Question about Drills
Chuck Removal for Black And Decker D303 R/D9 1/2 inch
  • 8,404 Answers
Open the chuck and lool at the bottom. You will see a screw ... it has left handed threads ... remove the screw. close the chuck. It will remove like a bolt in the traditional sense.
Posted on Jun 02, 2010
How to remove a dr200 BLACK & DECKER 3/8" DRILL CHUCK, no chuck screw in chuck
Hi- We have instructions on how to remove the chuck listed on our website Q&A. I have included the link. Please use the instructions for the Keyed chuck. blackanddecker com
Thanks Black + Decker Customer Care
Mar 18, 2015 | Black & Decker Drills
Keyless chuck overtightened
two strap wrenches work well becasue they will not crush or scratch the chuck like channel locks or any plier.
Apr 04, 2014 | Black & Decker Black and Decker FIRESTORM...
How to unstick the chuck
Hi Gregory,You can use a 6 inch pipe wrench on the top of the chuck and an eight inch on the large part of the chuck.Put a rag in the pipe wrench jaws.Lay the drill on a flat surface with the chuck pointed at you.The handles face the same way,small one on the bottom to lock the chuck and the 8 inch on top so they look like scissors. Depending on which way the chuck is jammed will determine if the handles are on the left or right side.Gloves and safety glasses will make holding the top wrench with a bit of force to lock every thing in place.Now just a tap on the end of the eight inch wrench will loosen the chuck.If the set up is wrong you will only jam the chuck more. Thank you for choosing FixYa.
Jan 28, 2012 | Black & Decker Drills
Chuck removal B&D KD335 drill
I have instructions in the tip section that might help. There is usually not much difference in the removal of a corded or cordless drill. Let me know if you need more assistance.
Jan 25, 2012 | Decker BlackN Household Drills and Kits...
The chuck is frozen on my 14,4 Black and Decker cordless drill. This is the second time that has happened with a Black and Decker drill so I assume it is a product defect. In use it was not that...
Yes, they are an inferior product. However you can replace the B & D chuck with a Jacobs chuck that will hold up and last for a long time!
Jacobs Chuck
heatman101
May 23, 2011 | Black & Decker Drills
Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
Aug 18, 2009 | Black & Decker Drills
Cordless drill- chuck jammed.Model No. HP146F2B
b&d usualy thow away inthis range.still you can remove the chuck and fix or relace chuck unscrews anticlockwise hold shaft behind chuck with thin spanner or it may be the type with allen screw dwn the centre of chuck
Jul 25, 2009 | Black & Decker Pivot Plus Cordless...
Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Jul 10, 2009 | Black & Decker 3/8" Variable Speed...
Chuck removal
There is a screw in the bottom of the chuck. It has a standard thread. Clamp the chuck in a vise, find a screw driver that fits as snug as possible, to prevent stripping the screw, remove the screw and pry off the chuck. An impact driver will simplify the removal, if one is available.
Jul 06, 2009 | Black & Decker Drills
Can't remove the chuck on a drill.
There are one-way (non-reversible) and two-way (reversible) drills. Mine is one-way. Methods for chuck removal are different for these two types.
Procedure for one-way (non-reversible) drills:
Drills of this type have no chuck screw, so one have to hold the spindle with a wrench, than to sharply strike the wrench with a hammer to spin it off.
Procedure for two-way (reversible) drills:
Open the chuck up and in the bottom is a screw that holds the chuck on the shaft.The screw turns in a clock wise motion to be removed and then you can top the chuck off the shaft.
May 19, 2009 | Black & Decker Drills
Drills Logo
87 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
