recieve or speaker complete usually black
Jan 08, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
No sound
It must be a bad internal speaker, but also check the external speaker jack for broken solder. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 31, 2007 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy Radios DX-99V 40-Channels Base CB Radio Logo
267 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
